Lightening blew out my 35" TV which is approx 11 years old. I replaced the fuse in the set and the power light clicks on when the set in plugged in. The on/off button does not work, it has to be unplugged to turn off. However, I get "cable 2" message on the picture tube which remains totally blank, no lines, no ant fight, no nothing. This makes me believe the tube is no longer good. Any suggestions? Thank you
  • jocko dockly Oct 15, 2008
    Dear Dan,
    Thank you so very much for your advice. Both my uncle and brother who are experienced with electronics (not tv's though) gave me the same advice but I was still apprehensive about letting my big tv go. Now I feel much better knowing that more problems would probably occur in the future. Now
    I just need to locate a safe disposal site. Thank you again. This site is awesome!!!!!
    Heidi (jocko dockly)
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
USB Charger Cable for Apple, Lightning Cable for Apple,Power Cord Connector with Nylon Braided Amazon com Charm sonic 2Pack 4 9Feet 1 5Meters USB Charger Cable for Apple...
Posted on Dec 30, 2016
  • 4,234 Answers
The tube is probably fine, but the internal electronics are messed up. With a set that old, and the fact that it took a lightning hit, I wouldn't suggest spending anything on it. Take whatever insurance money you get and put it toward a new set. Most shops will tell you that lightning hits are not good investments as there are often hidden problems that appear over time.
Dan
Posted on Oct 15, 2008
Panasonic TH37PX80B tv won t turn on
Probable power supply failure.
Apr 02, 2014 | Televison & Video
We have a model AD-40A dehumidifer that I believe is approx 3 years old. When the unit is plugged in, nothing happens. Although it appears to be getting power (when you pull out the water tank, the...
You may have the humidity extraction level set to HIGH. Try lowering the humidity extraction level to 35% or if you have an analog unit, turn the control knob to maximum. Also cleaning the air intake filter may help.
Hope this helps you to solve the problem and thanks for choosing FixYa.
Aug 17, 2011 | NewAir AD-40A Dehumidifier
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
It blew my fuse box, i have changed the fuse the light comes on but it is not heating up approx 5 years old
This happened to my Alessi kettle also. I changed the fuse in the plug but the kettle is dead! Red lights are on but the heating element in gone. From what i can gather parts are not available to fix it.
Feb 15, 2011 | Alessi MG32 Cordless Electric Kettle
No power after lightening storm. blew out dvr upstairs also. this is one of the 10 old combo tv/direct tv wide screens.
several things could have been damaged but the low voltage power supply has a fuse in it which probably blew. you will need to remove both back covers and the right side cover the are 2 screws in the rear on the metal plate where the lexmark factory tag is you will need to remove these. the low voltage is where you put the power cord pullthis out and check the fuse with a mutitester.
Dec 07, 2009 | Office Equipment & Supplies
Tv just makes clicking noise and doesn't turn on
I had the same problem. The power board for the on-off had to be replaced. The set is only 11 months old.
Oct 19, 2009 | Philips 42PFP5332D 42 in. Plasma...
TV will not turn on when power button is pushed.
check the main fuse in the tv. test it with a multimeter, not visually. if its the thermistor that blew the fuse, it is very difficult to see the break in the wire. replace if blown. if unit blown fuse again withing a couple of weeks replace the thermistor in the degausing circuit. good luck.
Jan 09, 2007 | RCA F36665 36" TV
TV won't power up and blows the fuse
A 10 year old RCa most likly has a bad Horizontal output transistor as well as the main High Voltage transformer and The transformer is no lonmger available from RCA. The replacement wont last longer then a year if your lucky. My advice on a set this old ?? Buy a newer one!!
Sep 11, 2006 | RCA F35670MB 35" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
