Question about D-Link DI-624M Router (DI624MRE)
I can't connect to wireless
The Device Status for the Wireless shows MAC Address
00-00-00-00-00-00. In addition the WLAN light not flashing. I have rebooted, updated firmware and all the normal troubleshooting. I'm thinking there is a problem with the router. My DI 624 worked fine. I'm upgrading!
  • 34 Answers
Looks like a firmware corruption. try running a firmware update from http://support.dlink.com/products/revision.asp
Posted on Oct 15, 2008
My print server cannot be reset to the factory default for some reason. I have tried holding the reset button for 10 secs, but without luck.
I have some devices where I have to hold the reset for 20 seconds. So try holding it longer. And make sure the print server is powered up when you do it.
Feb 17, 2016 | Belkin (F1UP0001) Print Server
Tip
How to Install WG111v3 on MAC OS 10.3 , 10.4, 10.5
<p>The below article would illustrate the steps to install the NETGEAR wireless adapter WG111v3 on MAC OS 10.3, 10.4 and 10.5.<br /> <p><br /> <p>Please ensure that you have installed the latest version of driver for the adapter from the below link on your MAC OS computer:<br /> <p><br /> <p><a href="http://kb.netgear.com/app/answers/detail/a_id/2640">http://kb.netgear.com/app/answers/detail/a_id/2640</a><br /> <p><br /> <p>After the installation of the driver please perform the below task:<br /> <p><br /> <p>1. Plug in the adapter.<br /> <p>2. Double click on the NETGEAR WLAN Client Utility in the desktop.<br /> <p>3. On the NETGEAR WLAN Client utility select the Available Network tab which will detect the wireless network, select your network and click Connect.<br /> <p>4. If you are connecting to a secured wireless network then you will be prompted for a Wireless Network Security Properties menu.<br /> <p>5. Type the network key WEP/WPA security and click OK.<br /> <p>6. Click on Link Status which shows the connection as connected.<br /> <p>7. Check for the IP address by clicking on the Apple icon and select System Preference.<br /> <p>8. Click on Networks and check the IP address.<br /> <p><br /> <p>You should have succesfully established the wireless network on your MAC.
on Mar 24, 2011 | Computers & Internet
Can you connect several n300 routers
Connect a computer to one of the Belkin's "LAN" ports with an Ethernet cable.Open a Web browser and enter "192.168.2.1" into the address bar. Press "Enter."Click "Login," then click "Submit."Make a note of the WLAN MAC address on the Status page.Click "Wireless Bridging" under the "Wireless" category.Click to check the two boxes "Enable wireless bridging" and "Enable only specific access points to connect."Type the MAC address of the Belkin router and the MAC addresses of the other wireless routers or access points that are participating in the bridged WDS network. If using Belkin devices, repeat the previous steps to obtain the WLAN MAC addresses, otherwise refer to the owner's manual of the wireless device to find the WLAN MAC Address.Click "Apply Changes" to save the settings.
Nov 19, 2011 | Belkin Wireless Surf Router (F7D2301)
2 routers, same WLAN MAC addresses.
First of all, two wireless devices cannot have the same WLAN MAC address. Its like a fingerprint. In this rare case, as you do have it that manner. You can TRY to connect both routers using wireless bridging and check the MAC address (if different) of the router on the DHCP client list. If its the same, this feature will not work. With this. if we confirm its an issue with WLAN MAC address, as it can also be a printing mistake. You can go ahead and request for a replacement from US Robotics and bring this to their notice. Moreover, its not possible to spoof or clone the MAC address present of the network adapter of a router.
Thanks and regards,
Arvind
May 15, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
Hello Sailorgreg,
mac addresses are supposed to be unique addresses for each and every wireless network device.
There is no way to change or modify a mac address as it is programmed into the actual network adapter.
If you have purchased two different routers and they have the mac address for both, I would recommend trading one of them in because this would be a defect.
Thank you,
Pat
Mar 26, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
Limited or no connectivity
hi,
welcome sir,
what i can suggest u is that just reset the router and then install the wireless driver into ur computer and then try and connect to wireless network and hope u will be connected......good luck....
pls rate this solution..........pls...thanks
Feb 12, 2009 | Adapters.com PLANET USB WLAN...
Wireless card in E1505 Dell not finding networks in range
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
Feb 03, 2009 | Dell Inspiron 1501 Notebook
Dpr-1260 onkly works when connected by ethernet cable
dpr-1260 searching for ap and connected keeps changing back and forth when I refresh.On dpr-1260 if status of wireless keeps changing from searching and connected, change wireless to WPA, instead of WPA2. even if you have WPA2 setup (as I did), if you choose WPA it will stay connected.
Jan 23, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
D-Link DI-624M Router (DI624MRE) Logo
230 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
