Oteman dp-90 pen plotter- computer does not see- need generic drivers?
I have a oteman dp-90 upright pen plotter/printer. My computer does not see it at all. I have not been able to find any support for this plotter for over 2 years, can you help?Do I need to re figure the switch settings on the plotter as it is plugged into a com port with a new adaptor.
What generic drivers can I use for this? Any help on this would be greatly appreciated
SOURCE: Networking a Panasonic DP-2330 Multifunction printer/copier.
i have a panasonic printer but drivers is also remove with windows and my printer cd i forget so this time my computer in so software in panasonic dp-2330 printer i want reinstalling printer in computer so u till suggesting
Posted on Aug 13, 2008
  • 148 Answers
SOURCE: Intermec 3400 label printer - Connected but no printing...
your com setting must be 9600baud 7 data bits even parity
you may need to drop back to win 98
here is the syntax you need to send to the printer STX ESC E5 CAN DATA CR DATA CR ETB ETX PRINT
Posted on Jan 04, 2009
preachw996
  • 1179 Answers
SOURCE: Need drivers for panasonic dp 2330 printer
You can download your driver here: http://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?storeId=11201&catalogId=13051&itemId=88287&catGroupId=13843&surfModel=DP-2330&displayTab=R
Just click on the driver download & select the driver for vista. Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 09, 2009
  • 62 Answers
SOURCE: Printer port configuration and Zebra trouble
When you connect a printer to your pc the operating system adds a virtual port. Your pc will typically have 3 physical usb ports but can have as many virtual ports as you have devices to connect to it.
1: Ensure that your printer has media loaded and is powered up and ready to print. Connect the USB cable. You should get a message on pc screen saying device (printer) found.
Open printer driver ( double click on the zebra printer icon - Start/control panel/printers & Faxes/) Click print test page. If it doesnt print you will see a printer icon with a red question mark.on your toolbar, double click on this. This will bring up a small window showing status of the print job, Click printer/properties/ports. Select the next free usb port and click apply. Drag the print status window so that you can see the message in the status window change from Error print to error Restarting. repeat trying each of your usb ports until printer works. start with the higheat usb with highest number and work your way down.
Posted on Aug 02, 2009
  • 5 Answers
SOURCE: win 7 driver for panasonic DP 8020P
Go to www.panasonic.net. Click on support tab. Click Business & Professional, Office Products, Digital Imaging Sytems and scroll down page to find your model. Accept the terms of the license agreement and you will find the driver(beta) their.
Posted on Dec 30, 2009
Plotter will not print
Check lan card led blinking pattern., Replace lan card(Jetdirect card 620n) & check, mostly lan card issue might be there..
Jun 12, 2015 | HP DesignJet 5500PS InkJet Printer
I need the drivers to install a plotter ENCAD CADJET 2 in a Windows 7 ultimate
Cadjet2 - All the drivers, utilities and more are available from the following site:
http://www.wideformat.kodak.com/support/Printer%20Reference/CJ2.asp
Aug 12, 2010 | Encad Kodak Premium Backlit Film 36" X...
1. PEN NOT LIFTING. HOW DO I ADJUST PEN LIFT 2.PAPER SKEWS TO LEFT 3. NEED SERVICE MANUAL ON SUMMAGRAPHICS PLOTTER HI7200
Installing Pens
Most types of disposable pens must be activated before using the for the first time. If you are installing a new disposable pen:
  1. Press down on the pen cap to break the internal link seal.
  2. Holding the pen with its tip pointing down, shake the pen to start the ink flow.
  3. Remove the cap and test the pen for ink flow on a scrap of paper or media before installing it in the plotter.
    Some types of pens require adaptor sleeves to fit the pen holders in the pen changer and pen carriage. Insert each pen into its adaptor sleeve, if required, before installing it.
Using the Pen Changer
You may find it easier to temporarily raise the pen changer arm to install pens. Press the widest part of each pen into the jaws of each stall in the pen changer. After installing all the pens that you plan to use, lower the pen changer arm until it latches into place.
