Question about Lexmark X2470 All-In-One InkJet Printer
INK Sir, Can you tell me why I,m using a lot of ink also I cannot print or send photos and how do you clean the printer,or do l have to send it away,plus it wont print photos of my cameras........thank you
    Scholar:
  • 191 Answers
Please refer to this link and this will definately help to resolve your issue.
http://support.lexmark.com/perl/support/support.cgi
Regards
Moses
Posted on Oct 15, 2008
Canon printer mg5300. Suddenly ink on photos not drying. Should I clean something? Thanks.
No has nothing t do with dirty heads or nozzles. I think you used the wrong paper (or plastic) and did not tell the printer what it was printing on. Be aware ink yet printers need special paper, so the droplets (how small they may look with only a few pico litre) don't give a splash pattern and the ink will dry very quick. What looks like normal paper, has an absorbent on top of it. Only use photo paper when it says photo paper for ink yet printers. The best results you get, when you use the Canon paper, canon ink and use this in the settings while printing.
Feb 27, 2015 | Canon Office Equipment & Supplies
Printer prints every 2nd or 3rd line of a Word Document in pale gray ghostly way
Ink jets may be clogged, go into your printer software for the canon. At someplace in there there should be an option to run the cleaning program on the printer. This is used to clean out the jets and clean up the printer a little bit. Make sure that you have lots of ink, Cleaning process uses a lot ink
Nov 29, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Sir , my printer canon pixma ip 1200 when i start to print it show waste ink obsorber is full. please help
Hi. I think the problem on that one is the waste ink tank is already full, so you need to clean it or replace the pads on it, because when you are printing or opening your printer it blows little amount of ink to the heads so that it will not be clogged, and that ink goes into the used/waste ink tank. Also after cleaning the used/waste ink tank you need to reset the counter of the printer so that it would print again, you can just download the counter reset software2_bing.gif over the internet or just bring that machine to an authorize canon printer technician. Hope this Helps
Jun 09, 2010 | Canon PIXMA iP1200 Photo Printer
Not printing in color and black/white copy not clear, light in some places
Dear sir
good day
to fix up such problem
Clean the printhead, then print and
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo + Copy simultaneously to print a demo sheet
and you have to Replace ink cartridges.
IMPORTANT: Make sure you are using KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to KODAK Ink Cartridges & Photo Value Packs.
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Insert new KODAK ink cartridges into the printhead, then press down firmly until you hear the cartridges click into position.
  3. Close the printer access door, then make the same print.
and you can point to the website below for further information
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=5224/6198
thanks
Dec 18, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Wont print it prints but no print comes out ink is ok
1st try to clean heads (printer cleaning function)
2nd see if any fresh ink droped on ink basket (inside right/left position.(normaly wrong ink density as non original ink cartriges, have 2 situations: ink too light as low quality ink, drops to much ink on ink basket, and flod and detiorate all metalics parts inside.
Or too heavy, and no ink will pass on print head holes).
3rd u can have the print heads, burnout (u can test on diagnostics tools on printers software), or send for repair, for local repair shop.
Nov 28, 2009 | Office Equipment & Supplies
HP C4500 ink consumption
Dear Sir,
Now a days all HP ink catridges available at low price that means ink quantity is also low.So if you print heavy coloured pages it will deffinately consumes more ink.So print in gray scale or black and white consumes low ink. Compare to gray scale,black and white printing consumes very low ink. So print in black and white is the better choice.
good luck
Aug 08, 2009 | Office Equipment & Supplies
Not printing clearly even after cleaning the head
Hello sir; Not only to clean the print head also the ink cell.;
turn power on, open the cover, the ink cartridge will move to the center, then UNPLUG power cord, now you can manually move the cartridge check the ink cell which ink cartridge allway seating, there should be have a lot ink stick, just remove it.
Aug 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Printing problem with Epson CX9400
I have a CX9400Fax and occassionally print is mixed/missing lines. You must do a Cleaning cycle usually at least 4-6 times or until it prints a clear pattern. It will use LOTS of ink during the cleaning cycle. The printer normally uses a lot of ink, my solution was to purchase a CISS system along with a Waste Ink Container. IMO the best CISS is sold by the company below. I did have to call for tech support once and they returned my call in 30 minutes, problem solved and never came back. I purchase refill ink and it seems that I do a lot less cleaning cycles.
http://www.inkproducts.com/ink-store/
Jun 20, 2009 | Epson Stylus CX9400 Photo Printer
Ink not dry and significant smudging
there r various modes in the printer in which u have to print .and that u have to select.as you said it is printing properly on ordinary paper.the printer is perfect.the photo paper have less soaking power that ordinary paper.as the photo paper can consume ink but not so quickly as ordinary paper.
u just change that printmode and then check out how it prints.
for example the modes r ----------best mode printing.
better mode printing.
fine mode printing
normal mode printing.
draft mode printing
economy mode printing.
now i f u print in best mode it will consume lots of ink but will take lots of time to print.
if u select normal mode it will consume less ink and print quickly.
u can change the settings in printer properties.
thanks
Nov 14, 2008 | Canon MP610 Photo All-In-One Printer
No black print outs
Run the software cleaning utility (almost always accessible from the printer) in order to fix a clog. Replace the ink cartridge if the clog cannot be fixed or if the cartridge is almost empty. A way to physically clean the clog is using a q-tip dipped in rubbing alcohol and wiping it on the printer cartridge head.
Jul 23, 2007 | Brother MFC 210C All-In-One InkJet Printer
Lexmark X2470 All-In-One InkJet Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
