Question about Pioneer DEH-P80MP CD Player
Reads dc/dc error @ high volume
When i turn up the radio past half way it reads dc/dc error n wont display anything but that. only way to get it to go away is to power the deck back down
More than likely you have a bad ground and/or a power supply problem: bad wire connection, bad alternator - but check the radio's ground wire first.
Posted on Nov 22, 2008
Can I connect my digital receiver to my grundig ghc 1000 home theater? And how I can make the connection?
That depends on the make and model of the radio, and the available inputs on the GHC1000. Does your radio have a line output socket? If not, you can generally use the headphone socket to source a signal. Then all you'll need is a cable with a 3.5mm stereo plug on one end and two x RCA plugs at the other - easily available at low cost from an electronics store. The RCA plugs go to a free line input on the Grundig amplifier and the 3.5 mm plug goes into the radio's headphone socket. HOWEVER some radios require a DC return path to detect that there is something plugged into the socket. You Grundig cannot provide this, and if your radio needs it, this method will not work. So hopefully your radio will not need it.....
By the way, you will have to experiment with the volume setting on the radio if you decide to try connecting it this way and find that it does work. Set too low there will be insufficient audio to run the Home Theater at reasonable volume, too high and you'll get distorted sound. Trial and error is the way to go, but start with the Grundig's volume control set to a low level and the radio's volume control set about half way - to protect your speakers from potential damage if you accidentally drive them too loud
Oct 08, 2013 | Audio Players & Recorders
HELLO: KENWOOD MARINE STEREO WHEN TURNING UP THE VOLUME ABOUT HALF WAY THE RADIO CUTTS OUT TILL YOU TURN IT BACK DOWN THEN IT COMES BACK ON.
You have a grounded out speaker wire or blown speaker. Disconnect speaker wires at the unit. Make sure the wires are not touching, turn the unit on, then turn the volume back up. If it stays on, it is a wire or speaker. Re-connect one speaker at a time and test. once you find the bad wire/speaker, disconnect the wire at the speaker and test again. This will determine if it's the speaker or wire.
If after disconnecting the speaker wires it still cuts out, check your ground and meter the DC voltage at the power wire. If you do not have enough current at the radio, it will shut off as well. Usually this will happen at about 9.8v dc.
If you still need further help, post a reply/comment and I can help you dig further.
Jul 11, 2011 | Kenwood Car Audio & Video
I have a 96 goldwing that the mute is on and wont turn off the radio only goes half as load .
The mute isn't supposed to turn off the radio just decrease the volume. you should have a knob on your radio to adjust how low the mute takes the volumebut like i said it won't completely "mute the radio".
Mar 29, 2011 | 1991 Honda GL 1500 Aspencade Gold Wing
I need to know if the shift motor wiring runs through the radio harness. The radio was ripped out and now the 4x4 wont shift . I checked the shift motor and it still works fine, just not at the switch.
is it possible that the switch is not plugged in all the way,? i know this is a stupid question, but you said the radio was ripped out as maybe stolen, now the other day i pulled the radio out of mine as the display stopped illuminating and the same thing happened. the 4x4 switch worked fine before, i started to look around wiggle things when the plug fell onto my hand, i plugged it in and it started to work again,ok fixed! next day, now the 4hi and 4lo lights flash three times and stop then a few min later flash three times and stop, and wont switch into 4x4 lo or hi stuck in auto 4x4
Jan 14, 2011 | 2002 Ford Explorer
When purchased, upon starting the car, the radio (manufacture model) volume knob would actually be turning down when you were turning the radio knob up, and it did the opposite if turning the knob up, the...
sounds like a serious electrical issue there hard to track down could be the computer staarting to go in car the radio could of been hooked up wrong causeing other stuff to short out what year is the car what kind of car
Dec 01, 2010 | Pontiac Grand Prix Cars & Trucks
My volume will not go past 10on the display and will not go any louder.
Turn the main (volume) knob all the way until volume reads 00, leave the button (volume) pressed until the radio beeps - be patient it takes a while - after this turn the knob all the way or until you reach an acceptable volume limit, push the knob again until beep then turn radio off. This should take care of the problem.
Dec 19, 2009 | Boston Acoustics Horizon Solo Clock Radio
Regarding a Yamaha RX-V757 receiver, if I have my volume set above approximately -28, whether I'm playing a DVD or listening to a music CD, the units power shutsoff. When I turn it back on the display says...
Try turning up the volume with just the FM selected (and tuned to a station). If you can adjust the volume to an appreciably higher level when simply tuning in a radio station, then your CD/DVD player may be outputting a signal with a DC offset, which is getting amplified when you turn up the volume, and past a certain point the protection circuitry is sensing too much DC being sent to the speakers and shuts the unit down. If the unit is getting hot, there is likely an internal problem, or you have a shorted speaker wire, or even a bad speaker. Replace the speaker wires as a test, and you can also run the unit with only one speaker connected at a time to see if any are the source of your problem.
Yes, it's possible that there's nothing wrong with the wires or the speakers, and the unit simply needs a trip to the shop, but it's your job to rule out the easy stuff before you pack it up and take it in.
Nov 21, 2009 | Yamaha Audio Players & Recorders
My radio display is reading E DC and the radio
u need the code from the dealer or look up the books that came with the car firest u might find it
Oct 07, 2009 | 2007 Mitsubishi Eclipse Spyder GT...
Ive got no power to the amp trough the rem wire unless i connect.
You need a bigger amp and make sure its a two channel. Four and five channel amps are for mids and highs. If you want real bass get a two channel. If you dont want to buy a bigger amp, Go get a capacitor. It acts like a battery charge storage for when your sub needs to hit those real low notes. It takes a lot of power. Also if you get a capacitor your altinater that charges your battery will not have to work so hard keeping your battery charged, Thus not wearing out your altinater and not having to replace it so soon because it will happen.
Another quick fix is turning your gain down. I turn my gain up half way, maybe a little past half way. You might not get the bass hitting as hard but at least it wont shut off on you.
Nov 20, 2008 | Kicker 01C8VR4 Car Subwoofer
Dxz785usb radio wont read ipod
IT MIGHT BE A CABLE ISSUE TRY A NEW ONE
Nov 13, 2008 | Clarion Car Audio & Video
Pioneer DEH-P80MP CD Player Logo
331 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
