LG Model HT752TH
My Lg player works fine despite if I play AVI Video files the player stop after 2 third of the movie maybe somebody has the same problem
    Problem Solver:
  • 6 Answers
It seems that your drive is not working properly. when reading the laser moves toward the outer edges of the disk. Your problem is most likely mechanical in nature. the gears inside your dvd disk drive might be dirty or worn.
Posted on Oct 15, 2008
My LG DP122 will play some AVI files from a USB device but not others.
figured this out, lg dp122 uses DivX Home Theater profile, so the technical specs of the video must match that.
Those specs can be found here: http://www.divx.com/files/DivX-Profiles_Tech-Specs.pdf
Jan 23, 2013 | LG DP122 DVD Player, Multi Format...
Any way of dissabling the DivX code so I can Play My own DivX dvd's?
No! these units are pre-programed from the factory, you would need to go online to LG and contact customer support and the technical department to see if this is possible.
May 07, 2012 | LG Televison & Video
I have an LG BD650 player that it's not able to play divx videos because "video format not supported." The specs of the player indicate otherwise.
I had the same problem with certain .avi files. I did a lot of research and found a program called "FourCC Changer". You can google it and download it for free. Open the file that doesn't work and change the "fourcc" to "xvid". Once I did that, the .avi files played without a problem. I hope this works for you. Good luck!
Jul 03, 2011 | LG BD650 BluRay Player
Cannot play .srt subtitles on .m2ts movies on my LG BD550 (even the names of both files are matched). Any idea what to do?
You cant play subtitles with .m2st try .mkv, .avi and .MP4 it would work for sure. there is a problem with the LG players they don't integrate the subtitles well. sometimes u might observe lag also!!
Mar 05, 2011 | LG Televison & Video
Hi, how to enable subtitles for DivX movies from USB on LG 42LE5500? I connect USB, TV recognizes folder where DivX .avi file is but within same folder it does not "see" .srt subtitle. Also, in settings...
It seems that subtitle file must have exactly same name as movie file. For example: Movie file: Mission impossible.avi Subtitle file: Mission impossible.srt or Mission impossible.sub or Movie file: Mission_impossible.avi Subtitle file: Mission_impossible.srt
Aug 14, 2010 | LG 42LE5500 42 in. TV
Picture sides cut off when watching avi files
My new LG LCD is not syncing the video and audio when playing avi movies on either USB stick or HDD.
Dec 28, 2009 | LG 37LC5DC 37 in. LCD Television
GOM Player can't play (.avi) file/
Hi teddy, maybe the file you are playing is not a real avi file. Try to Open "My Computer">Tools>Folder Options, then look for "Hide extensions for known file types" and uncheck it. Then look back at your file again if it's still has an avi extension. Another reason is that, maybe the file is not a real movie or video files.
You can download the latest GOM player at:
http://www.gomlab.com/eng/GMP_download.html
Maybe it could help you reinstall the player then try to play it. If still the same, the problem is not the player it's in your file.
Dec 27, 2009 | Computers & Internet
LG HT762 DVD Player won't play divx anymore?
Try to unplug the player for a few seconds and then plug it back. It should work again with the DivX files. I had an identical problem and since then, it works just fine.
Apr 02, 2009 | Televison & Video
LG RH188H - what movie file types does it play?
AVI are a certain type of movie file.
Your problem is most likely that you do not, have the correct software ( program ) installed on your computer to view these files, yet i believe do play on a normal DVD Player.
you could try Windows Media player, this may work for you. also power DVD or Similar. although there are newer programs out there. as for the conversion, this is a long winded process in itself. To convert AVI To MPEG ( standard DVD Format ) you need unpacking tools and software, And a relatively high spec PC, Lots Of Memory.
Hope this guides you.
Mike @ compurepair.
Feb 29, 2008 | Televison & Video
Archos 704 Wifi - does not play AVI file until its full lentgh
I had the same issue.
The size of the AVI cannot exceed 1gb or the end of the movie will never play.
I had a movie that was 1,7gb. 2 hrs and 15 seconds.
The Archos recognized this as a 1.7gb file and 2:00:15 long.
As soon as the movie started, the time line bar at the bottom of the screen went from 2:00:15 to 1:10:25. Basically, it cut off the last 50 minutes of the movie.
I simply divide the movie into 1gb chunks.
I decrypt the DVD to the computer
Use Nero Recode to convert it to and MP4. Divide the movie into 1gb chunks and Maximize the Volume.
Use SUPER to convert it to an AVI / MPEG-4 / MP3.
Copy this to the Video folder of the Archos.
This is simply something that Archos does not want to admit is an issue. They want you to purchase the Cinema plugin.
Sep 28, 2007 | Archos 704 WiFi Digital Media Player
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
Electro Med Services...
