Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Problem for Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Replace Honeywell IFC board? - no power to igniter
By Putty - usenet poster
replace Honeywell IFC board? - no power to igniter
12 year old Rudd Deluxe 90 Plus gas furnace at my home won't ignite.
Induced draft motor keeps running. No power to igniter no matter how
long I let furnace run. I traced the problem to the white wire into
the igniter. It's not providing the power or ground to the igniter.
The ignitor's black and white wires plug into the IFC circuit board.
Troubleshooting guide says to make sure vent is open (it is), then to
make sure air proving switch is working and is closed (I don't know
where it is or how to test it), and then to replace IFC. Should I just
go ahead and replace IFC? This will be the second time I've replaced
the IFC board. Is that typical? I would appreciate advice on where to
buy the IFC board - Honeywell MPLS MN55422. How much should it cost?
I'm in metro Detroit, Michigan area. Thanks for your advice. Michael
Same Problem
Dec 06, 2007
-   Yes, I have the same problem and the repairman doesn't know where to find the replacement.
C Lape-   Guest
Solution #1
posted on May 27, 2006
Somewhat Helpful)
Green1
Rank: Apprentice
Rating: 0%, 0 votes
Typical.
Could be a few things...
Stop now..call a tech..
And if its a $4 part thats actually bad???
Very
You cant. Rheem will not sell to a homeowner...at least not here.
Also, if the board isnt the problem, you can forget returning it.
Also, the new board looks nothing like the old one, requires a couple of
rewires, and cant be returned.
Dunno what the average labor rate is in your area, but around here, expect
between $175 to 290, depending on the dealer.
Was this helpful?
Yes
No
Solution #2
Not Helpful)
Brad
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the advice CBHvac. I got one web price of $220 for the IFC
board. I'm going to call the same furnace tech that installed my
furnace about 10 years ago. He gave me the second board for a much
lower price about four years ago, when my first board went. It was
used stock, but worked. I replaced it myself and that got the furnace
working again. This time, the furnace quit working after I replaced
the Spaceguard pleated air filter. I let the furnace run a day
without the filter (the old one was dirty, and I went to buy a new
one), but don't see how that would affect the furnace. Is it just
coincidence that the furnace quit working when I worked on the filter?
I didn't open either furnace panel before it quit working. Both
lights on the IFC are on. Thanks. Michael
Was this helpful?
Yes
No
Popular Solutions for Honeywell Power Humidifier:
Questions and Unsolved Problems for Honeywell Power Humidifier:
Do you recommend Honeywell Power Humidifier: Furnace Humidifier/ Humidifier?
Answer
Answer
My honeywell chronotherm iii display shows time and then it says -AC. Doesn't seem to turn on.
Answer
I have one humidistat honeywell H8908B which presently controlls honeywell humidifiers(HE440A ). I... (More)
Answer
I am getting six blinks on the call for service light after I push the reset button.What does that... (More)
Answer
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate... (More)
Answer
"replace better" msg light came on; I replaced with 3 AAA Alkalines...3 days later, same... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Humidifiers Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
