Question about ECS 945GZT-M (V1.0) Motherboard
I cannot install my OS because the monitor is saying that the computer stopped responding, there are choices like safe mode, safe mode with networking, safe mode with command prompt , last known good configuration , start windows normally but after clicking all the of them , my pc keeps on restarting and the speed of the CPU fan is not normal .there is this glimpse of the windows xp logo but after that I'm having the same result ... Please help me with this...
  • jetszkie Oct 17, 2008
    i have the same problem. exactly similar
  • 147 Answers
In witch point of setup installation is interrupted your pc
if you make a new setup windows? if you are not making new setup windows but trying with the version that you have installed .... hhmmm try to delete this setup and make another one because , there is somme problem in your windows and this is too much complex to explain but probably from viruses or driver installed wrong or from your defektive copy of setup windows that you have if you proved too many times
Posted on Apr 06, 2009
System stops working until reboot
Step 1:
You might have a virus or malware or it could be a hardware issue
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials if this fails you might have to go back into safe mode you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. other than that you might need to do a format and then re install your operating system
Feb 23, 2013 | HP Compaq Presario CQ57-229WM Notebook PC
My monitor is not loading. Video card has been replaced twice system boots up fine. Have read the ASUS P5QL motherboard Manual and have looked at the Jumpers not sure what the issue might be
your monitor might be faulty
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
select enable the vga mode
if still no luck
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
Apr 02, 2012 | ASUS P5QL PRO Motherboard
How can i fix a hard drive
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
hope this helps
Dec 22, 2011 | Seagate Computers & Internet
Hello! my problem is i have my laptop connected to an external monitor, due to the screen being cracked. I am not sure if that is relevant, but anyways, one day i turn on my laptop and a notice saying...
What I would recommend to do is while you're in safe mode, download the most recent version drivers for your card, then uninstall your current drivers. You can usually access them through remove and add programs/uninstall programs from the Control Panel, or if they're not there, through the Device Manager which you can access from the Control Panel as well. (Or through System if you're on an older OS). Then try to reboot in normal mode. It should work, and you can install the newest drivers from there. If it doesn't work, try to install them from safe mode.
Dec 14, 2010 | Computers & Internet
I have a LG E300 notebook and once i switch it on it responds for a while and then freezes, then changes to blue screen saying: Problem occured so windown has shut down to prevent damage: After few hours...
It can be caused due to any driver clash or antivirus . With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Jan 26, 2010 | LG X-Note LM50 Notebook
No Software from disk will not load using Vista
hi, i guess your os is definitely corrupt. in such case i advice you do a clean forma of the os. just back up your files and then format it with the os installation cd
Jan 23, 2010 | Computers & Internet
My computer says windows did not start sucessfully
go to safe mode and create new user account, and try again....
if it doesn't reinstall the OS..
Jul 30, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Toshiba, when i start the computer. it says toshiba tempro accounted a problem, computer logging of, and then it shuts down.
There are a myriad of problems that could have resulted in this.
1. A virus has shut down your system
2. Memory has gone bad
3. Last software you installed has corrupted the hard drive
Possible solutions:
1. When it is coming up – hit F8 (over and over again) till the menu comes up :
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
See if you can get in safe mode. IF NOT – repeat these steps, and instead of clicking on Safe Mode – Click on “Last Known Good Configuration”
IF THAT does not work:
Insert your recovery CD and see if you can boot up to that.
If THAT still does not work, you have a hardware problem, either memory chips (RAM) or your Hard Drive.
Jul 17, 2008 | Computers & Internet
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
ECS 945GZT-M (V1.0) Motherboard Logo
83 people viewed this question
Top ECS Computers & Internet Experts
David
David
WTF Chuck.....
WTF Chuck.....
Coss
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
