I've inadvertantly deleted the recovery partition in (D DRIVE) on a compaq presario and do not have a recovery disc/s as backup. How do I carry out a full system recovery now to get the computer back to factory condition.
  • 19,396 Answers
You can buy a copy of the CD by contacting HP from website, or calling the phone number in laptop documentation, that is the easy way.
The other way is using a generic windows CD corresponding to the licence printed on the sticker at the bottom of your computer. You will need to download and install drivers afterward.
Posted on Oct 15, 2008
My presario cq57 wont boot to windows and there are no recovery discs, how can i reformat the hard drive?
the only way to format is using the CD,before formatting download the network drive from HP so the you can download other softwares after formatting
Jan 27, 2013 | Compaq Presario Cq57 Notebook Pc
Remove hp recovery
That would not be wise, if you remove the recovery partition it will be impossible to reload windows, unless you made a backup recovery disc.
Jun 04, 2012 | HP Compaq Presario F761US Notebook PC
Locate the factory image drive
The Factory Image "D" drive (part of the computers hard drive) is the recovery partition It is sectioned off from the main "C" drive on the computer, you need to save your programs to the C drive. The D drive only has enough space on it to hold the recovery information (an image of the factory settings) and little else, you will need to use recovery discs to get the information that you saved to the D out of there since you can go into the D drive and delete anything.
Feb 02, 2012 | Compaq Presario CQ5300F PC Desktop
Compaq presario 5400t was running out space on hard drive so i added a seagate external hard drive. after copying over files i deleted them off of the internal drive and must have inadvertantly deleted...
use your xp disk, boot from cd then rather format, select the F option to repair.
it will rewrite your windows folder without deleting other personal folders
Jan 02, 2010 | Computers & Internet
Unable to recover my system
u need to fix error on harddisk.
u can fix those error with "chkdsk /r"
command
Mar 25, 2009 | HP Compaq Presario C304NR Notebook
Recovery drive
Usually (since drive d is another partition) you would boot to it by means of startup, the laptop should say something about, to enter a menu here press F6 or something similar. So when your computer turns on, press the f12, or f8 or f2 keys and see if it gives you a menu (the recovery option would most likely be in there). Beware to PLEASE backup your files before formating and turning everything back to as it was :) . Also, you should seriously consider asking Compaq for a recovery DVD, they are usually free and they are livesavers if something goes wrong with the partition on your lappy.
Dec 16, 2008 | HP Compaq Presario V6000T Notebook
Compacq Presario
Prior to re-installing your OS, backup all your documents..
Insert your recovery disk cd on the cd rom drive and reboot your pc.
As it reboots press any key to continue so it will boot from cd and delete the partition, create a partition and active it.
Then install the OS which goes to C:\ drive. After the installation is complete install all the drivers and the applications. You can go to the manufacturer's website and download others drivers as needed.
Activate Windows then go to Microsoft Update
Dec 09, 2008 | Computers & Internet
Recover problem
This can happen if the Recovery Partition is corrupted or the Hard Drive is bad.
 First, I recommend you to check the Hard Drive using the Hard Drive test utility available in the BIOS by following the steps below :
Start or restart the notebook and start tapping the F10 key.
This will get you the BIOS Setup window.
In this. go to the Diagnostics or Tools tab where you can find the Hard Drive test utility.
Select using the Up/Down arrow keys and press enter to start the test.
Make sure that you complete the Full test which may take around 80 minutes to complete.
If the Test result is Pass, we can come to a conclusion that the issue is with the Recovery Partition which is corrupted.
You need to purchase the Recovery Disks for your Notebook in this situaiton.
Contact HP Chat Support to get the exact link to order the Recovery Disks for your Notebook.
However, if the Test Result is Fail, you need to take backup of the data in the Notebook and replace the Hard Drive with a new one.
Hope this helps...
Oct 07, 2008 | HP Compaq Presario v3000z Notebook
My Compaq Presario 700 PC Notebook Problem
you have to break the recovery partition, as the cd provided is only recovery disc, u need the entire vista cd for that
u can contact me at aryansrms@gmail.com
Sep 24, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario m200 Laptop system recovery
buy or download a windows disk. insert it and format the partition and install a fresh copy
Jan 28, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
