Shut t.v. off will not start again it trys to start because I can hear it...remotes are ok...I tried unplugging it and reseting it...its a sony..27"..eight years old
  • 1 more comment
  • johnbuckus Oct 15, 2008
    is this an easy fix at home...model no KV27S40
    model KV27S40 lite blinks four times..stops and repeats...is this worth fixing
    thank you
    stand by blinks a repeating count four times ...no sound
  • 4,234 Answers
In order to help with this, can you please post the model number (should be KV-27xxx) and count the number of blinks of the standby light? This standby should be blinking a repeated pattern. That will tell me the circuit in which a problem was detected.
Thanks,
Dan
Posted on Oct 15, 2008
  • 1 more comment
  • ABRsvcs Oct 15, 2008
    Thanks for providing the model number. Can you check to see if the standby light blinks a repeating count? Also, is there sound at all?
    Thanks,
    Dan
    The 4 blinks usually means a vertical deflection problem. Look inside for a small flat IC attached to a heatsink. It willbe marked LA7837 or something similar and have about 11 pins. That should be the vertical IC. Resolder the pins first. If that fails to resolve the problem, replace the IC.
    Keep me posted.
    Dan
    Keep me posted.
    Dan
Tried to reset DMPBD79last step it shut off it wouldnt turn back on I just get a blinking redlight.
This is for a diff. model but give it a try, they may be diff. #'s showing up then what pops up on screen then is listed below.
  1. Remove any disc from the drive and switch the device to stand-by
  2. Press and hold [OK], [BLUE] and [YELLOW] simultaneously on the remote control until the device turns on and shows "00 RET" on the display
  3. Repeatedly press [RIGHT] on the remote control until the device shows "08 FIN" on the display
  4. Press and hold [OK] on the remote control for at least 3 seconds -> The device will reset itself to factory condition and show "HELLO" on the display
  5. Press [POWER] button on the remote control -> The device will shut down
May 02, 2016 | Panasonic Televison & Video
Why does my Philips 40" flat screen tv shut off 15 seconds after I turn it on?
The symptom you describe suggests power supply failure. It is still working but fading fast
Mar 24, 2013 | Philips 40pfl3706/f7 Lcd Flat Panel Tv
WS-65511 won't turn on
Hello
The power supply section to your set has the fault. If you come over me by Fixya paid service purchase, I'll assist you to repair your tV by yourself at home. OK.
Dec 07, 2011 | Mitsubishi WS-65511 65" Rear Projection...
Will turn over but once i take it out of park it shuts off and will not start right back up takes a couple of trys to get it started
Welcome to FIxYa.com
Starter solenoid going bad if you hear clicks or not. Replace starter And before you do check battery cables. Clean them and try again
Regards, Lee Davidian
Thank you for using FixYa,com.
Oct 24, 2010 | Honda Accord Cars & Trucks
The ink system not working
here. try to reset your printer. this will clear annoying error displayed on your printer
1. Remove all cables
2. Unplug the printer power.
3. Press and Hold down # and 6 on the keyboard.
4. Plug the power cord back in.
5. Then release the buttons....after successful boot operation, try to print.
If that did not work.. you can also try this.
1. Press/Hold down the HELP and OK button..then unplug printer..release the button
2 Press/Hold down the HELP and OK button again..then plug the printer back in. Just Press and hold down the button while you wait for the printer to turn on (it could take a minute)
3 Now release the buttons and power it back on.
4 Error message will be displayed “improper shut down”
5 Press OK to reset the printer
6. Press both HELP and OK button again to start the resetting procedure of the printer.
Now try printing again...
If you find this very helpful..please rate this solution and vote on this on the YES below....thanks..
Jun 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
Car starts for two seconds shuts down trys to restart three times with same results
code program wire (pink) was left unpluged after programing code.At restart it would lose code. Reset code pluged in wire,runs fine
Feb 06, 2010 | Viper Security and Remote Start System...
Whirlpool GH9185XLQ won't start
check the thermocouple/ thermal cutout on the side of the magnetron tube,its weak and shutting off before tube gets warm,then resets and does over again
Nov 09, 2009 | Microwave Ovens
Python 1400XP remote start system
yes you are correct the learn procedure is done by a dei 555L or a 555G bypass module.your car should have one or the other installed on it. simply unplug it,it will be a three wire plug. then plug it back in and then by turning the ignition on and off it will relearn the code.
Dec 05, 2008 | DEI Python 1400XP Remote Start/Keyless...
Sharp remote control not working
Ok, looks like this TV works on MS Windows. Anyone who has had a computer 5 years back knows that when Windows has a problem, there is only one sure-shot solution.
SHUT IT DOWN, START IT UP !
Try this with your TV. Completely unplug it and leave for one minute. Start again. Voila ! Remote works flawlessly.
Feb 13, 2008 | Sharp Televison & Video
Televison & Video Logo
Top Televison & Video Experts
