Hawking PN580U Analog Modem
GA-7VRXP - problem with Hawking USB modem
By Phoebe - usenet poster
Howdy
I wrestled too many hours with this one last night.
The problem: a known-good Hawking PN580U USB
modem refuses to work correctly with a Win98 SE system that
has a rev 2.0 BIOS F11 GA-7VRXP motherboard.
The modem won't hold a connection. It breaks off
during username/password checking. Trying to fax
gets nowhere; just can't hold a connection.
I tried it with several ISVs. I tried it with many strange
variations, all related to trying to slow the modem
down and remove compression, in the dial-up networking
settings.
This modem uses some fairly generic USB modem drivers.
Something's not working when it connects to a GA-7VRXP.
I googled around and found that people using the same drivers
with other USB modems had sometimes hit the same problem
(failure to hold a connection), but the instances seemed rare.
Happy to hear of anyone's insight on this matter for now,
I'm just sticking a modem inside the box
Stan Krute
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 27, 2006
Not Rated (0)
Bray
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Oh, yes, and my apologies to thee also, oh
GA-7VRXP, twasn't thy fault, you be one
fine honkin' bigBang4daBux mobo.
Stan
talkin' to hardware again
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on GA-7VRXP - problem with Hawking USB modem:
I don't want to Accept this solution
Solution #2
Not Rated (0)
pawa
Rating: 0%, 0 votes
Aha !
When last I wrote to this thread
I put in a US Robotics 56k PCI modem, a known
works-with-everything-safe-bet.
It exhibited EXACTLY the same symptoms as the
Hawking. Couldn't hold a connection.
Hmmmm
Something must be screwed up in Windows. Norton
Systemworks must've missed the mess.
I reinstalled Win98 SE on top of itself, using
an upgrade CD.
After that, the US Robotics 56k PCI modem worked
flawlessly.
As did the Hawking USB modem.
(Great little modem. Sorry for doubting you.)
Stan Krute
Thank You!
Can you Help with these Modems problems?
Modems
i have followed aol set up for this modem but it fails the...
Modems
i want a driver of my toshiba satellite m35s456
Modems
I am going to buy benq t60 to get gprs modem facility but...
Modems
I can't down load pictures...says on the keychain please...
Modems
Trying to connect to a Arris TM6020/CT moden remotely to a...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
