I have a problem while connecting my phone as modem to use internet ?
Please Suggest me how to give the commands in hyper terminal
My screen shows AT Command Interpreter ready
then i type "at cgatt" then press the enter ,
then it says ERROR
Regards
Sathish
Please Suggest me how to find modem for this type of laptop computer ( Fujitsu FMV5MTBL3)
Posted on Oct 16, 2008
I am using samsung 3g metro gt-s5350 with MTNL sim. I am able to surf the net on the mobile but not able to use it as modem for using internet for my laptop. It is showing "os error, remote device...
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link)
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio
Nov 08, 2010 | Samsung Modem Configuration Software...
How can i communicate from my pc to the ups on the 9 pin serial connection
Taken from the MGE UPS SYSTEMS, Network Management Card Installation manual (34003641EN/AD)
Run Hyper Terminal on a PC running Windows (9x, Me, NT4.0, 2000 or
higher).
Connect the card to the PC using the cable supplied.
Set up the terminal with the following communication parameters:
9600 bauds. 8 data bits.
1 stop bit. no parity.
no flow control.
ASCII: "echo typed characters locally" option disabled.
Press the Carriage return key. The configuration menu is displayed.
Enter the password (MGEUPS by default).
The main menu is displayed.
Select one of the items in the configuration menu.
Via the serial link or Telnet
Select the "Agent configuration" command by entering 1.
Select the item numbers and modify all the IP parameters (address, mask, gateway).
Once all the modifications have been made, exit following the instructions on the screen.
Restarting the card Via the serial link or Telnet
Select the "Restart agent" command by entering 6.
Then follow the instructions on the screen.
Restoring the default parameters Via Telnet or Hyper Terminal
Select the "Reset configuration to default" command by entering 5.
Nov 05, 2010 | MGE UPS Galaxy 3000 UPS System
How to configure Tata Photon Plus with Red Hat Linux 3
linux connectn
1st log in the root user
connect the usb modem
run terminal in linux
type following command
wvdialconf /etc/wvdial.conf
wvdialconf will detect the modem
nano /etc/wvdial,conf
jus replace dis wid defaulf setting
modem-/dev/ttyusb0
baud=115200
dial command=atdt
baud=115200
dial command=atdt
init1=atz
init 2=at+crm=1
flow control=hardware
username=internet
password=internet
phone=#777
stupid mode=1
aftr dis open terminal type wvdial &press enter
if u want to disconnect den press clt +c
kindly revert if u need any help
if ur using tata photon + then plz check properly der is a inbuilt software in photon modem if u cant find den follow dat above method
Feb 05, 2010 | Red Hat Enterprise Linux ES 3 Standard...
I want the driver for huawei fwt wireless modem
I'm giving you two links to download the drivers for Huawei fwt wireless mode
1- http://www.openpages.info/huawei.html and
2- https://answers.launchpad.net/ubuntu/+source/wvdial/+question/43266
You will probably need to edit the wvdial.conf file a little so that you are using the right connection parameters for your internet service.
If those URL's did not help, please follow this procedure:
Step 1: Open Terminal from "Applications->Accessories->
Terminal"
Step 2: Run the following commands (copy-paste each line below to the Terminal then hit <enter> after each line)
ifconfig
sudo lshw -C network
lspci -nn
lsusb
uname -a
dmesg | grep USB
Step 3: Post results (cut/paste terminal output from each command) here
Step 4: Provide us with the full model and make of Huawei modem. What is the exact model number? Does it connect to the PC using a serial-to-USB converter?
Apr 19, 2009 | Computers & Internet
Using tata indicom usb modem in Ubuntu
linux connectn
modem-/dev/ttyusb0
baud=115200
dial command=atdt
baud=115200
dial command=atdt
init1=atz
init 2=at+crm=1
username=internet
password=internet
phone=#777
stupid mode=1
Dec 09, 2008 | Canonical Ltd. Ubuntu
MOTOROLA W230
I HAVE SOLVED THIS PROBLEM. before installing this driver uninstall all motorolla driver. and install only charging driver.
after then install the driver file named 'moto_w230_gprs.inf' (available on internet) on same port on which charging driver is installed yhen write the code" AT+CGDCONT=1,"IP","INTERNET" in extra initialization string on modem. (internet is access point network) use another if u have other networks
set the baud rate of ur modem 230kbps
write the user name andf password
and fone number '+cgdata' without quotes and then try
i have cheked on telenor pakistan its working fine
Best Regards
Engr. Tarique R. Memon
Aug 05, 2008 | Computers & Internet
Help me plz
cisco routers make use of an IOS software for configurations.
you have to connect the router to a computer system through an hyper terminal program in order to access the router command interface,there is no way you will be able to configure this router without having cisco configurations knowledge.
the steps could be complex/complecated for a novice.but all the same,
after running the hyper terminal program on your computer to connect the router(start-accessories-communication-hyper terminal) make sure you use cisco serial cable or a cat5e roll over cable.
press the enter key once and type 'enable' then press enter,
configure terminal,to take you to a global configuration mode.
i will advice that you should contact a cisco person in your area for help
Apr 23, 2008 | Cnet CN UM56-RS (CNUM56-RS) Modem
GRRS Setting Using Reliance Smart
cant connect to internet
extra initialization command needed
MTKBTDEVICE (chinees mobile)
vignesh.a@kotak.com
plz help
Apr 20, 2008 | Computers & Internet
192.168.1.1 unreachable
you can use the "ifconfig -a" to see the ip addresses of all network adapters. but i'm wondering what happened to the user interface that showed a list of options to choose from.
Mar 15, 2008 | EnGenius EOC-3220 (EOC3220)
Internet connection
start your machine and go to hyper terminal.START, ALL PROGRAMS, ACCESSORIES, COMMUNICATIONS in here type your server's phone number. if your modem is working it will try to connect with hyper terminal and if a connection is made, will ask you for your password. this will verify that the modem is ok. if this works, then re-install your modem's drivers and reconfigure new internet connection.
Dec 28, 2007 | Dell Dimension 2350 PC Desktop
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
