Question about Sony VPL-HS20 Multimedia Projector
Powering up My HS20 is 4 years old and still had 400 hrs of bulb life. Recently when I turned on the projector, an amber light flashed for a few minutes then powered down. Tried several times to no avail. No images projected on the screen. Does this mean that the bulb is burned out? Is there any way to test the bulb before buying a new one? Please advise. Puebbie perosas1@yahoo.com
  • puebbie Oct 15, 2008
    In regards to the comment concerning my problem, the filter has been cleaned - and the fan comes when powering up. The bulb does not come on when powered up. As mentioned before, when powering up the projector runs for about 2 minutes, with fan running and amber light flashing, then powers down.
    Please advise
    Please advise
    Brigadier General:
  • 6,966 Answers
The Sony VPL-HS20 powers down when it senses something is wrong. This is to prevent any further damage to the circuitry. Part of its built-in diagnostics is to determine presence and bulb-life. The flashing light and the turning off both indicates a component failure. You may want to consider replacing the lamp. Depending on your location, replacement Sony LMP H180 - projector lamp maybe be available from online stores such as here, here or here.
Alternately, it may be to your advantage to simply have the unit serviced and not only lamp replacement. Service would include cleaning, lamp replacement and timer reset of bulb hours. Doing so would assure you that you can expect the same number of years of service from the HS20.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 15, 2008
  • 1,879 Answers
Lamp problem
testing the lamp before buying a new one is the best way but you need to have an identical or compatible projector to test the lamp. best place to find one is a repair shop or if a store will accommodate if request for it.
  • 81 Answers
Hi.
Yes the symptoms shows the bulb is down.
According to me there is no way to check the bulb.
I would advice you to get it checked at a repair shop before going to replace the bulb as there might be other problems.
Regards
Faraz
    Sergeant:
  • 306 Answers
To get the best time out of your Projector and your lamp , you should take in your Projector at least twice a year for a service.
If you want to clean out the filters , simply take a vacuum cleaner and vacuum the dust out.
As for the fan , this could be as a result of dust , but I would suggest you have it checked out by a Sony Service Provider as fan malfunction is the biggest cause of lamps blowing.
Also try not to run the Projector for short periods at a time as this simply eats away on your lamp. Rather leave it running for longer periods a Projector's lamp is similar to the lamp's you use in your house - switching on and off all the time makes the lamp's fillament weak - Take my word on this , I've had please using the Projector to watch a odd movie now and then and they only get 500 - 1000 hours on their lamps. And then I've had clients who use their Projectors as TV's and they got 10 000 - 15000 hours on their lamps.
    Sergeant:
    Champion:
  • 331 Answers
The projector is quite good and may not have any internal defect
may the bulb has really burnrd out......
try a new bulb if it works or not
  • Varun Kumar
    Varun Kumar Oct 15, 2008
    i think u should go for the new bulb
  • Varun Kumar
    Varun Kumar Oct 17, 2008
    u could go to a service center to get it fixed
Power bottom light flashes amber and the temperature light is steady amber after DMD chip replacement.
Sounds like a board problem or a bad temp sensor. Those things get pretty hot (charred) and you may have open circuit it when you swapped. Did you put the old one back in?
Nov 25, 2014 | Dell 4610X Wireless Dlp Multimedia...
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
My projector's power light is red, but when I click power it won't turn to green (on)
The likeliest problem here may be a burned out or failed projector bulb. Most projectors will fail to power up at all when if the bulb is out. The HD20 user manual does not specify a red light as an error indication option however, generally amber.
User manual .pdf is located here (takes a bit to download for it's size), Projector Status Indicator instructions are located on page 40.
Here on the product page itself, an email to Optima support may be warranted given the red instead of amber error light.
If you had any messages recently indicating your bulb life was nearing it's end, again, this would be my first guess. Certain models of projectors do have a tendency of blowing through bulbs even before any warning message comes up. I had an experience with a certain brand/model that for the last 3 replacements has given only about 1/4 of the stated bulb life, so unfortunately it does happen.
Mar 05, 2011 | Optoma HD20 DLP Projector
Projector turns on but no light or image from lens.
The bulbs do not always look broken when dead. You say it is used often. The life of a bulb is around 1400 hours I believe. This normally equates to a year or two depending on your usage levels. Did you notice your image getting dimmer in the months before it stopped working? This would be a good sign it was in need of replacement. Are the lights flashing very rapidly or blinking slowly? If they are flashing very rapidly this indicated the bulb will not fire and needs replacing.
Jan 16, 2009 | Dwin TransVision 3 Plus Multimedia...
Projector keeps turn itself off
I have a Dell MP2300 with a bad power supply. Everything else is in excellent working condition. the bulb is less than a year old and has less than 500 hours on it. My asking prices are:
1. WITHOUT BULB: $50 shipping
2. WITH BULB: $150 plus shipping .
If you are interested, please contact me. I will also consider offers.
JJ
Bethesda MD - 301-588-7222
Jan 09, 2009 | Dell 2300MP Multimedia Projector
Infocus SP 4805
How old is it ? Approx how many hrs have you used it? Was it set at Lo speed / low power or hi speed / max power on bulb and fan? Do you smoke in the same room? Is the unit ceiling mounted ( more concentrated hot air ). Have you had a power failure while the unit was on? The bulbs used in many projectors , although claiming 3000 or more Hrs ,are subject to early failure. If the unit or bulb is new ( less than 1 yr. old, contact the service manager at that co. and complain about short life; IThat works !
Apr 30, 2008 | InFocus ScreenPlay 4805 Multimedia...
Sony VPL-HS20 Multimedia Projector Logo
293 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
