Question about Lexmark Office Equipment & Supplies
Lexmark 5200 series all in 1 it was in storage 2mos som took hme and they had no prob the color inked leaked so i,i cleaned out printer,& traded them in put in new ones and it won't copy at all is there a trick to use to fix this or are there any places that fix primters HOPE YOU CAN HELP
    Problem Solver:
Print qauality problem orange back ground
Posted on Jan 02, 2011
Blue and yellow not printing
Just make sure you are inserting genuine Lexmark cartridges. Lexmark does not recommend the use of refilled, remanufactured or clone cartridges, you might not get the print quality you expect from ink that is specially formulated by Lexmark.
Try cleaning the cartridge nozzles using the Lexmark software installed on your computer instead:1. On your computer, go to Start menu.2. Go to Programs.3. Go to Lexmark 2600 Series folder.4. Select Lexmark Solution Center.5. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean it from dirt and possible clogs.
Should the problem continue, please contact Lexmark Technical Support Center to have your genuine cartridge replaced. They might ask for your receipt so have them ready. If you're not using genuine supplies, please replace your cartridges with original supplies.
Dec 27, 2011 | Lexmark X2670 All-In-One Printer
Colourcartridgenotprinting
If that doesn't help but you're using genuine Lexmark supplies, please contact Lexmark Technical Support for additional assistance, otherwise, please replace your color cartridge with a genuine one.
Dec 12, 2011 | Lexmark X2670 All-In-One Printer
My Lexmark X1270 printer at one time worked, everything was good, then when I put a new color to black will not print any other color or a black color, print only a little pale, almost do not see anything...
Lexmark products work best with genuine supplies. Lexmark does not recommend the use of refilled, remanufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
You can try to clean your cartridge nozzles using the Lexmark software on your computer. From your computer, go to Start menu > Programs > Lexmark X1200 Series folder > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
If that does not help, maybe it would be best to replace your supplies with genuine cartridges.
I hope this helps.
Dec 02, 2011 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
NOT PRINTING COLOR (INK LEVEL GOOD) PRINTS ON BLK/WHITE MODE
Your color cartridge may need some cleaning. If you're using Windows, go to Start menu > Prorgrams/All Programs > Lexmark 2600 Series > Solution Center. Go to Maintenance tab and select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
If problem continues, try to insert a different known working color cartridge to determine if it's a faulty cartridge issue.
Jul 29, 2011 | Lexmark X2690 All-In-One InkJet Printer
Paper comes out blank
Please check your ink levels:
1. Click Start > Programs or All Programs > Lexmark 2400 Series 2. Select All-In-One Center 3. Click Maintain/Troubleshoot. 4. Select Device status and ink levels.
If all ink levels are still good, proceed to cleaning the cartridge nozzles.
1. Click Start > Programs or All Programs > Lexmark 2400 Series 2. Select Solution Center. 3. Click Maintenance tab. 4. Select Click to fix horizontal streaks.
Your printer will begin to print, forcing ink through the cartridge nozzles and clean them. Try to print your file again.
Jun 17, 2011 | Lexmark X2470 All-In-One InkJet Printer
Hello, I have a Lexmark S505 color Printer that is only 8 months old. I use it every day at work. In the last few ,months I have had to replace the ink more often than normal. It tends to tell me ink is...
It may be possible that the printhead is defective. You may call Lexmark Technical Support at 1-800-539-6275 for assistance. You may also log on to www.lexmark.com and click on Support & Dowloads tab to chat or sent an email. You will need your printer purchase receipt and the printer's serial number. This is necessary to obtain warranty service and replacement.
Jun 09, 2011 | Lexmark Office Equipment & Supplies
.i used to have get good bright colored pix but
Try removing the print head again, removing the ink and re-cleaning the print head. Once it has been cleaned leave it to air dry for a few days before returning it to your printer and make sure the ink cartridges are fully clipped in. Let me know how you get on.
Mar 01, 2011 | Kodak ESP 5 Printer
RResetting Cartridges after refilling
Can't be reset. The Lexmark 32 & 33 (and porbably som others) contain a low ink sensor in the cartridge that once activated can NOT be reset. The key would be you have to refill before the low ink sensor gets activated. Don't know at what ink level that is, probably around 1/4 remaining.
Apr 15, 2009 | Lexmark X5250 All-In-One InkJet Printer
Lexmark x3430 need ink cartriage
This is the only information I could find. Didn't your printer come with a black and color ink cartridge? If it did, all you need to do is take the ink cartridge out and write down the numbers written on the cartridge. The only ink cartridge I could positively confirm was the #24 color ink cartridge. The Lexmark website does not list any black ink cartridges for this model. This information was obtained from Officemax.com.
Lexmark - 24 Ink Cartridge - Color
Compatible with Lexmark Z1400 series, X3500 series and X4500 series printers;
Lexmark - 23 Ink Cartridge - Black
Compatible with Z1400 series, X3500 series and X4500 series printers;
Sep 15, 2008 | Computers & Internet
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
