Question about Epson DFX-8500 Matrix Printer
E4 Error It blinks all led flashing E 4 after making a jam noise, then turns off after a while
E4 Error
It seems your printer,s carriage is jam or carriage encorder is out of carriage sensor
Posted on Nov 08, 2008
When the print head does not slam or move left or right, 'only adjusts paper thickness - forward and back'. Suspect paper fuzz and / or dust around the front paper feed area. A can of compressed air can blow through slots and vents to remove some of this. Fixed the problem when all sensors are operational, the top lid sensor in mine is magnetic, a hall effect switch detects the magnet in the closed position.
Posted on Oct 12, 2009
Do we have 24pin Epson DFX 8500 printhead?
Posted on Apr 08, 2010
2 Suggested Answers
SOURCE: E4 Error
encoder strip is out of it senser , look under printhead area.
Posted on Aug 01, 2009
Error code e4 unit airconditioner
Not sure about E4 , but 4 blinks or flashes usually means the compressor isn't starting properly. It could be a faulty start capacitor or wiring or faulty indoor PCB (Board)
Oct 18, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Neon c2297f. When I plug it in and turn on the power, the red LED blinks, whenever the LED blinks on I hear a discharge from the speakers.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Aug 15, 2017 | Televison & Video
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Jul 09, 2010 | Heating & Cooling
All lights are flashing
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
All the best Pineworks
May 01, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Trobel paper does not go on E3
it.
procedure:
button pressing
the "service mode"
Try it
it.
Apr 28, 2010 | Canon PIXMA™ iP6310D InkJet Photo Printer
Printer keeps on flashing E-5 and is not printing out anything
it.
procedure:
button pressing
the "service mode"
Try it
it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I turn on my pixma mp150 and it flashes e4 whats the problem then
Hi there
it.
procedure:
button pressing
the "service mode"
Try it
it.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Mar 21, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Pixma mp150 E5 flashing and b + c flashing and warning light on! have recently put in cartridge world inks but have already printed with them now its playing up each time you try to use printer.
Canon printers MP 160 AND MAYBE OTHERS
it.
procedure:
button pressing
the "service mode"
Try it
it.
Mar 17, 2010 | Office Equipment & Supplies
My printer canon pixma MP140 All-in-One is not printing! The light in B keeps flashing and its says E4! whats the problem?
Hi there you try.
it.
procedure:
button pressing
the "service mode"
Try it
it.
Sep 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E4 Error
Sep 26, 2008 | Epson DFX-8500 Matrix Printer
Epson DFX-8500 Matrix Printer Logo
1,066 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
