Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
Problem with dishlex dx302
We get error P10. Manual says it's a problem with water inlet filter. Programme stops running and bleeps and P10 flashes. I guess it's not filling up properly but if you press programme again it will restart for another 10 mins before the same problem occurs. Cannot locate this filter even though we have looked underneath, at the back and inside. Help.
  • catzacmax Nov 14, 2008
    P10 alrams activates after approx 5 - 7 mins operation. Restart will continue to fail around same time. Checked water in line filters just the ones connected to the actual water supply and where it enters the unit. Next step cap off water supply remove the until to investigate underneath. If no Joy Dump here I come!
  • megsylea Jan 28, 2009
    We have the same problem dishwasher stops ans shows code 10, press the start button and it continues for approx 5-10 mins then beeps with code again.
I know what the problem is.
The 10 error relates to a water inlet problem. In my case the water was going in, but after about a minute it would display the error code and beep.
I knew the computer would sense for the incoming water and if it doesn't sense the water entering I assumed it goes into the error. There are two water pressure switches near the wash cavity base on the right side (looking from the front) which do the sensing. Each has a hose going from the switch to the sump at the bottom of the wash cavity.
At first I checked each pressure switch with a multimeter. I removed each hose from the sump andI gently blew into each hose while watching the multimeter. An audible click can be heard and the meter showed the switch closed indicating both pressure switches were OK.
Next I reconnected each hose to the sump and removed the other end from each pressure switch. A gentle blow into each revealed one hose connection to the sump was blocked. The blockage prevents the water level from activating the pressure switch at the appropiate time. The other sump hose connection was OK.
With an air compressor I blew compressed air back up the hose and into the sump on the blocked side. I lay the dish washer onto the left side to make it easier and to ensure the blockage would not remain in the sump when blown out. A clump of food scum was cleared from the sump with the compressed air.
Put it all back together and I don't need to wash by hand again and I have one happy wife.
Posted on May 31, 2010
  • dave marshall
    dave marshall Sep 02, 2015
    hi how do you actually access the switches ? I guess it means removal of outer case of dishwasher? thanks Dave
Diplomat dishwasher ADP 8322 - previously not draining but neither was the sink and I've unblocked that which is now working fine. When I put it on it bleeps continuously after about 5 minutes
Hello Simon,
No water in the tub would indicate the drain is clear (unless it never filled at all...have you confirmed? Do you hear water leaving the unit?).
Those bleeps and flashing lights are of course the machines desperate effort to tell you it's problems and the code may be in the owners manual or a call to the manufacturer.
I'm a big one for checking grunge accumulation and would ensure the discharge hose is clear. This gets back to hearing water leaving the machine. You may need to pull the unit to check the hose, although a common blockage is right at the connection to your disposal.
Also, check for debris under the filter screen in the bottom of the tub, another place detritus accumulates.
All the best.
Nov 22, 2014 | Dishwashers
I have a adg7560/1. the cycle starts but ends after a few minutes. the light flashes four times
Run the dishwasher through a test mode
Test Mode
Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
Open the door and set the program to the first program. (Normally rinse).
Turn the power off.
Press and hold the start button and while holding turn the power on.
After a little while the start button will flash, release the button.
Press the start button once and close the dishwasher door.
The machine will now run through a diagnostic routine.
Should take about 20 mins.
The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the programme.
To exit diagnostics at any time just press and hold the start button till the programme is cancelled
Error codes
F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
FB. 12 Flashes. Motorised Diverter Valve
FC. 13 Flashes. Water Hardness Sensor Failure
A fault with no fault code indication = faulty module
Read more: http://www.diynot.com/forums/viewtopic.php?t=200838#ixzz2zKhYFHxt
Apr 19, 2014 | Whirlpool Dishwashers
Error 3
Error 3 is a Door lock error and has nothing to do with the water sensor. Tighten the door down snuggly, but don't over-tighten. If it still doesn't work it may need a door rebuild or switch replacement. Call for service if it doesn't restart.
Apr 16, 2014 | ESCHMANN Little Sister Autoclave Tabletop
Error 0001 error 0002
I have looked through the Service Manual for you and there does not seem to be an error code 0001! or 0002. Are you getting any sound Bleeps? Or flashing Orange or Green lights?
Mar 10, 2014 | Canon PIXMA MP830 All-In-One InkJet...
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
Have a dishlex dx302 it starts. timer counts down and shortly after error code CL /beep happens. can you help me.
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Thank You for using Fixya
Aug 17, 2011 | Electrolux 24 in. EDW5505EPS Stainless...
My Diplomat dishwasher ADP8352 keeps stopping
Switch off the machine at your plug end and switch ON.
Check incoming water flow. Check and fill rinse-aid liquid in the dispenser. Check dish washer salt dispenser and fill.
These are the only actions an user can try.
May 27, 2010 | Dishwashers
Ignis dishwasher beeps and flashes constantly
salt container is full of water
Mar 10, 2010 | Dishwashers
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
1,507 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
