Double clique on Icon but program doe'nt run. Have tried your solution given under FAQ , but it still dos'nt work.
    Sergeant:
  • 306 Answers
Right click on the icon, select 'Find Target' then see if it leads to real executable, like *.exe, rather than just another shortcut, like *.ink.
Posted on Oct 15, 2008
Unable to install 3.1 in windows7
install the app as admin. then go to the installed apps propereties and tell it to run as a xp app in compatibility mode
How to Use Windows Application Compatibility Mode Published: October 25, 2001
This article describes how to use Windows Application Compatibility mode. This mode provides an environment for running programs that closely reflects the behavior of earlier Windows operating systems.
Using The Windows Application Compatibility Mode
When you use Windows Application Compatibility mode, many of the most common issues that prohibit earlier versions of programs from working correctly are resolved. If you run a program and it does not function as expected, it is recommended that you run the program in one of the compatibility environments.
To run programs in Windows Application Compatibility mode in Windows XP
  1. Right-click the icon of the program that you want to fix.
  2. Click Properties.
  3. Click Compatibility tab.
  4. Click Run this program in compatibility mode and select one of the following options:
    • Windows 95
    • Windows 98 / Windows Me
    • Windows NT 4
  5. Under Display settings, check the mode that you think is necessary for the program to work correctly:
    • Run in 256 colors.
    • Run in 640 X 480 screen resolution.
    • Disable visual themes.
  6. Click Apply.
  7. Click Ok.
  8. Double-click the program icon.
    Note The Compatibility tab is only available for programs installed on your hard drive. Although you can run the Program Compatibility Wizard on programs or setup files on a CD-ROM or floppy disk, your changes will not remain in effect after you close the program. For more information about an option on the Compatibility tab, right-click the option and then click What's This.
Oct 30, 2010 | Primavera Project Planner P3 (PRIMAVERAP3)...
DEAR SIR I HAVE COMPAUTER HP COMAQ DC 7900 I WORK WITH SOME PROGRAM WORKING IN DOS .. THAN I NEED INSTALL DOS OPERATING SYSYTEM THE COMPUTER DON'T RESPON ... ALSO THE COMPUTER DON'T HAVE LPT I BRING CARD...
the best way to do this is probably use windows and run dosbox for windows. What it does is it emulates DOS and lets you run any program that requires dos. Because your computer doesnt have a LPT port. and nowadays only drivers for dos or newer operating systems come with the card. installing the driver in windows then running dosbox, it will see the LPT port.
you can get it here
http://prdownloads.sourceforge.net/dosbox/DOSBox0.73-win32-installer.exe?download
May 04, 2010 | Computers & Internet
I recently had a HD crash and have replaced it with another HD using the same Windows XP OS. While trying to reload programs that were on the old HD to the replacement, some of the programs get this error...
I always receive a "C:\WINDOWS\SYSTEM32\AUTOEXEC.NT" error message.
“C:\WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running MS-
DOS and Microsoft Windows applications. Choose ‘Close’ to terminate the application.”
This error message is not caused by the installation CD-ROM, but rather by the
“Autoexec.nt” system file. Windows is unable to find this file when launching the
installation CD-ROM, the file most likely having been deleted by another application.
To resolve this problem, proceed as follows:
1. Go to “C:\Windows\repair” and find the file “Autoexec.nt”.
2.Copy this file to “C:\Windows\system32”.
3.Right-click the file “Autoexec.nt” that you have just copied, and select
“Properties”.
4.Tick the “Read-only” box and then click “OK”.
Aug 06, 2009 | Microsoft Windows XP Professional SP2 Full...
Opening Wordbiz
Issue
Wordbiz 1.8 does not launch when you run it under vista.
Solution
Just run the program administrator for this:
1. Right click on the icon WordBiz ISC RO
2. Properties
3. Compatibility tab
4. In the Priviledge level section check the box Run this program as administrator.
5. Click OK and restart your application.
http://en.kioskea.net/faq/sujet-3774-wordbiz-isc-ro-does-not-run-on-vista
& we'll sit by the qat and have some za!
Jul 13, 2009 | Microsoft Sony VAIO 3544501 Notebook
Do not know how to install software
How to install a software program can depend on the operating system being used and the program being installed. Because of all the different possibilities, we have created the below steps as guidelines for installing programs in each of the major operating systems.
Notice: This document has been created as a basic overview on how to install software programs, games, and utilities on your computer. If errors are encountered during the installation, this document will not cover those errors.
General Tips
Microsoft Windows 95, 98, NT, ME, 2000, and XP users
MS-DOS Users
General Tips
  • Make sure your computer meets the requirements of the program, game, or utility you are attempting to install.
  • The manuals for the program or the readme file located in the same directory as the install commonly contain exact instructions on how to install a program.
  • After installing or during the installation, a program may need to install other programs, files, or utilities before it is able to run. If this is the case, the program will commonly prompt you to install the program or you may need to run a separate install before the program can be fully used.
  • When installing a program, utility, or game, it is always a good idea first to close or disable any other programs that are running.
  • After installing a new program if it prompts you to reboot the computer, do it.
