Kindly restate the details of your problem instead of "fgjftgkgh.jk" and instead of writing the details in the subject box........We need the clarification and further details for us to help you...thank you!
You can't post conmments that contain an email address.
OK.there is only solution, please re-consult to mobile tech and let them reheat the blue-tooth ic or let them change it.Reheat can solve 70% of this problem.So, at least you can try.Good luck
sir just flash your mobile, Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
C.O.D.E 1: --->>*#7370# C.O.D.E 2: --->> STEP: 1. Switch off your Nokia Mobile, STEP:
2. Press-> Call button,
press-> 3, press-> *, STEP: 3. Now Switch on your Mobile.
you need to update your phone software as soon as possible . to update it yourself :
1) you need to have high speed internet.
2)data cable
3)nokia software updater.
if you have all these just start nokia software updater while your phone is connected and your pc is connected to internet. the phone will restart itself several times while updating . wait for 1 hour and your phone will be updated and everything will work fine.
to download nokia software updater go to http://www.nokia.co.in/support/download-software/device-software-update
if you dont have any of these ..... simply go to nearest nokia care and get it updated.
you can get your best unlock code for your Nokia 3110c model mobile, through this site http://www.mobile-unlocker.com/nokia-3110/rs2wp9/ It provides the step by step instructions and easy methods for unlocking your Nokia mobile phones.............
First: better use kasperaskey anti virus. If your desktop pc or laptop has antivirus, have your pc scan your fon memory through bluetooth, or usb cable
OR: If you have Virus On mobile 1 - remove memory card. 2 - dial *#7780# or *#7073* 3 - It format your Phone 4 - Format memory card. and enjoyyyyyyyyyyyyyyyyyyyyyy
The Problem with Nokia 3110c – Switching off and automatically restarting
This is what happens. Nokia 3110 hangs, gets switched off and
restarts randomly. More often, it restarts around 3 times or so and
then gets switched off.
Possible Causes and Solutions
Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory. Solution – Keep the free space between 350 to 500
KB, so as to keep things running smoothly on your phone and prevent
Nokia 3110c from restarting. Cause 2 – Changing Themes – Some people have
reported that the phone restarts automatically when they try changing
display themes on the phone. Solution – Don’t get your phone loaded with too
many themes downloaded from the internet or atleast, don’t switch
themes frequently. These themes, mind you, also load up things into
your already falling Nokia 3110c phone memory. Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card. Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue. Cause 4 – Transferring data via Blueooth / USB data
cable (or) Updating Music Library – A few people have reported that
their Nokia 3110c mobile phone restarts when updating the music library. Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone. Cause 5 – MP3 files Solution – This may seem dumb, but consider
converting all your MP3 music files to WMA and then store them on the
memory card. Some users suggested this.
Also try this:----- It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically. Try this method 1] Remove the battery and Micro SD card 2] wait about 5 minutes 3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD {Don t Format the memory card}
9] Switch On ur Nokia 3110c phone. 10] Now Keep ur free Phone memory space [Not the memory card's free space] between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months.During these time u can 1] Send/receive any file via bluetooth. 2] Enjoy Music,video, GPRS,Yahoo Go .....etc 3] Also u can Update music library anytime. but remember below DONTs 1] Don t try to change themes.{u have to stick with a theme} 2] Charge ur phone in ON mode 3] Dont fully discharge the battery 4] Start charging ur phone when there is only a bar on Battery indicator 5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again. if so Follow the above steps again. Good luck To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
h plz go to the nokia priority or the showroom with ur bill, and ask them to update ur software, u can check ur software version by pressing these keys *#0000#
