Question about Xerox Phaser 8400 Laser Printer
Hallo Xerox Phaser 8400 error 07.009.42:85788
  • vsinfo Nov 24, 2008
    07.009.42:52082 error, can't print, can't connect to printer.
  • Jim Throckmorton May 11, 2010
    Hello do you have a noise when it starts to print like gears out of sinc?
    Novelist:
  • Xerox Expert
  • 297 Answers
07,009.42 indicates that the printhead was unable to tilt normally on its axis.
You probably have a cracked drum maintenance camshaft. If the drum maintenance pivot plate is white plastic it should be replaced as well with the new style, which is black plastic. This repair requires removing the process drive gears assembly and reinstalling it requires the gears to be timed. This repair should be performed by a qualified technician familiar with these machines.
You probably have a cracked drum maintenance camshaft. The dm camshaft is driven by the process drive motor on the right side of the printer. It raises and lowers the maintenance kit against the drum to oil and clean the drum. The camshaft has 2 lobes on it. These lobes crack over time and cause several different error conditions. The camshaft part # 401100380 is only about $17 from xerox but can be tricky to replace if you're not mechanically inclined. The other thing to look at is the pivot plate assembly. Slide out the drum maintenance kit. If you look inside the cavity the plate that the maintenance kit sits on is called the pivot plate. If it's white it will also need to be replaced with a black one.
Posted on Jan 16, 2009
Error code 13.387.48:106521 Phaser 8400 Print Count 110,000 Can this be Fixed
It can be fixed, but only by a Xerox authorised service centre. Xerox website tells you to turn it off and book it in for a service. Be prepared to pay a call out fee before hand. Here's the reference link for your error from Xerox website.
Mar 06, 2011 | Xerox Phaser 8400 Laser Printer
Error message Xerox Phaser 8400 07.010.43.4819
The post was a little confusing. You have an 8400, correct? (not an M20)
The 07,010 error is normally a bad process motor 401-1000-80
You should also change 2 camshafts at the same time 401-1003-80 and 384-1874-80. The whole job is medium difficult and takes 2-3 hours.
Whit
Item, Inc.
May 09, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Xerox Phaser 8400 Fault 37,008.44:9490
this is a Preheater error 37,008.44 I will put the link below so you can see how to fix it the repair for that error is on page 105
https://www.office.xerox.com/partners/products/Phaser8400/SQRG/8400_85XX_Service_Manual.pdf
Jul 23, 2009 | Xerox Phaser 8400N Thermal Printer
Printer Phaser 8400 : error 07,010.43:116034
If your printer is networked, if can fix its self by accessing this site
http://www.phasersmart.com/
May 18, 2009 | Xerox Phaser 8400 Laser Printer
What is error code 07,010.43:32309
The print head is not moving freely.
There is s print head block that may be filled up with runoff ink, or the print head wiper blade may be tacked to the print head.
Apr 16, 2009 | Xerox Phaser 8400 Laser Printer
Error in xerox phaser 8400
37,004.40: PEST - Printhead Reservoir 0 disconnect. Reservoir 0 is not drawing
the expected power from the supply.
One of the printhead cables may have come partially unplugged. Also, an ink spill on the circuit board could lead to this problem.
Apr 13, 2009 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 error
That is a print head tilt error. Either the print head pivot block is contaminated with ink or the wiper blade is tacked to the print head.
Let me know if you want to try to resolve it yourself, I will send you directions.
Feb 17, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox phaser 8400 error code
That code is a jet heater code.The most likely problem is a bad print head, the second most likely bad item is the electronics module that supplies the 40-50 volt source to the print head heater.
Sep 22, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400
The first obvious question is, "Does it have blue ink/wax?" Is it displaying any errors? Have you tried the Xerox support site? They have a fantastic utility that can connect to your printer and diagnose many problems. Here's the URL for the utility: http://www.phasersmart.com/ They also have a wealth of information in their knowledge base. Here's the URL for the support page for the Phaser 8400: http://www.office.xerox.com/printers/color-printers/phaser-8400/sprt-enus.html Did anything happen before the blue quit printing? Have you tried running a cleaning cycle?
Aug 21, 2007 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
276 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
