Question about Compaq Presario V4000 Notebook
Don't know my BIOS password
I am aware that i need too do something with the battery, now i would like help from someone who could tell me where the battery is located, and then what procedure to take,
i have removed the battery (or at least i think it's the battery) and left it unplugged for 1 hour, but nothing changes.
please help!!
    Genius:
  • 1,124 Answers
New laptop store the password without requiring a continous power so removing the battery should not help in this case. Ask to your manufacturer for your password.
In some cases for example, like Dell laptops, the password will be given by customer support.
Thank you for using FIXYA
Dont forget to rate my help
Pablo :-)
Posted on Oct 15, 2008
Hi. Can someone help me with the BIOS password on my dell latitude e5500? Service tag is: 7KBVQ4J
Hi Mar Mar,
As far as I know once the you forgot your BIOS password no more options to get it anymore. You may also wanted to talk to Dell Tech Support 1-877-542-3355 in order for them to check if they can still do something about it. Worse scenario would be replacing your MOBO.
Apr 25, 2014 | Dell Latitude E5500 Laptop
Please can you tell me how to reset the cmos on a samsung R510 Laptop
Hello you just have to remove the cmos battery:
Press the release pad and the battery will pop out
DO NOT have any power on disconnect all power and usb cables
when you do that.
Wait for 10 min. or so with the battery out
and the bios will reset back to factory settings.
Replace the battery and boot up your machine and enter the bios
you kave to configure the boot order.
Here is some youtube videos how you do that:
http://www.youtube.com/results?search_query=Intel+D945GTP+bios+setting&oq=Intel+D945GTP+bios+setting&gs_l=youtube.12...55167.59517.0.61846.6.6.0.0.0.0.85.411.6.6.0...0.0...1ac.1j2.lSt1MwgqUkQ
But it depends what bios you have.
Good luck
Dec 04, 2011 | Intel D945GTP Motherboard
I have lost the bios password... any body help me to recover without opening case
This is a tricky one because the BIOS password is made to be the hardest password on a computer to break. Some manufacturers allow you to enter BIOS without the BIOS password but most do not. Here are some troubleshooting methods starting with the easiest and moving on to the hardest.
To enter BIOS hit the F2 key repeatedly as the computer boots up. You should enter BIOS after the first loading screen. If this does not send you into BIOS, try the ESC, DEL, and F1 keys. Once in BIOS find where you can set the password and reset it or enter a blank password as your new password.
If you can't access BIOS or are prompted for a password once you enter BIOS, try the following methods to flush the BIOS password cache:
1. Contact your manufacturer's support and ask if they have a backdoor BIOS password that they will allow you to use. This works to allow you to enter that password instead of your own and easily fixes the whole problem, but not all companies will tell you their password. You can also do a google search for your manufacturer's backdoor BIOS password since many of them have been discovered.
2. Send your laptop to your manufacturer to have them reset the password manually, although this takes an undisclosed amount of time and they will often make you pay a fee if you are not under warranty.
3. If you don't want to pay your manufacturer, open your laptop and locate the motherboard. On the motherboard there is a CMOS battery, if you don't know where this is use your PC manual. Remove the CMOS battery for an hour and then place it back on the motherboard. This should reset the password. After this turn on your computer and enter BIOS. This will reset all your BIOS settings so it may take a few minutes to open. After it is open, just exit BIOS and everything should be working properly. Just be very careful when opening the laptop and handling the CMOS battery because you can severely damage your laptop if you don't handle it properly.
Thanks for using FixYa and good luck!
May 23, 2011 | Computers & Internet
My laptop Toshiba Satellite Pro A210 is locked with password in BIOS SETUP It does not recognise the original password
Wow, as I have a Toshiba Satellite Pro. I'm sorry, but there is no easy way out of this if you have enabled a bios lock. It is looking for a password that "someone" set up. I say that because there is no bios password when you setup the machine. Also, the bios password is completely different from the user or system password. (Although you could make them the same.)
Please find the person you got the computer from; type in the correct password; and be aware that it is case sensitive. Make sure the caps key is not accidentally down.
Recap:
- there is no original bios password; you would have needed to set it, and remember it. There is no recovery (that I'm aware of) to a mis-placed bios password.
dw
Dec 31, 2010 | Computers & Internet
Hi i have a dell inspiron 9300 mobo y4694 service tag #2K3HC91-595B. i was obliged to change its ram but now it ask me for bios password something it never ask me before so i don`t know the password. so i...
Your bad luck ... Id dell and IBM bios password is saving in a small non-volatile memory. So you cannot clear it by a jumper or CMOS battery removal. Specialized people can only do the same (contact laptop motherboard repairing vendors)
Sep 25, 2010 | Dell Y4694 Dell MOTHERBOARD INSPIRON 9300
HAI I FORGET MY BIOS PASSWORDE PLZ HELP ME
Hmm...you might try opening up your laptop (or have someone do it for you if you don't feel comfortable doing this) and taking out the CMOS battery for a couple of minutes. This should reset the BIOS password.
Jan 31, 2010 | ASUS G1 Notebook
BIOS Password
Enter the bios
You should see something that says Administrator Password, hdd password, etc.
Not all bios menus are the same so you gotta poke around a bit.
Let me know if you need any more help or if something is unclear.
Best of luck!
Feb 25, 2009 | Toshiba Satellite M45-S265 Notebook
NEED TO BREAK THE BIOS PASSWORD ON MY SON'S DELL INSPIRON 8500
Usually there is a jumper to clear the cmos which will reset the bios password should be near the battery.
There is 3 prongs the jumper is on 2 you need to move it to cover the one that the jumper is not on.
Either that if there is only the jumper just remove it and then reseat it.
Dec 24, 2008 | Computers & Internet
Bios password
when I was doing some research on my mysterious BIOS password problem with my Toshiba.
Long story short, Toshiba is aware of the problem and has released version 2.20 of the BIOS software which states that they have "Added a workaround for a BIOS password anomaly."
I know this is not the forum to discuss this stuff but felt compelled after the many hours of frustration, diconnects and name-rank-and-serial-number talk with Toshiba Support and Toshiba Customer Service.
Bottom line is that depending on who you talk to a Toshiba or Toshiba Customer Service, they may or may not cover the up to $200 charge for removing a BIOS password..."Toshiba does not warranty software issues". If you have this problem just be persistant until you get ahold of someone who is aware that the problem is real and who will listen. And not that morron who told me "that there is no way a BIOS password can be set without someone setting it"...idiot. They will send an "exception code" to your service provider to do the work under warranty...I mean how can they not if they're aware the problem exist and post a fix on their own website.
I just got my lab top back from my Service Provider for the second time for this problem so I don't have many hours running it to see if it happens again...I've got my fingers crossed. The first time was in July '06 and the updated software didn't come out until Sept'06. So although Toshiba gave me an exception to remove the BIOS password, the software was still corrupt and it happened again in Nov '06.
Dec 17, 2007 | Toshiba Satellite A105 Notebook
Compaq Presario V4000 Notebook Logo
87 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
