Question about Epson AcuLaser C900 Printer
Epson C900 won't print in blue, noisy pick up
For the past week or so all my colour print outs have either very faded blue or now no blue at all. All cartridges are >90%. I've also noted that just as the paper pick up takes place a heavy noise occurs. At first I thought it was from where the paper gets picked up in the tray, but I've since found that it doesn't make this noise when printing in black. It's almost like the Cyan cartridge is blocked meaning no blue in the colour print and a noise caused by the system trying to extract it or add it to the print colour. Sorry if it sounds vague, but I'm lost here.
Any ideas appreciated.
  • Anonymous Dec 01, 2008
    blue or now no blue at all.also noted
    lost here.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 98 Answers
The rollers are jammed with a tiny piece of foam from a damaged pick up roller, usually because it is just worn out from multiple refills or it has been over-filled when re-filling or the wrong brand of toner can sometimes do it too. If you take the roller out of the cartridge, you should be able to dislodge it, but usually it's the beginning of the end of the cartridge, as the roller is starting to disintegrate. You need to get a replacement cartridge.
Posted on Apr 30, 2009
My Epson is printing fine lines of different colours across and over the images that I am printing, if i am printing black the lines are blue, if in colour the lines are magenta or blue in different parts...
Check out this link for Stylus drivers for your printer. What I have found is that you can always go down with printer model for updating drivers but not up. Just copy and paste into your browser.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14387&prodoid=28907797&infoType=Downloads&platform=All
Let me know if this helps, and if I can help you with anything else.
JimmyC
Oct 02, 2009 | Epson Stylus Photo 1290 InkJet Printer
Hullo I have a c900 aculaser, printing fine and now on all colour images, there is no image just block of colour and a series of broken repetitive lines. Help! Christine Willis tel 01803 866577
Unplug your printer power cable, restart your computer and plug the printer cable back and on it and tryt to print. this may help. thank. let me know if it works
Jul 02, 2009 | Epson AcuLaser C900 Printer
Noisy printer
yha u have to change taplone tap on rollers.it is broken so create noise.
Mar 25, 2009 | Epson AcuLaser C900 Printer
Epson aculaser c900
When printing, as thepaper is being transported up the printer, try pressing the right door panel of the printer firmly with your hand. If the colours are much improved then the printer requires a new Transfer roller.
1. Open the Right Door.
2. Remove the Transfer Roller while opening the shaft holder (white color) levers found at the left and right shaft ends of the Transfer Roller to unlock it. Lift out the roller.
Jan 21, 2009 | Epson Aculaser C1100 Printer
HELLO PRINTING FADES RIGHT HAND SIDE OF DOC ANY ADVICE ,THANKS IN
Hello I have sorted the growling sound out with a shot of WD40 lube ,but have not sorted out wht the cyan does not print clearly any advice would be helpfull
Nov 14, 2008 | Epson AcuLaser C900 Printer
C900 Colur print problems
Print a self made test page in word, a bar of bright yellow, bright cyan, bright magenta (almost pink) and black.
You might find one is completly missing, if so its a faulty toner or maybe the pull strip did not rip out correclty.
Jun 23, 2008 | Epson AcuLaser C900 Printer
The magenta & blue rollers on our Epson Aculaser C900 are printing in stripes.
quick check
1. are you running out of toner magenta and blue??
2. remove magenta and blue, shake them gently HORIZONTALY to evenly distribute the toner inside (the toner container internally has a spade that feeds the toner dust to a spongy roller then to the roller u see on the outside :) )). DON'T HANDLE THE TONER CARTRIDGE VERTICALLY ---ESPECIALLY WHEN U ARE LOW ON INK---
3. on photo conductor read my article
http://www.fixya.com/support/t146110-epson_aculaser_c900_photoconductor
May 02, 2008 | Epson AcuLaser C900 Printer
Printing faint
hi
I believe this is a timing problem, you have done alot yet the same problem recurs . Compare the toner drum assembly holder positioning with another similar printer to justify its timing. Remove this holder drum and inspect the metallic contact tracks behind it.
keep me posted on this
labatt
Jan 29, 2008 | Epson AcuLaser C900 Printer
Colours printing really faint
dear sir you should check the colour mixing detect sensor
Sep 26, 2007 | Epson AcuLaser C900 Printer
Colours not printing correctly
please check the charging roller of your new cartridge
Sep 07, 2007 | Epson AcuLaser C900 Printer
Epson AcuLaser C900 Printer Logo
460 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
