Question about HP Compaq Presario V2000 Notebook
Dvd drive problem
I am using HP pavillion DV6516TX for the past one and half years, window vista, recently my dvd drive is giving me a lot of problem. sometimes the dvd drive could not be seen on the window explorer, it plays a dvd/cd for 15-20 mins and then the drive to stop responding until and unless i manually take out the disc by inserting a pin in the hole in front of the dvd drive. these days while starting up my laptop, it just dont start, black screen with a white cursor blinking, once i open the drive with the same method,the pc starts up, everything is normal except the dvd drive. After starting the laptop, if i close the drive, everything goes slow down. Please suggest something, is the problem is in the drive or in the laptop
  • nirajmeitram Oct 16, 2008
    dear
    thanks for the soluton, i think there might be a better solution than replacing the DVD drive coz sometime it do work with no problem at all, but the last few days it just got worse. someone suggested me that the PC ight be reading the drive at the start up for booting CD, some to reinstalled the drive driver, someone to take out the drive and check the connection, etc. i better do all these things first. if u have any new suggestion, please let me know, actually replacing with a new one will take a big buck out of my pocket which i dont have now. i just think if it just get OK tommorrow morning
  • JDTec
    JDTec May 11, 2010
    It is your DVD drive. Hopefully you have an extended warranty. It needs to be replaced.
    If you don't have a warranty, then it is not that difficult to replace.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
  • 186 Answers
If you want to make sure whether the issue is with the Drive or not, I recommend you to try removing and booting the Notebook without the Drive.
The warranty of the Notebook should not be effected with this and however, your Notebook should be out of base factory warranty.
You can find the required instructions to remove the DVD Drive of your Notebook from the Manual of the Notebook which can be accessed from the link below :
http://h10032.www1.hp.com/ctg/Manual/c01295877.pdf
Look for the instructions starting from page number  59  (67 of 160) in the Manual for the required instructions.
Here is the procedure you need to follow :
Remove the DVD Drive when the Notebook is turned off and power adapter and battery disconnected.
Start the Notebook.
Check whether you have the same performance issues even if the Drive is not connected to the Notebook.
If the Notebook is working fine, just turn it off and reinsert the Drive and fix the screw.
However, if the performance issue exists even if the DVD Drive is not connected to the Notebook, the issue should be something else.
This should also resolve if the issue is related to the connectivity of the Drive as removing and reseating the DVD Drive should solve this.
Hope this helps...
Posted on Oct 18, 2008
  • HP Master
  • 4,338 Answers
I still believe it is the drive. Several months ago, I sent my wife's DV9000 back to HP for repair because of the same problem.
Another thing you can do is to clean the lens. open the drive, then you will see a lens on the tray.
take a cotton swab and dab some alcohol on it and clean the lens. This may help .
Posted on Oct 16, 2008
Can't play DVD on VLC on HP Pavillion dv5 running Vista.
problem with DVD drive, HP has this problem, not only that, Drives for laptop doesnt suit to work long. if under warranty, try to change that as soon as possible.
Aug 12, 2009 | Computers & Internet
HP Pavilion dv6516tx internal dvd writer not writing to blank dvd
you can check the capability of your drive with nero so you know which disk u can write to.
Jun 30, 2009 | HP Pavilion dv6000z Notebook
Missing boot manager
go to system bios (using F10 key on the start "Commanly") then press F9 for restore defaults, and insert the Bootable Vista DVD into the drive, it will solve your prob.. otherwise in bios mode make sure that all the drives (HDD & CD/DVD Rom) are properly installed.
good luck
shafky
Jun 19, 2009 | Tablets & eReaders
I have jvc everio model gz -mg70u unable burn dvd on my pc with
Need software update for vista, go to jvc web site and check for software up dates.
Jan 01, 2009 | JVC Everio GZ-MG21 Camcorder
Hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
try to download belarc advisor software. Run this in your vista OS and send it to me so I can check your hardware specs. This is the only way to avoid problems in the future or before you start the formatting.
Dec 01, 2008 | HP Pavilion dv6000z Notebook
Hp pavillion laptop dv6000
I beleive that the DVD Drive icon had dissappeared from My Computer.
However, I recommend you to check in the Device Manager by clicking the + mark next to DVD/CD-Rom Drives.
If you find any entry under the DVD/CD-Rom Drives, right click on the entry and select Properties.
In the Properties window that opens, check the status of the drive listed under Device Status.
If you find any error message with Drivers, we need to make some registry changes to reinstall the Drivers for the DVD Drive which should solve the issue.
Since you had not mentioned the Operating System installed in the Notebook depending on which the steps to edit the Registry depends, I am providing the steps for both XP and Vista :
Uninstalling DVD Drive Drivers from Registry in XP :
http://support.microsoft.com/kb/314060
Follow the instructions listed under Advanced Troubleshooting to edit the Registry in XP
Better way is to copy the entire link and paste it in the address bar of a new Interner Explorer window and press enter key.
Uninstalling DVD Drive Drivers from Registry in Vista :
http://support.microsoft.com/kb/929461/en-us
You may either find the Upper or Lower Filters or Both as per the instructions provided in the links above. Delete the Upper and Lower Filters which ever you find from the Registry and restart the computer which should solve the issue.
However, if there is no entry of the DVD Drive even in the Device Manager, you may have to remove and reinsert the Drive manually as it can be an issue with the connectivity of the Drive with the Notebook.
You can find the instructions to remove and reinsert the DVD Drive from the manual of the Notebook which can be found from the link provided below :
http://h10032.www1.hp.com/ctg/Manual/c00737799.pdf
You can find the required instructiosn to remove and reinsert the DVD Drive in the Notebook starting from page number 110 of 233 in the Manual.
However, if there are no error messages in the DVD Drive properties window in the Device Manager and if the DVD Drive icon is missing from My Computer window, all you need to do is to try changing the Drive Letter of the DVD Drive from the Disk Management window.
Find the instructions to change or assign a Drive Letter to the DVD Drive in XP from the links below :
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=no&dlc=no&cc=no&docname=lpg40244#N545
http://pcsupport.about.com/od/tipstricks/ht/changedriveltr.htm
Find the instructions to change or assign Drive Letter for the DVD Drive in Vista from the link below :
http://www.tech-recipes.com/rx/506/vista_xp_reassign_change_drive_letters/
http://pcsupport.about.com/od/windowsvista/ht/chdrlettervista.htm
I am sure that any of the instructions provided should solve the issue with the DVD Drive in your Notebook.
Oct 22, 2008 | HP Pavilion dv6000z Notebook
HP Pavillion dv9000 laptop service tag dv9308nr dvd burner
vista or xp?
alot of vista os come pre installed with the software and maybe just a setting you need fixed
Jul 31, 2008 | HP Pavilion dv9000z Notebook
HP Pavillion not reading audio CD
It is possible that this is a drive issue, I've seen drives that one of the optical reader device has gone out, but generally it'e the DVD reader and will only read CD's. It's very rare that the CD reader goes and the DVD reader works. Before you replace drive, if it's only music CD's (you didn't mention program CD's), then update your media player. If it still won't play, then unistall the media player and completely reload it. At this point you can replacse the drive.
Jun 28, 2008 | Computers & Internet
HP Pavillion Laptop Hard drive crashed
Have you tried HIRENS BOOT CD. It is a bootable cd that offers back-up options from a DOS SHELL running from the cd into RAM.
LINK
Click on download, no payments are necessary. Open the rar file burn the ISO file on cd, boot and back-up.
May 19, 2008 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
69 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
