Question about RIM BlackBerry Curve 8310 Smartphone
Blackberry 8310 Bluetooth device no services
Hi, Have a blackberry 8310 that was working with my bluetooth car kit. No it will pair and says connected, but is not working. When I check Bluetooth device options, there are items listed in the services, but when I check the paired device properties there are no items listed in the services so i suspect tis is the problem. How do I get them back! all other phones i tried work in the car.
Regards
Jim
  • George Mc77 Oct 24, 2008
    Hi, I have a blackberry 8310 that won't allow bluetooth transfers. It will pair and says connected, but is not working. When I check Bluetooth device options, there are items listed in the services, but when I check the paired device properties there are no items listed in the services so i suspect tis is the problem. How do I get this to work ??
  • Anonymous Mar 14, 2009
    IN MY TOYOTA LANDCRUISER 2004, WHEN BLACKBERRY T-MOBILE IS CONECTED WITH BLUE TOOTH, IT WILL INDICATE BLUE TOOTH CONNECTION DETECTED AND THEN IT WILL STAY CONNECTED AND IF YOU TURN OFF THAT MESSAGE, SPEAKERS IN AUTO WILL NOT FUNCTION FOR PHONE AND WILL GIVE HUM.
    DEALER AT TOYOTA SAYS ITS BLACK BERRY PROBLEM.
I just experieiced this for the second time on my 8320 using a plantronics 510 bluetooth. The solution was to take the battery adn SIM card out of the phoine and leave it out for a full minute. It appears that the phone needs to be rebooted once in a while. I suspect Bill Gates designed some of the internal code.
Posted on Nov 04, 2008
How do I connect my blackberry cel phone to my bluetooth ce0678
Hi, you can use this instruction to pair your blue tooth with your cell phone:
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Good luck to you..
Feb 01, 2011 | Cell Phones
My Blackberry 8310 finds the Parrot 3000 (bluetooth) device, but does not ask for the password, and therefor, cannot connect. How do I get these two to mate? (kidding--I mean pair)
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Sep 21, 2010 | RIM BlackBerry Curve 8310 Smartphone
Cant get my bluetooth to pair or it says it is connected cannot transfer anything across
In this case you have to fallow few troubleshooting steps please fallow this.
1. From the BlackBerry smartphone home screen, select the Options icon. 2. Select Bluetooth. 3. Highlight the Bluetooth paired device in the list that is experiencing this issue and press the Menu key. 4. Select Device Properties. 5. Set Trusted to Yes.
Oct 29, 2009 | RIM BlackBerry Curve 8310 Smartphone
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Built in bluetooth carkit but my BB Bold won't connect
Sir you have to just on bluetooth visiblety from your phone settings
Jun 01, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
BlackBerry won't pair with device anymore via Bluetooth
1. Go to Options/Bluetooth
2. Select device found
3. Select device properties
4. At Trusted select yes
It'll never ask again
Dec 30, 2008 | RIM BlackBerry Curve 8310 Smartphone
Plantronics 330 no longer pairs with Blackberry 8310.
I believe that the bluetooth symbol that you see indicates that bluetooth is enabled on your Blackberry, not that you are connected to a device (at least that's how mine works).
Here are some suggestions:
First, if you are on BES, check with IT to make sure no changes were made (they can block bluetooth).
Next, make sure you are using the most current software. It should be: v4.5.0.108. If you are using an older version, definitely update your software because the 8310 is known to have bluetooth issues.
Do you see your headset listed on "paired devices"? If so, I suggest that you delete it before upgrading the software.
Once your headset is no longer listed (or if it wasn't in the first place), re-connect it to your Blackberry as follows (apologies if you already know this part):
1. Re-set your headset:
Turn the headset off.
Press and hold down the control button.
After 6-10 seconds, the light will flash blue, then it will flash red, then blue.
Release the button when you see the red/blue.
2. On your Blackberry:
Open "Options"
Open "Bluetooth"
Open menu within Bluetooth
If not already on, click "Enable Bluetooth"
Open Bluetooth menu again.
Open "Options".
Turn "Discoverable" to "Yes"
Open the Bluetooth menu a 3rd time.
Click on "Add Device".
Your Blackberry will search for your headset.
If you are prompted for a Passkey, use 0000 (that's 4 zeros).
After a short time, your headset will appear on your Blackberry.
It should appear as Plantronics 3xxx.
Make sure you go back into Bluetooth Options and change "Discoverable" back to "No".
Once you have established a new connection with upgraded software, you should have no trouble with "Transfer Address Book".
Hope this solves your problem.
Dec 28, 2008 | Plantronics Explorer 340 Wireless Headset
Bluetooth
Your bluetooth needs to be in pairing mode. Depending on what model bluetooth there are several methods to put it in pairing mode. the most common is pushing and holding the main button until a light changes color.
Dec 02, 2008 | RIM BlackBerry 8800 Smartphone
Pairing Motorola HS820 with Blackberry 8310
there is really no fail safe method to pairing a bluetooth device.
The main thing is recognition. i,d suggest trying to press the different buttons on the transmitting bluetooth device, whilst attempting to pair. i.e volume up/down or on/off et,c. to enable the device-blackberry to find and sync. i,d think the device that needs to be configured or setup correctly is the blackberry rather than the bluetooth device.
try changing the phone settings. to accept all incoming signals on bluetooth, or disable encryption.
hope this helps.
Mike @ Compurepair.
Oct 06, 2008 | Motorola Mobility HS820 Consumer Headset
RIM BlackBerry Curve 8310 Smartphone Logo
2,285 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
