Question about Kitchen Ranges
Hi, I have a Smeg Oven SA410X and the oven over heats everything. The temp goes to high every time even though I set it lower. Do I need to get the thermostat fixed?
    President:
  • 1,462 Answers
It is quite possible the stat needs replacing.
what is also worth a check is that the stat is still in position on the back of the selector switch. the stat is clipped onto the back of the switch and can come away
Posted on Oct 15, 2008
Oven Pre-heats too high
Your oven sensor has gone bad and telling the control board/thermostat to keep heating. Find the model number on the range and go to a parts distributor like repairclinic.com or apdepot.com and order you sensor. This is an easy repair.
Apr 23, 2012 | Dacor ER36D Dual Fuel Range
New oven thermostat acting nuts
can't find our model with this model # .. i would try cking the wiring / making shure it's correct . normal orp when heating the light is on . not heating light is off . although the thermo is new it may be bad / or possible that it not the correct replacement . hope this helped **** ..
Dec 09, 2009 | General Electric JBS07M Range
Temp on oven is not correct
Good Evening.
I would make sure that the conversion kit was the correct kit for your stove. Also, if it is not heating properly I would call the gas company and tell them the conversion did not work and they need to double check their work (at no charge). If everything is in order proceed to the next step below.
You can try removing the Oven Temp control. There is an adjustment on the knob which will vary the temp + or - 75 degrees F or so.
Procedure: Preheat your oven for 350 degrees F. Give it a good 1/2 hour to 45 minutes and then pull the knob off (usually held on with a set screw) You will need a thermometer that will go up to 500 degrees (I use an electronic one but you can use any kind as long as it is within the ovens temp range. If the oven is underheating simply turn the oven control stem to a higher setting, say a 50 degree incrament. Wait another 1/2 hour and measure temp inside oven. Keep in mind when you open the oven door it affects recovery time, etc so 30 minutes between a measurement and adjustment should suffice. Once you have adjusted the temp control to your target temp of 350 degrees look on the back of the knob and see if there is a stop adjustment. There is a chance the temp control knob could be setup differently but the same philiosphy/procedure will be similar.- the adjustment could be on the stem itself instead of the knob.
Also keep in mind that the oven temp will fluctuate from high to low as it tries to adjust to the temp it is set at. That is why it is very important to give the oven time to cycle low to high when you incrament the temp control. Hope this helps and good luck! Gary
Mar 14, 2009 | Whirlpool SF325 Gas Kitchen Range
My Smeg oven heats up to extremely high temperature even when the gauge is on 50 degrees celcius so I've stopped using it because everything is getting burnt. To identify the model just before the word...
Hello, my problem will soon be resolved by employing a professional smeg electrician who said I needed a new thermostat. Thank you for reading but I no longer need 'fixya' assistance this time around.
Dec 22, 2008 | Smeg Kitchen Ranges
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Smeg SUK91MFX5 oven wont heat
Reset the clock that will make the heating element work, if your clock has stopped displaying (common fault) set as per instructions but you wont be able to set at any acurate time.
Sep 16, 2008 | Smeg SUK61MFX Gas Kitchen Range
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Glass breaking
go to a supermarket a buy a thermometer that is oven safe.put the thermometer in the oven and set it to 350 degrees.when the oven light goes out open the door and see what the temp reads on the themometer.it could me the tstat,are you getting the correct voltage to the element or not sure?
Aug 13, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smeg main oven failure
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Apr 01, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Tappan double oven
I have the digital timer oven and also cannot find the manual. You have to set the bake time timer, I think for 3 hours. Then you set the oven knob on clean and turn on the temp knob, probably to full but I don't think it matters. When you engage the lock, the clean light should come on/ When the oven reaches high temp, the lock light will also be on.
Mar 29, 2007 | Tappan TEF242 Electric Kitchen Range
Kitchen Ranges Logo
187 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
