Question about Philips GOGEAR SA6045 MP3 Player
Can't copy JPG file from PC to gogear Model SA52XX
They said the JPG's file has one or more properties outside of device limits.
When I click yes to all and I lost the videos, songs, pics.
Please help.
Thanks
Hilla
hilla.ariti.ext@nsn.com
  • Anonymous Jan 28, 2009
    same to me! but videos, bloody stupid
  • 8,596 Answers
There is a spec sheet at the back of the manual - it will tell you exactly what resolution the jpgs have to be in. For now, your DB has become corrupt by having unsupported files in it. To resolve the corruption issue:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
I have recently bought a Phillips gogear 8g mp3 player and I just want to ask (since I don't have a cd software or a manual that came with the product) how do I add songs into my mp3?
you can simply use drag and drop method to transfer music from your computer to your MP3 player. You can also use Windows media player 10 to transfer music. Make sure to use version 10,. Version 11 doesn't work.
Transfer music via Windows Media Player 10:
1.Hook up your GoGear to the PC via the supplied USB cable.
2.Plug your GoGear into a power outlet with the supplied AC adapter/charger.
3.Launch Windows Media Player 10.
Note: Once the device is connected to the computer, all audio or radio playback will stop.
4.Check and make sure that the Create folder hierachy on device option is enabled in Windows Media Player. Go to Tools>Options. Select the Devices tab and then highlight GoGear Audio and click Properties
5.Click "OK" to close the windows.
6.Click the "Sync" tab.
7.In the "Items to Copy" pane, from the drop-down list, click the playlist, category, or other item that you want to copy.
8.Click the check boxes next to any files you want to copy.
9.In the "Items on Device" pane, from the drop-down list, click on PhilipsGoGear for where to copy files to.
10.Click the "Start Sync" button.
11.The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
12.Repeat steps 2-5 for any other items that you want to copy to your portable device.
13.Once the transfer is completed, close Windows Media Player.
14.Unplug the GoGear from the PC and enjoy the music on your GoGear.
Ok, you can download all the software and drivers from this link:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=US&slg=AEN&sct=HDD_AUDIO_JUKEBOX_SU&cat=MP3_MEDIA_PLAYERS_CA&session=20110319225449_121.241.4.111&grp=SOUND_AND_VISION_GR&ctn=HDD1830/17&mid=Link_Software&hlt=Link_Software
Hope this helps.
Mar 19, 2011 | Philips GoGear HDD1830 MP3 Player
How can i get itunes to download on my phillips gogear 4gb?
  1. Hook up your GoGear with the PC via the supplied USB cable.
  2. Make sure you connect your GoGear micro also to the main power supply.
  3. Launch the version of Windows Media Player 10.0 installed in your computer. Note: Once the device is connected to the computer, all playback or radio will stop.
  4. Check and make sure that the Create folder hierachy on device option is enabled in Windows Media Player. Go to Tools>Options. Select the Devices tab and then highlight GoGear Audio and click Properties
    Click OK to close the windows.
  5. Click Sync.
  6. In the Items to Copy pane, in the drop-down list, click the playlist, category, or other item that you want to copy.
  7. Click the check boxes next to any files you want to copy.
  8. In the Items on Device pane, in the drop-down list, click to select PhilipsGoGear to copy files to.
  9. Click the Start Sync 051028091952_1760.gif button.
  10. The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
  11. Repeat steps 2-5 for any other items that you want to copy to your portable device.
  12. Once the transfer is completed, close the Windows Media Player
  13. Unplug the GoGear from the PC and enjoy the music on your GoGear.
Transfer music via Windows Explorer:
Note! You cannot transfer pictures via Windows Explorer, for pictures use Windows Media Player.
  1. Connect your GoGear with the PC via the supplied USB cable. Make sure you connect your GoGear also to the main power supply.
  2. Launch Windows Explorer.
  3. Drag and drop your music files into the music folder of your GoGear.
  4. Once transfer is complete unplug the GoGear from the PC and enjoy the music on the go.
Jun 10, 2010 | Philips GoGear Flash MP3 Player
How to download music from computer to my philips gogear audio player
  1. Hook up your GoGear to the PC via the supplied USB cable.
  2. Plug your GoGear into a power outlet with the supplied AC adapter/charger.
  3. Launch Windows Media Player 10.
  5. Click "OK" to close the windows.
  6. Click the "Sync" tab.
  7. In the "Items to Copy" pane, from the drop-down list, click the playlist, category, or other item that you want to copy.
