I have a problem in my system when i try to playany song this it what it says . windows media player cannot play the file because there is a problem with your sound device ther may not be a sound device installed on your computer it may be in use by another program or it may not be functioniy properly.
I have formatted my hard disc. Now after installing the windows 2003. I found that there is no sound device installed message coming when trying to star any sound device.
kindly advice.
[email protected]I have formatted my hard disc. Now after installing the windows 2003. I found that there is no sound device installed message coming when trying to star any sound device.
Uninstall your drivers the FT Pro or go into My PC - View System Info - Hardware - Device Manager - Sound, Video and Game Controllers. Select the FT Pro and update the driver. It should connect to the 'www' automatically. Restart your pc.
Uninstall other audio software and try to install each audio software one at atime and test it out before install another software. Windows media is not the best audio software, but it should pick up any of the audio media.
Are you using Windows Media Player? If you are, there are some file types that Windows Media Player doesn't support. I would suggest trying VLC Media Player. It's an open-source, free program. I've never encountered a media file it couldn't handle. Here's the link: http://www.videolan.org/vlc/
I hope this helps!
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
Often this is indicative that the "filing system" and the "table of contents" of the digital media player is being messed up. Technically, this would refer to corrupted files. In most instances, this could be corrected by formatting the player. This of course would mean that a fresh "filing system" and "table of contents" would be written on the device. But then, this also means that all its contents would be erased.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
You have to make sure your songs are MP3 or Unprotected Windows Media Audio files. You can check this by right clicking the song, go to Properties, it will tell you the type of file, make sure its says MP3 or the song is not compatible with the unit. Below is a link on how to add songs through windows media player:
Instead of dragging the songs directly to the player, use windows Media Player to transfer the songs instead - erase all of the ones that you have dragged on to the player first before proceeeding.
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
Through
Try adding some songs using Windows Media Player. Then on the home screen go to menu-system-system repair tools and reset the temporary settings ( the 1st option on top). Warning:If you have rated your songs the ratings will disapear.
If you want to delete EVERY track off the player, then reformat the player in Windows Media Player - it's a shortcut - see my "tips and tricks" on formatting mp3 players If there are artist, album traces, then you need to click on every subfolder under your device in Windows Media Player and delete every trace that way - tedious, but effective -Tha Mp3 Doctor There are 2 ways to format an mp3 player - if you were formatting the mp3 player from "My Computer," then try reformatting from Windows Media Player instead - I have a "tips and tricks" entry on How to Format an Mp3 Player for details If that doesn't work, then double-click on My Computer, double-click on the Sansa player, and go to the various folders that it lists - music, voice, etc. Delete the songs ONLY - do not delete the dat, bat, ini, inf, or other system files
Through
It's an unsupported file format. Are you trying to play files that were ripped in I-tunes? I-tunes does not make mp3s, it makes m4a files, which are not supported. Make sure the files you put on this player are mp3 files. You can also use wma files, but you will probably need to use Windows Media Player to transfer those files.
Let me know how you get on & shout if you need more help!
i cant play any sounds in my laptop..
kindly advice.
[email protected]
