Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
I have lost Connection to the unit
The unit has power but when I click on MY COMPUTER on the desktop, Elements has dissapppeared. I cannot get to it anymore.
  • james48ros Dec 01, 2008
    power adapter not working ,how do I get another one
  • Anonymous Dec 05, 2008
    Exactly the same problem but with 160gb model - changed cables, swapped usb ports/hubs - nothing. Left it a couple of days and tried again and it worked.....Now its gone again - are there any external drivers that might work with this damned drive? I wont buy another thats for sure.
I just bought a 320 GB version and I was not at all surprised when it did not work - Windows Explorer did not see it and no USB "gerdunk" noise ensued. Problem is that depending on the quality of the USB port that the USB cable is plugged into, it may or may not provide sufficient powere to the drive. The answer is simple: connect the drive using a Y-cable. This type of cable has two USB Type A male plugs on one end and a single male Mini-B connector on the other end. The two type A plugs need to be inserted into two USB sockets on your PC. One of them supplies 5V at up to 500 mA plus the USB signals; the other suppllies only 5V at up to 500 mA. That provides up to 1 Amp of current compared with up to 500 mA for just a single connection. I don't know why WD does not supply a Y-cable with the drive!!!! I've been aware of this problem for some USB sockets/some PCs/some drives for yonks. The Y cables are somewhat hard to get - here is one supplier in the States: www.pcconnection.com Anyone know of a supplier in Australia?
Posted on Dec 08, 2008
  • mboesen Dec 08, 2008
    I forgot to mention: it is possible that by trying the WD supplied non-Y-cable in another USB socket you MIGHT get a satisfactory result, too. Particularly if you have a desktop PC, then use a USB socket at the rear of the PC and that hopefully is well shielded and connected to the mobo. See my article here about USB problems: http://www.pcug.org.au/boesen/USB/USB2.h...
    However, for 2.5" medium capacity drives, by far the most reliable result will be achieved by using a USB Y-cable.
    And the second solution is to connect the drive to a Powered USB hub, through a non-Y cUSB cable. This is explained in my article.
Tappan tef351ewc
Loose connection somewhere?Replace both elements,make sure connections are tight!
Jan 10, 2014 | Kitchen Ranges
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
WD Elements SE 500 GB/Go not detect in my computer
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery software to recover files.
http://www.asoftech.com/adr/
Aug 31, 2011 | Western Digital Wd Elements Se 1tb...
My Mac will not store data on my wd external hard-drive
Take it back to where you bought it, and get a replacement,
or at least get them to demonstrate that it _does_ work, when connected to a Mac computer (not a Windows computer).
Dec 26, 2009 | Western Digital Elements powered by WD 320...
The computer has lost internet connection.
Hi
Thanks for using FixYa. Please check that the internet signals are being received through your Dell Dimension. You’ll need to left click on the Network Connection icon in the bottom right and then click on the Network and sharing Center and click on the status and you will be able to see the status of your network connection. If there is any red (x) mark against your computer, network connection and internet, then you’ll need to click on this sign to diagnose the error and resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 19, 2009 | Dell Dimension 3000 PC Desktop
Unit is immersed in water during flood. power is okay but unable to heat foods. Units manual is also lost in the flood so there's practically nothing i could refer to. please help me. there's no...
if it is not digital try to open the back side of the oven,check the connection of the wire going to selector switch and elements..
Aug 21, 2009 | Ovens
My dryer takes 3-4 full drying cycles to completely dry.
Since you do have some drying hapening, it is probably a lack of total heat.
Most all dryers have 2 heating elements. One for low heat and both for hi heat. Sounds like you lost one of the elements.
On electric dryers, look for:
1. Safety device has tripped and not reset or has malfunctioned.
2. An element has burnt out. Or a wire to the element has fell off or burnt off due to loose connection.
3. Exhaust system is clogged or restricted, causing safety to active. This stops the heating process. (Don't forget the internals of the unit being clogged too.)
4. Not getting full power to the unit. Reset breaker and verify that full power is to the unit.
(Usually somewhere between 208 to 240 volts, depending on where you are at and the manufacturer of the machine.)
5. Timer has malfunctioned and needs replacement. This does effect power to the elements.
Check these out and let me know how you come out.
Please keep in mind that there is the possibility that a new unit may be cheaper than repairing the one you have. New units have warnanties too.
Choose wisely grasshopper. And Good Luck on your getting it going.
May 11, 2009 | Dryers
Retreiving lost file?????
go to start/search/my computer/then put in the name of your file, it is there just not where you thought is was,
once you find it, move it where you want it, and then right click on the icon, send to/desktop
that will create a shortcut for you to make it easy to find
May 03, 2009 | Adobe Photoshop Elements 6: Windows
Lost power
Open your system units and then refix the hard drive, memory, video card..and all connection inside.
may this help,
melnavz
Aug 27, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
414 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
