Toshiba px1223u-3g32 external hard drive found when pluged in via usb, but not allowing add or remove date, warning message appears (insert disc)
fire sine
  • 382 Answers
SOURCE: Hard drive problem
What operating system ?
Posted on Oct 28, 2007
  • 152 Answers
SOURCE: USB Hard Drive - Won't recognize
this problem depends on your OS, or if that is a really bad pendrive,
if you have windows 9x most of the times you must use that pendrive as a normal hard drive.. with this i mean you have to plug it in, and then start your pc, and to take it out you must turn off the pc..
if its a really bad pendrive, installing the drivers will help, but because those thingies are really lame, they will get busted really fast.
but you can be sure that your USB entrances in your PC are fine because they are recognizing something is in, so the problem is the Operating System, either being too old or lack of drivers.
by the way.. is it a KINGSTON? or a kingbyte?
Posted on Dec 18, 2007
Basti
  • 1447 Answers
SOURCE: HELLO. EVERYTIME I TRY TO
Look for an update on microsoft help and support for hotfixes chances are usb drivers for your vista is not updated
Posted on Apr 17, 2008
  • 305 Answers
SOURCE: My PC has XP Home
TO BE HONEST, I WOULD TRY TO ROLL BACK YOUR SYSTEM TO BEFORE YOU INSTALLED SP3, IF ALL WAS WORKING THEN, WHY BOTHER WITH SP3. I PERSONALLY DO NOT ACCEPT ANY UPDATES FROM MICROSOFT AS THEY ALWAYS CORRUPT SOMETHING AND MANY PROGRAMS DO NOT WORK. I'VE GOT SP2 AND I'VE NO INTENTIONS OF INSTALLING SP3 (IF IT AINT BROKE, DONT FIX IT)
Posted on Jul 01, 2008
Cytherian
  • 124 Answers
SOURCE: How to install new hard drive
Hi Mark,
External drives have come a long way and run almost as fast as many internal drives. If your need for extra hard drive space is pretty much driven by the Microsoft Flight Simulator game, you could get by with using an external drive. A few things, though: Make sure your system is supporting USB 2.0 (it should be) and that the drive runs at least 5400rpm. External HDD's run off standard 120v AC power.
Otherwise, if you want to get an internal drive, you can certainly get another ATA-133 drive. But SATA is faster and your computer may support it. The D530 CMT (convertible mini-tower) definitely does. But there is also the D530 SFF (small form factor), and D530 USD (ultra slim desktop)--not sure if those are rigged for SATA support.
As for maximum hard disk size supported, that's up to the operating system (e.g. Windows XP vs. Vista). You likely won't need any bios updates because of a new hard drive installation. However, its not a bad idea to review the BIOS update release notes to see what they're addressing.
Posted on Dec 30, 2008
Ps3 system update error
Sorry its so long but its step by step ;)
1. Download the update onto a USB stick using your pc. (Hopefully you have one). Create a new folder named UPDATE and drag the file into it. Then create a folder called PS3 and drag the 'UPDATE' folder into that. Note the folders must be in capitals.....
2. Underneath your console is a small panel near the front that pops open to reveal a small screw. Unscrew it and then remove a bigger panel on the actually front of the console to reveal the hard drive. It has a wire handle that will help you remove the hard drive. (Don't take it out yet)
3. Turn your console on and when the update loop begins take the hard drive out. After a minute or so it will realise this has happened and a error message will appear and a 60 second countdown will start. Let this time countdown and allow the console to restart. ( a post a read on a forum said that the console will restart on a screen that will allow you to download the update via USB but is did not happen for me and the system said it was unable to start because it could not detect a hard drive.)
4. Turn the console totally off and insert the hard drive. Turn it back on and as it is beginning to start carefully take the hard drive back out. Then a screen will hopefully appear that says to connect your controller to the USB wire and press the ps button. Do this and then it will give you the option to update via USB. Insert your USB drive and press start and select on your controller.
5. Then comes a step that I can't really explain and is the trial and error part of the process. When the system is searching for the USB update I inserted the hard drive. On the first try it didn't find the update and a error message appeared, but as I tried the whole process again it found the update and completely the process. I didn't lose any saves and more importantly, didn't pay a penny!!
Jul 30, 2014 | Sony Playstation 3 (PS3) Console
Ps3 system update error 8002F310
Toshiba l645 bootstrap
The Windows operating sustem appears to be corrupted and most like to get a working computer you need to restore it back to the factore default condition.
Before you attemp to do this and to back up data, remove the hard disk from the Toshiba and connect this hard disk to an USB hard drive adapter, then plug this adapter into the USB port of a working computer. This computer will see this as an external storage device. You can then open the various folders on this drive and back up your data on this computer or an USB memory stick.
To restore your Toshiba, insert the hard disk back into the Toshiba and follow these instructions..
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.http://www.fixya.com/support/r8248520-restore_toshiba_out_box_condition
Mar 05, 2012 | Toshiba Satellite L645DS4037 Notebook PC
My 16GB usb flash drive is not working. it is shown on safety removal & device manage, but when i try to open it the please insert disc message appeard
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 10, 2011 | A-Data Technology Adata USB C802 8GB BLK...
Hello, What cable or adaptor do I need to transfer all data from the hard disk of my Toshiba Satellite Pro A200 to my new laptop via USB port? Thanks.
You won't be able to transfer hard drive data by plugging one computer into another via USB. In order to transfer data, you will need to remove the hard drive from the Toshiba Satellite Pro, use an external hard drive enclosure, and attach that to your new computer with any USB cable.
The hard drive can be taken out by removing screws on the bottom of your laptop. The drive can be found in the bottom left of this picture: http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Here is an example of the exclosure you would need: http://www.newegg.com/Product/Product.aspx?Item=N82E16817816013
Mar 14, 2011 | Computers & Internet
Toshiba external hard drive 640Gb appears on my laptop the USB connects perfectly ,it opens but doesn't take in any file .
hello, i would advice you to format your external hard drive by write clicking on it and click on format and click on start to begin, if this does not allow you to still put files on your external hard drive,then insert it on a friend laptop and see whether you can move files to it. I hope this helps. Regards
Feb 08, 2011 | Toshiba 640GB USB 20 Portable External...
HOE TO FORMAT DATE TRAVELER
The simplest way to format a Flash Drive or a Pendrive is to format it from the My Computer without using any commands. Let's assume you are doing it on a Computer (Pc Desktop). Follow the instructions;
1. Connect you Data Traveler on one of the Usb port of your computer, and wait for few minutes.
2. After you know that it's been detected by the computer, open "My Computer" then right-click on the Data Traveler's Drive Icon e.g. Removable Disk (K:), etc.. and select "Format"
3. When the format dialog box is opened, click "Start" and then you'll be prompted with a warning message to confirm the proceed, click "Ok" to proceed. Formatting Dialog box bf3d566.jpg
Format Warning Message
4. Wait for few seconds and you'll get another message that the drive has been successfully formatted.
If you have problem, please let me know. Good luck.
Thanks for using FixYa.
Jul 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
No access to USB drive when inserted (Windows). ''Malfunction'' error message.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 30, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
Toshiba satellite memory stick problem
Oct 09, 2009 | Toshiba Satellite A135-S4527 Notebook
Sir/Madam when i attached my external 30gb hdd via usb ide data cable with my laptop message appear "unrecognized device" how i solve this problem?
You need the driver for the device. If the HDD came with a disk you will need to install that beore hand. =) Hope this works.
Ed
Jan 31, 2009 | Toshiba (HDD2181) (hdd2181-50pk) 30 GB...
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
