Question about Konica Minolta DiMAGE Z3 Digital Camera
Only works in playback mode
Whewn switched on the camera only recognises the playback mode and does not change at all when the main switch is moved, All the other buttons seem to work fine. The main switch button does not feel any different from normal.
    Sergeant:
  • 306 Answers
If when switching from playback to LCD then Viewfinder and no preview display is visible in either LCD nor viewfinder then the switch is not switching. If the red battery light is on try new batteries as some functions are unavailable with low battery power or connect the AC adaptor to see if power is a problem. Does the menu work? Does the zoom function move the lens? If all is functional in the playback mode then the switch may not be making contact internally. Carefully apply pressure to the switch while slowly moving it between all 3 positions while seeing if any display changes both through the viewfinder and the LCD. If you are technically confident you can open the camera case and try bridging the switch poles with a small screw driver to see if the switch is defective or misaligned. EBay has had DiMAGE cameras listed for 'parts only' very cheap but the Z3 would not merit the cost of a camera repair shop. My last successful bid for a Z6 was $200 2 years ago. My first repair on a digital camera was pretty simple since inside the case is a single printed circuit board with little ribbon connectors that can be reseated at ZIF type connectors. Just be careful, slow and keep track of the screws and parts orientation. Any friend who fixes laptops can help you but a shop will cost you more than the camera is worth. Good luck.
Posted on Oct 15, 2008
My Cannon SD1000 Powershot is stuck on video and will not switch to photo mode.
Could be related to a stuck shutter which is a common problem with this camera. Check that all physical parts are moving and do an unstuck process to free the shutter if this is the issue. See the link for more details:
Do It Yourself Digital Camera Repair
Feb 10, 2015 | Cannon Cameras
Canon powershot only boots in playback mode
You could try to help the lens coming out if you hear the motor trying to. Or hold the camera with the lens downwards to let gravity help as well. Hope that will help. Or the lens mechanism will be faulty and the whole lens needs to be replaced. But such a repair might not be worth it because of the costs and the value of the camera.
Jan 04, 2014 | Cameras
Hi, I have a Canon Powershot A700 digital camera and I am facing a problem with it. The 'Mode Switch' button, which changes the mode from Shoot/Record mode to Play/View mode is not working....
If you have the manual for this camera turn to page 15.
This tells you how to switch between Shooting Mode and Playback Mode.
This is achieved simply by pressing the DISP button.
This button is located below and to the left of the FUNC/SET button.
Pressing DISP repeatedly toggles between Shooting Mode and Playback Mode.
I would suggest you try these steps with your Mode Switch in both positions alternately.
May 20, 2011 | Canon PowerShot A700 Digital Camera
No Manual (instructions) for Jazz hdv178
Press RECORD/PLAY Button to switch from Record Mode to Playback Mode.
The Playback Mode is for viewing and managing movies and pictures as well as listening to voice and
music on the built-in memory or on an optional memory card.
Operation Display Screen
Press RECORD/PLAY Button ( ) to switch
from Record Mode to Playback Mode Main Menu.
• There are 4 options in the Playback Mode, movie,
picture, music and voice.
• Direction Buttons can be used to select the
specific option.
• Press OK Button to view movies/pictures, listen to
voice or music.
Feb 18, 2009 | Jazz DV-179 Digital Camera
Playback function
Unless your an electronics expert, you run a very high degree (89-100%) of probability that the camera will never work again. If your cameras aren't under warranty, than call the canon north america offices, and explain the problem they will more than likely work with you considering this is a wildly popular problem with this specific model.
Oct 23, 2007 | Canon PowerShot SD600 Digital Camera
Camera doesn't work
Sounds like you are in playback mode (Power switch icon is a right pointing arrow). Make sure the power switch is in the "photography mode" the icon looks like a camera.
Oct 01, 2007 | Fuji FinePix S5000 Digital Camera
Fuji Finepix F401 - cannot switch to playback mode
There are no remedial suggestions I am sorry to say. These devices are made in such a way that a 'repair' would not be possible only replacement if under warranty- which this one longer is. 4 years is a good life and technology has moved on now so much that a new camera is going to be the only option.
Sep 25, 2007 | Fuji FinePix F401 Digital Camera
Camera turns off
CCD sensor is faulty and the sound you hear is camera switching off lens after no signal from CCD block is delivered to the main CPU. CCD has to be replaced and should be done free of charge if the camera is newish and has not been abused ( you bought it with poorely manufactured CCD sensor which should last 15 years ).
Jan 06, 2007 | Fuji FinePix S5000 Digital Camera
Playback of my 8 mm tapes on camera
Hello, there can be some contact errors at the flat cables and connectors from the mechanism to the main board. Please contact your nearest Authorized Sony Service. Best regards, Arpi
Dec 13, 2006 | Sony Handycam DCR-TRV530 Digital Camcorder
Can't take pictures or videos
The lens block appears to be defective. If you need this pl.let us know further.
Aug 07, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Konica Minolta DiMAGE Z3 Digital Camera Logo
90 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
