Home | Honeywell | Power Humidifier: Furnace Humidifier/ Hum... | Honeywell Chr...
Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Problem for Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Honeywell Chronotherm III problem
By pandamama - usenet poster
For the last couple of days, the thermostat has been displaying on and off
something like
"737 -AC"
insted of the usual display of the current temp.
At the same time, it has NOT been heating up the house properly
I changed the batteries and tested the old ones. But they were fine.
So are the new ones
And yet, the heating system does not seem to be getting the house up to
comfortable temp
And I'm not sure if it's the furnace controls or what ?
I am presuming that this is some kind of error code
I have the user's manual, but it's pretty sparse about troubleshooting and
and totally empty about error codes.
And I'm not even sure if it's the furnace or the thermostat
Any help would be appreciated.
Same Problem
Mar 14, 2009
-   Just had to change the batteries and then, of course, had to re-program. Everything went as it should, until I hit "run program." Screen shows correct time, date and the dreaded "-AC" Don't think the furnace is working.-   sgardner035
Dec 18, 2007
-   I HAVE THIS SAME PROBLEM IS THERE A FIX
-   macme
Dec 18, 2007
-   I HAVE THIS SAME PROBLEM WHAT DO I DO-   Guest
Best Solution
posted on May 27, 2006
Very Helpful)
lawyer
Rank: Apprentice
Rating: 0%, 0 votes
Most of the time if it says "AC" that means the thermostat is not getting
power. If the furnace is coming on, then I don't think that is the problem.
Make sure the metal "clips" that make contact with the batteries are clean.
If they are AND you put in new batteries, you may want to think about
getting a new thermostat...
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Helpful)
Gary10
Rank: Apprentice
Rating: 0%, 0 votes
Just to respond, I took the time to clean ALL the contacts that I could
reach, not just for the batteries, but those also that connect 5the
thermostat to the wall bracket (and wires to the furnace).
Thinks look OK, and have not had any error codes since.
So you may have hit on the source of the problem
Ultimately, I would like to make some changes to the system anyway.
So, this is a motivator to start looking at the how of it.
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
herself
Rank: Apprentice
Rating: 0%, 0 votes
Yeah, he's like this a lot.,
I don't know your thermostat, or what is wrong, but as more and more
people have fancy therimostats, and it's cold out, maybe someone who
knows this stuff could give a backup procedure for bypassing the
thermostat entilrely on those nights and weekends when they find it
not working.
That is, all the thermostat does iirc is connect or not connect one
set of two wires (that turn the fan on as opposed to automatic) and
two of three wires (either the Heat and the Ground, or the AC and the
Ground) Nice people here have explained this already, and maybe if
one googled for "thermostat furnace red black green yellow**" one
could put together a set of rules for getting through the night.
(Well, I wouldn't let it run *all* night, but you could warm the place
up to 72, turn it off, and get up again when it was 62..
**or whatever the colors are
IIUC, there is no emergency need to have the fan be on anything but
automatic, so that just leaves 3 wires to fiddle with, and one is for
AC. Leaving just two wires. They can be jumpered at the thermostat
or at the furnace (without disconnecting the thermostat I think) Come
to think of it, you could probably take the thermostat out of any
space heater***, and use that in your jumper. Then you could get a
good night's sleep. OR you could install the thermostat you removed
from the wall when you put this one in. You saved it, I hope.
***Make sure you don't use one from a fan. They look the same but
work backwards.
Also I wonder about the -AC code being related to the batteries in the
thermostat, since batteries are DC. Car companies give out the codes;
it would be nice if thermostat companies did too.
Remove NOPSAM to email me. Please let
me know if you have posted also.
Was this helpful?
Yes
No
Solution #4
Not Rated)
Reynolds
Rank: Apprentice
Rating: 0%, 0 votes
I'm looking at putting thermostats and presence sensors to drive motors on
the duct outlets, so that more (warm or cold) air goes to occupied rooms.
And unoccupied rooms are less well provided.
Also program into them whenever they are in high use.
Eg Bathrooms kept warmer in the evening before bedtime.
Setback if house empty but crank up the heat just before people come home
So I'll probably have to look at X-10 and similar systems.
Probably dedicate one of my old laptops with an older version of LINUX to
actually run the logic.
Was this helpful?
Yes
No
Solution #5
Not Rated)
pawa
Rank: Apprentice
Rating: 0%, 0 votes
Read up on the different thermostats and their functions. I am partial to
Honeywells. I know they are always improving their technology, but I wish
they would have kept the Chronotherm line. I'm about ready to change mine
with one of their touuchscreen models:
Was this helpful?
Yes
No
Solution #6
Not Rated)
kcw573
Rank: Apprentice
Rating: 0%, 0 votes
That's an excellent signature that describes you to a "T".
Clearly you should look in your mirror to see a TRUE asshole, large
enough to pack a container ship
Now, although I won't bother reading it, I'll let you have the last word
I have better things to do with my time.
<plonk>
Was this helpful?
Yes
No
Solution #7
Not Rated)
Powe33
Rank: Apprentice
Rating: 0%, 0 votes
My home is NOT turning into an icicle for a bunch of reasons
1) I have one gas-fired fireplace which runs at nearly 90 % efficiency
and can keep my house warm at a comforatble 68 degrees as long as the
natural gas flows.
2) I have another wood-fired fireplace in the basement which can also
heat all 3 floors of the house without much problem. And I also have 3 FULL
cords of wood, well seasoned and ready to burn. to keep me toasty well into
next fall, where I to so choose
3) I also have 5 20# tanks of propane, that are filled to capacity and a
propane heater that can keep the whole house, if not toasty, at least
comfortable for over a week. Where everything else to fail
The furnace just happens to be more efficient than my backups. Although not
by much
So I can actually survive till spring if I so choose and only use the
furnace to filter and circulate air to keep the house evenly comfortable.
So what exactly where you assuming, like the solid ass that you are ?
Nah !
Don't bother aswering.
Whatever you may respond is just not worth my time.
But thanks for playing and demonstrating that without a doubt, you truly are
a GREAT horse's ass packed full of shit.
<plonk>
Was this helpful?
Yes
No
Solution #8
Not Rated)
kcw573
Rank: Apprentice
Rating: 0%, 0 votes
The motivation to respond is so assholes like you will write that kind of
crap.
Serious problem? So if it's that fucking serious, why not call someone in to
repair it???
Asshole
Was this helpful?
Yes
No
Solution #9
Not Rated)
Mini Me
Rank: Apprentice
Rating: 0%, 0 votes
One has to wonder the motivation of morons who respond with such nonsense to
what is a serious problem when the outside temperatures are around 0F
without the wind chill factor.
You give bubba's a bad name, guy
Get a life
Was this helpful?
Yes
No
Popular Solutions for Honeywell Power Humidifier:
Questions and Unsolved Problems for Honeywell Power Humidifier:
Do you recommend Honeywell Power Humidifier: Furnace Humidifier/ Humidifier?
Answer
Answer
I have one humidistat honeywell H8908B which presently controlls honeywell humidifiers(HE440A ). I... (More)
Answer
I am getting six blinks on the call for service light after I push the reset button.What does that... (More)
Answer
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate... (More)
Answer
"replace better" msg light came on; I replaced with 3 AAA Alkalines...3 days later, same... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Honeywell Power Humidifier:...:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
