Question about Relisys TL 766 Monitor
Relisys TL766 monitor. OSD menu continually open, wont close. Standby button doesnt always function.
The OSD menu opens and flashes through its settings and cannot be closed. Being in the centre of the screen makes it almost impossible to work on the pc.
The standby button does not function and the only way is to turn the monitor off completely.
The monitor is almost 2 years old and until the last few week has worked well. I tried contacting Relisys but understand they are in liquidation.
Can you help?
Many thanks,
Sally
PS, My husband has an identical monitor bought at the same time and it is still functioning with problems- although it gets less use.
    Problem Solver:
  • 6 Answers
Here is a definite solution to all those having problems with OCS menu on Relisys TL 766 Monitor.
Having tried many of the posted solutions none of which worked. The only option was to visit my local PC repair shop who disconnected the OCD monitor for UK £15.00. Spare parts for this model are no longer available. Only down side was the power indicator light in middle of now redundant control buttons does not work. Otherwise a monitor works perfectly. NO MORE STRESS.
Posted on Feb 19, 2009
  • Douglas Meikle Feb 19, 2009
    Re my posting on solution with Relisys TL 766 Monitor.
    Apologies for typing error when refering to function menu. This should read OSD FUNCTION MENU
    Finnock.
Osd Lock how to open?
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
http://s807.photobucket.com/home/budm/allalbums
Jun 14, 2011 | AOC 917Sw 19" LCD Monitor
Tip
AOC monitor Lock-Unlock instructions
on Apr 25, 2010 | Computers & Internet
My optiquest Q19wb monitor has the contrast/brightness option disabled in the menu..I am using it as my secondary monitor..OS used is win7
Try unlocking it:
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
Apr 16, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
When I'm trying to change the menu setting of my AOC Led Monier I get a error message saying "OSD Locked", What should I do to resolve this?
Mar 23, 2011 | AOC 912Vwa-1 19" Monitor
Cant get my monitor back in english its on *** i think
restore your settings to "Factory Settings" by
use the front panel buttons
Power Turns the monitor on and to standby or sleep mode.
? NOTE: The power button is located on the top or front of the monitor depending on the model.
- Menu Opens, selects, or exits the OSD menu.
-Adjusts the volume level.
-Opens the Quick View menu to quickly adjust settings for gaming, video, photo, and text.
? Navigates backward through the OSD menu and decreases adjustment levels.
+ Navigates forward through the OSD menu and increases adjustment levels.
Auto Auto-adjusts the display
Select Enters the selected option.
Jan 06, 2011 | HP w1907 LCD Monitor
AOC LCD MONITER OSD LOCK
Apr 24, 2010 | AOC 917Sw 19" LCD Monitor
I got horizontal lines occasionally across my Relisys 17'' TL766 black monitor,sometime they disappears when I turn monitor off and on again,sometime not,what is causing them
try to open back cover and remove / insert all connector that you can found including ribbon wire check also soldered side for possible lost contact.
Apr 10, 2010 | Relisys TL 766 Monitor
Monitor menu shows up all of a sudden
If the butttons are not stuck on these monitors it could be something as simple as dry joints on the monitor somewhere. When this happens again lightly tap the front where the buttons are without pressing any and the sides then finally the back. If any of this tapping causes the menu to suddenly disappear and reappear then its dry joints. Otherwise it could be a number of problems. Post if it does not work and I will tell you more. Good luck.
Jul 23, 2008 | Relisys TL775 17" LCD Monitor
OSD function menu is on screen and scrolling through the menu. I have a relisys TL766 17" TFT-LCD monitor. How do I solve this problem
sounds like a button is being pressed you may need to open it up and see if the inside parts are pinched or damaged
Jun 17, 2008 | Computers & Internet
OSD function menu
ok i think i know how to get rid of it now, i did an ATX reset on it and it does go away HOWEVER as soon as you push the menu button again it comes back.
ATX Reset: unplug the main power lead then hold down the power button on the front of the monitor for about 10 seconds, plug the mains lead back in and then switch the monitor on.
Jul 29, 2007 | Relisys TL 766 Monitor
Relisys TL 766 Monitor Logo
1,060 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
giarcnameloc
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
