Question about HP Pavilion 753n (P9852AR#ABA) PC Desktop
Pc simply turns itself off and restarts ofter
HP Pavilion 753n PC Desktop will work fine, then suddenly turns off and back on. I know it is not the hard drive. I blew out all the dust and made sure all the power wires were tight. What to try next???
    Sergeant:
  • 306 Answers
Go to the hp.com website and ensure that you have all of the software updates including BIOS firmware updates available. HP has an auto-detect program that you can run online so choose that option if it is available. Another possibilty is the power saving mode you can access in the setup. At boot press the F2 key and peruse the power saving options. Second to worse case is the power supply dying which is a pretty easy do-it-yourself replacement and cheap these days. Just ensure that the watt rating matches or exceeds the original and has PATA/SATA connectors you need plus the right CPU power plugs. Motherboard problems are the worst case so try reseating the RAM first and remove one at a time to see if the RAM modules may have intermittent failures. Overheating is another consideration if you found alot of dust which acts like a thermal blanket on components.
Posted on Oct 15, 2008
  • 23 Answers
Do you use an UPS for your system... this can happen due to power fluctuation too...i think if you use an UPS your problem will be solved..
    Problem Solver:
  • 6 Answers
Overheating problem. Install a fan or put some arctic silver underneath the heatsink. the heatsink is what goes on top of the processor.
I cleaned my pc, its a hp pavilion 753n, and then when i turned the pc on, the fans didnt work and after i turned the pc on, one minute later it turns off.
What did you clean it with? What part of it did you clean? Inside outside?
If you cleaned the inside with a really damp cloth or even a regular vacuum you would have mostly ruined the computer.
Comment back.
Aug 15, 2011 | HP Pavilion zd8000 Notebook
How much memory can I add to my HP pavillion 753n?
The HP Pavilion 753n uses PC-2100 type memory. Maximum is 1GB.
Feb 13, 2011 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
I have a Hp Pavilion 753n that when I turn it on fans run for about 9 seconds then powers itself down
Sounds to me as though one of your memory modules have failed inside the tower. You can perform a memory test so it would be worth researching that. Try this site http://www.memtest86.com/. You need to know if you pc is 32 or 64 bit first. you can find this by going to Start, All Programmes, Accessories, System Tools and finally, System information, in that order. Once you know, you can look for the correct memtest to download.
Jan 12, 2011 | HP Pavilion a1410n (ER890AA) PC Desktop
My computer doesn't turn on just beeps
The beep is a code that will tell you where the fault lies.
How many times does it beep before a short rest?
Dec 19, 2010 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
My desktop,hp pavilion753n worked fine til a few days ago.Now when i turn it on it goes thru the windows thingy and will not log on after that.It will allow me to use the f8 option but none of the options...
sounds like corrupted files or a virus/malware that is preventing you from loading up the OS. If you have a way to scan the hard drive with an external hard drive caddy and another PC I would try that. Or you can simply just reinstall your OS.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
How and where do I get a Start Up Disc for my HP Pavilion 753n? When I bought it from Best Buy almost 10 years agon, HP wasn't providing them with the computer... which I thought was crazy! Now, I have the...
You can try to access the recovery partition of your Hard Drive by performing the following task:
Turn off your computer
Power on the computer
Start tapping the F10 key on your keyboard
It will bring up the PC doctor recovery screen
Select the option to restore computer to original factory settings
If you face any kind of problem in accessing the recovery partition, please let me know, I will give you a direct number and link from where you can order the recovery discs.
Please let me know if you find this solution helpful.
Don't forget to leave your comments and ratings.
Thank you for choosing Fixya
Mar 08, 2010 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
How do you replace the motherboard on a hp pavilion 753n.
open the processor first and then unscrew the screws and replace the mother board with the old one. and then connect all the hubs
Feb 26, 2010 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
My HP Pavilion 753n starts to be and then
It is the power supply
In hp the power supply they use does not die on you completely; it will start but not feed the computer.
So change it to generic brand and every thing will work fine.
Jan 02, 2010 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
HP 753n turns on and seems to start, nothing shows on the monitor. I pluged the monitor into another computer and it works fine. Is my vidio card bad? How do i fix it without being able to see anything?
If it is the video card, then you simply have to swap anoth in.
If your video card is embedded into the mother board, get a new video card of the correct type and plug it into the mother board. There is no way to fix a video card that has gone bad if its embedded into the motherboard, but you can upgrade to a regualr video card.
Aug 27, 2009 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
HP Pavilion 753n (P9852AR#ABA) PC Desktop Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