  8. Click the check boxes next to any files you want to copy.
  9. In the "Items on Device" pane, from the drop-down list, click on PhilipsGoGear for where to copy files to.
  10. Click the "Start Sync" button.
  11. The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
  12. Repeat steps 2-5 for any other items that you want to copy to your portable device.
  13. Once the transfer is completed, close Windows Media Player.
  14. Unplug the GoGear from the PC and enjoy the music on your GoGear.
Note! You cannot transfer pictures via Windows Explorer, for pictures you need to sync them using Windows Media Player.
  1. Connect your GoGear to the PC via the supplied USB cable.
  2. Connect your GoGear into a power outlet with the supplied AC adapter/charger.
  3. Launch Windows Explorer.
  4. Drag and drop your music files into the Media/Music folder of your GoGear.
  5. Once your music has been transferred to your GoGear disconnect it from your computer and you are ready to listen to your music.
if this it was helpful rate my solution and vote me thanks
Jan 06, 2010 | Philips GoGear HDD1830 MP3 Player
I have philips gogear sa52xx ipod and i lost the cd and also bluetooth is not workin i cant transfer any songs from mobile which i could do previously
Go for a search in next list, viewing the GoGear SA52xx models:
http://www.search.philips.com/search/search?h=all&o=support&l=global&s=all&q=GoGear+SA52
Select your exact model from the list for support.
In the matching support link all downloads will show up.
When having a model not listed, change the words in the bar for another search.
Need more help ? Just add a comment.
Jan 02, 2010 | Philips Audio Players & Recorders
Cannot delete playlist folders on my gogear
My gogear SA52XX wont show the names of the songs
Jun 12, 2009 | Philips GOGEAR SA6045 MP3 Player
My Philips SA52xx GoGear MP4 Player won't start up. It just starts starting up and freezes on GoGear, it also makes wierd crackling sounds when playing music... My Philips GoGear used to start up within 10...
if it has too many songs on it try deleting some of the songs off the player, and if thats not the case, stop using it for a few days then try to turn it on again
May 31, 2009 | Philips SA3125\02 MP3 Player
My philips gogear SA52XX won't play videos.
what video format is requird for my phillips gogear model sa52xx?
Apr 28, 2009 | Audio Players & Recorders
Lost all memory on hard drive
Once it's gone, it's gone.
You can try loading the firmware update from Philips website, but this is unlikely to resolve.
Philips HDD – Reloading the Firmware Hack
1. Plug your GoGear HDD into the computer
2. From ‘My Computer’ right click the GoGear drive and format it. Be SURE you format it as FAT32 and quick compression is not on
3. Create 3 folders on the newly formatted disk called: ‘_System’ , ‘Data’ , ‘Media’
3. Download fom Philips the latest Device Manager for your kind of player
4. Install the Device Manager
5. On the Desktop, right click the Philips Device Manager shortcut, then Properties, then open file location.
6. Copy the folders you see there into the ‘Data’ folder
7. Copy the Firmware.ebn file into the ‘_System’ folder
8. Unplug the device and now it should run fine
-Tha Mp3 Doctor
Oct 16, 2008 | Philips GoGear HDD1830 MP3 Player
Problems putting ANY videos on Philips GoGear SA6045
Install and run the Media Convertor software from the product CD and follow the on-screen prompts. This will convert the video file to a .WMV file of the correct resolution for the player, and allow you to transfer the video to the player.
If this doesn't work, check that the original video format is supported by the convertor software.
Feb 19, 2008 | Philips GOGEAR SA6045 MP3 Player
I need Help
I would recommend you to get the firmware upgrade on the device..that usually happens when your device firmware is corrupted...If after you done a firmware upgrade your device doenst work properly contact the manufacturer...
Thank You
Computerrep
**Rate accordingly..
Jan 01, 2008 | Philips HDD1630 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
703 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
