Question about Garmin BlueChart Atlantic Single Region Unlock Certificate Maps Software
Change region How to change the Region ? When I Insert sim it sez " Incert correcet sim card".
My daughter as moved to austrailia and she put a lebara sim card in her phone that used to be contracted it works nut is not giving her the correct credits it should do does she need to change the jav
Phones are made regionally. Phones in the US will not work with simcards outside of Canada and Mexico because of the laws of certain countries concerning frequencies that the cell phones and tower transmit. She would either need to purchase a phone in her current region or purchase a sim card from the original region of the phone. BUT that is not going to be a promise because again as stated above may not work.
Sep 02, 2012 | Cell Phones
How can I change The Sims 3 Region Code?
Wondering if you need to change your ip address .
to denmark during the installation process ?
https://www.how-to-hide-ip.net/browse-danish-ip-address/
Not sure if it would help ?
Does it need to access the internet to install the expansion ?
May 10, 2017 | EA Sports The Sims 3 Game for Windows, Mac
Invalid card in this region
It's because of Network LOCK............
Aug 12, 2011 | Samsung Cell Phones
I unistalled and re-installed the sims game but it still says "no disc found" why?
Sounds like a Region Issue, check your disk and see what region it is, it should say it on the sims cover usually int the back then go to start menu and right click on my computer the click the hardware tab, at that point highlight your dvd drive and select properties, then choose the dvd regions tab, select the region that the sims is formatted for, but be careful most dvd drives give your only 4 changes to the hardware region before it locks it down for good.
Jul 01, 2011 | Video Game Consoles & Games
How to unlock my dvd for all regioens
You need to ask GOOGLE if it is any modified firmware for you DVD (and of course you will burn you warranty card after reflashing) ;)
Jun 06, 2011 | Philips PD703/37 Player
Sims 3
No problem.
Here is what you need to know:
The regional code for the US is (1).
You can change your DVD Region code up to 5 times on your Mac.
Review the information on DVD Regional codes via this Apple Support link to change the region code:
DVD Region Codes - DVD Player
Let me know if this Apple data helps!
Regards,
-Mactechtrainer
Jan 29, 2010 | Apple 24" iMac Desktop
Region codes and windows vista??
Install Slysoft ANYDVD software, will bypass region locking on the fly.
It works very well.
Jan 03, 2010 | Computers & Internet
Error -70001 problem changing dvd drives region
when changing the dvd region for the fifth and final time. you need to insert a disc which only plays one region (the one you want) in my case region 2. if the disc can play more than one region then it wont set.
Sep 30, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Mobile
Your phone might not be read in tanzania. Each geographical region uses differant types of sim cards or frequencys or satellites.Your best bet is to bring your phone to your provider and have them check your phones compatability with your region. Also have them check if the sim card you have is the correct card for your phone. Hope this helps
Sep 09, 2008 | Locks & Locksmithing
Trying to change region to 2 but it has locked me out is there a code i need
you can only change ur region codes a few times then ur drive becomes locked to the last reset.then youll need to reflash ur drive with firmware.theres a program u can get(free)called any dvd which gets around region codes.
I personally would reflash firmware.this sets drive to "0" which is all regions.
simple precedure.locate firmware,download it,write it to a cd,insert cd which then reflashes auto.remove cd.
Mar 26, 2008 | HP Pavilion dv4000 Notebook
Garmin BlueChart Atlantic Single Region Unlock Certificate  Maps Software Logo
43 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