Microsoft Windows 95, 98, NT, ME, 2000, and XP users Many software programs, games, and utilities have an AutoPlay feature that will automatically start the setup screen for the software program when the CD is placed in the computer. If your program, game, or utility contains this feature, run the installation through the screen that appears after inserting the disc.
If you are installing a program, game, or utility that does not contain this feature or you are installing a program from a floppy diskette, follow the below steps.
  1. Open My Computer.
  2. Within the My Computer window, open the drive that contains the installation files. For example, if the files are on a floppy diskette, open the A: drive. If they're on a CD or DVD open the D: drive or the letter of the disc drive.
  3. Within the drive that contains your files, locate either a setup or install file. Double-clicking on this file should start the installation for the program, game, or utility. If you see multiple setups or install files, try to locate the Application file or double-click each of setup or install files until you find the file that starts the installation. Many times the icons associated with the installation files have the same name.
An alternate method of starting the installation in Microsoft Windows
  1. Click Start and Run.
  2. In the Run Window, type x:\setup or x:\install where x is the letter of the drive you wish to start the installation from. For example, if you are attempting to install a program from the floppy disk drive you would type a:\setup or a:\install.
MS-DOS Users Users installing a program from Microsoft DOS should have a basic understanding of the MS-DOS commands. If you are unfamiliar with any of the commands listed below, click the link to get additional information and examples on the commands.
  1. Before installing a program in MS-DOS, you must switch to the drive and/or directory that contains the installation files. If you are installing a program from a CD or diskette, switch to that drive. Additional information about switching drives in Microsoft DOS can be found on document CH000515. If the installation files are located in a different directory, use the dir command to list the directories and the cd command to switch into the appropriate directory.
  2. Once you are in the directory or drive that contains the installation files, run the executable for the setup. Many times this can be done by typing setup or install at the prompt to start the installation. If both of these commands give a bad command or file name error message, type dir *.exe or dir *.com or dir *.bat. These commands will list any executable files; if any files are listed, attempt to execute these files to run the installation or setup of the program. If no files are listed when typing all three of the above commands, it is possible that either you are in the incorrect directory or drive letter, or that the program.
Additional information about running an file from MS-DOS can also be found on document CH000598.
Additional information:
  • Information about problems that can occur after an install can be found on document CH000123.
  • See document CH000506 for information about how to extract a file that you've downloaded before installing a program.
< Please Rate :) >
Apr 12, 2009 | Computers & Internet
Windows problem
Try this.
Right Click on your DOS program EXE file. Then go to properties and go to Compatibilty TAB. Click in Check Box for Compatibitlity mode and select WINDOWS 95.
Feb 10, 2009 | Computers & Internet
When i am trying to use c++ on my system it is giving me message the NTVDM cpu has encountered an illegal operation
Here is an explanation of what NTVDM is: The NT Virtual DOS Machine (a.k.a WOW, or Windows on Windows), is a Win16 subsystem that runs under Windows NT, which allows 16-bit applications to run as if they were being executed on a DOS machine, with that machine's multitasking and segmented memory model. Because the system is multitasked 16-bit DOS and Windows applications cannot crash NT. However, 16-bit apps within a Win16 subsystem run the exact same way as they do on a DOS/Win 3.x machine; therefore, 16-bit apps within the subsystem can crash one another, or the subsystem. To prevent this, you can launch multiple WOW subsystems as long as your program does not communicate using shared memory. Windows NT will not allow NTVDM to execute instructions that try to directly manipulate hardware or memory locations. As a result, some DOS and Windows 3.x applications (such as games) may not run under Windows NT.
Feb 02, 2009 | Computers & Internet
Program Vista Home Error Message: config.nt The system file is not suitable for running MS-DOS and windows applications.
Hi VincB49,
Without getting too technical what you have is trying to run a 16-bit program in an 32-bit environment. When a 16-bit trys to run in windows 2000 it runs in windows nt dos environment, anyway, try this: Click Start>control panel>system>Advanced- click on "Environment Varialbles"> In the user name for User_Name list click "TMP" and click edit> In the Variables Value box type:
c:\winnt\temp and click OK three times, close control panel. I hope this helps you, if not, hit me back, we have other options i.e. pathway applications.
Thanks for using FixYa.com
Sincerely, cyyyd7
Oct 08, 2008 | Computers & Internet
I need to download a program that requires windows and my computer says the program wont run in dos mode how do i get it to work?
if the program requires windows that means it was design to work with windows and not with DOS.. you may want to get an old version of the program that will actually run under DOS.. usually you may be able to do the opposite which is to run DOS program on windows.
if possible try to get a DOS version of the program you are trying to run, or better.. upgrade your operating sytem so you can run your program and possibly other DOS programs.
post the program you are looking to download and confirm what operation system you're running and I'll try to look for it with you.
Sep 27, 2008 | Acer Computers & Internet
Not working
Do a file search for cmd.exe and then you can create a shortcut on your desktop pointing to it and then in double quotes put the location of the application you are trying to execute, ie.. It should be located on c:\windows\system32 - cmd.exe
C:\WINDOWS\system32\cmd.exe - in Properties Target and put this in double quotes and then your application with the full path in double quotes after that.
Jul 26, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
