Question about Whirlpool Dishwashers
I have a Whirlpool ADG937 dishwasher (9 years old) which will not complete a 65c wash cycle. It starts Ok and runs for a long time but then continually bleeps, when I open the door the programme indicator light is on the rinse cycle. If I reset the programme to 65c it may do the same or occasionally it will finish the cycle. I have tried salt top-up, descaling and filter cleaning all to no avail. Is the programmer faulty (can I bypass it?)or should I replace the washer?
3 Suggested Answers
  • 108 Answers
SOURCE: dihwasher not working
I had a hotpoint engineer try to fix this type of problem.
He insisted that there was something stuck in the bottom of the pump.
Sure enough there was.
1. Unplug your dishwaser at the wall.
2. Remove the grill under the bottom rack.
3. Ensure that the filter is free from food and other obstacles and clean the filter.
4. Before replacing filter etc, get a piece of metal coat hanger wire and care fully insert it down the channel under the filter to free any lodged items. You may also see a small white impleller try to turn this with your finger or the coat hanger wire (this is the info from the engineer!).
5. replace filter and retry a wash.
This routine fixed or machine twice and will hopefully fix yours!
Don't forget to rate me!
fyi
The third time about 1 year later this occured again and even hotpoint gave up as they could not fix the machine. (after multiple visits). I think that the two flashing lights are were a red herring and the dishwasher had a separate intermitten fault. Hotpoint replaced the unit for a mimum charge. Callout + 40
Posted on Feb 27, 2008
SOURCE: My AEG favorit sensorlogic turbo
hey
I just had the same issue done everything you say above with no joy. i then emptied the water that was in the dishwasher that the filter goes into and its now fine.
good luck
Posted on Jul 03, 2008
vickygomar
  • 460 Answers
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
Posted on May 15, 2009
Whirlpool quiet wash plus dishwasher
Sounds like the timer module is going bad. Might be getting moisture on contacts. That would explain why it works one time and not the next.Just trying to help!
Aug 14, 2013 | Dishwashers
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
Dishwasher only runs for 21 minute cycle
I bought and replaced the control board in the door. $145 CAD it took 5 min saved myself $300
May 07, 2009 | Dishwashers
Dishwasher does not complete cyele
Sounds like you might need a new Start button.
Mar 15, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Feb 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Will Not Run
I had the exact same problem. The tech came by and suggested to run the diagnostic cycle to clear up the error. Nice guy didn't charge for the time. He said Whrilpool has a poor software design.
Problem - LED blinks 7 times when the temperature doesn't come up to the degree F required for the wash. This may happen if someone took a shower minutes before starting the dishwasher.
The Tech said, Whirlpool should have allowed a straight forward reset by the customer (instead of disabling the machine for a tech to come by and fix the minor issue).
Here is the solution.
Solution - (is pretty much the same to clear up the other software glitches as well)
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Jan 05, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gold dishwasher gets stuck at 53 minutes left for an hour
Interval 7
Nov 08, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Soap dipenser
Try this... Wipe out the soap dish with white vinegar and a soft cloth.. make sure you get everything off the edges of the door and look for any nicks, blemishes or deformation of the dispenser door to make sure it is not mechanically binding up when it is cycled open. If Ok.. then.. clean your drain filter.. then.. start a wash cycle using the hottest setting ( without any dishes) .. and after about 10 minutes or so.. stop the process and open the door and add in 2 cups of white vinegar.. Let it complete the wash cycle.. When complete..try running a dishless cycle on any setting with detergent ( use about 1/3 less than you usually use) and see if that dispense adequately. If that works, then the next time you load the washer. make sure you don't have anything up against or limiting the door from opening. Hope this helps..
Sep 23, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Whirlpool Quiet Partner Doesn't finish cycle
FIX YA IS A JOKE I WOULD LIKE TO BURY THE ************** WHO CREATED IT!
Jul 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
99 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