Notice that the pen changer stalls are numbered 1 through 8 from right to left (viewed from the front of the plotter).
Note: Make sure that the pen changer arm is in its lowered position and latched into place each time you power on or reset the plotter so that the plotter will correctly change pens.
Operating Without the Pen Changer
For operation without the pen changer, position the pen changer arm in the raised position and install a pen directly into the pen carriage by pressing the widest part of the pen body into the jaws of the pen holder on the pen carriage. You can still produce multi-pen plots, if desired, by enabling the PEN PAUSE parameter--------------Online KeyThe Online key toggles the plotter between on-line and off-line operation. The mode is displayed with each key press.
The plotter is initally in the on-line mode at power-on. In the on-line mode, plotting operations are enabled. When media is loaded in the plotter and the plotter has been selected (see below), an on-line plotter begins executing plotting commands from the input buffer as soon as they are received from the host computer.
In the off-line mode, the plotter can still receive data into its input buffer if it has been selected, but plotting operations do not begin until the plotter is switched on-line. The plotter can be operated manually in the off-line mode using the following control panel keys:
  • Pressing the left or right arrow key moves the pen left or right.
  • Pressing the up or down arrow key moves the media in or out of the plotter.
  • Pressing the PEN SELECT key accesses a menu to select a given pen from the pen changer.
  • Pressing the PEN UP/DN key raises or lowers the pen.
Pressing the Online key during plotting switches the plotter off-line and suspends plotting.
Pressing the Online key again will cause plotting to resume at the point of suspension. ------------------Pen Up/Dn Key
The Pen Up/Dn key raises and lowers the pen when the plotter is off-line. If there is no pen in the carriage, pressing the Pen Up/Dn key causes the plotter to retreive the currently selected pen from the pen changer (if the pen changer is installed and is in the lowered position).
Note: After approximately two seconds of no pen movement, the plotter will automatically raise a lowered pen to prevent ink from bleeding on the media, until the pen is moved again. If the pen is not moved for the period set for the AUTO-CAPPING parameter , the plotter will return the pen to its pen changer stall. To restore the currently selected pen to its previous position on the media, press the Pen Up/Dn key or an arrow key. Pen Select Key
When the plotter is off-line, pressing the Pen Select key allows you to select a pen from the pen changer. After pressingPen Select, press the <-- --> keys until the desired pen number is displayed on the lower line of the LCD, then press the Enter key. The plotter will retreive the selected pen from the pen changer.
The Pen Select key is also used in the Configuration Menu,
Oct 16, 2009 | Computers & Internet
Plotter mt871 will not communicate from computer to plotter
Try getting some generic drivers for plotters and see if they do anything... I would also suggest that you get a JetDirect card or something to interface the Plotter with your network, this should take any misscommunication away.
Jun 20, 2009 | Computers & Internet
Need to intall printer into computer
you may download the drivers here on this link,
http://members.driverguide.com/index.php?action=dosearch&qm0=Brother+MFC-7440N+Laser+Printer+&qa5=15&qa6=181&dp=3&sm=b&jmd=and&si=3edccdfe38fe3957f3bf2d496521f422&st=1241757214&gqm0=Brother+MFC-7440N+Laser+Printer+Plotter+Multi-Office
main website is driverguide.com
you only need to register then you can download after that...
May 08, 2009 | Brother MFC-7440N Laser Printer
Hp design jet 750c plus. while plotting auto cad drawing,i command it to plot black/white (mono) but it plots all in color instead.I selected mono button on the printer as well.
Your plotter driver needs to be set to either black or greyscale. The driver will overide the settings on the plotter unless you set up the plotter in manual. ie the pen thicknesses, colour etc are set in the control panel to manual. The driver takes priority always.
Feb 20, 2009 | HP DesignJet 750c plus InkJet Printer
Document failed to print
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Jan 06, 2009 | HP DesignJet 90 - printer - color -...
IP Assignment....
No, a tranceiver cannot be assigned an IP address. It just converts the signal between two types of lines (fiber, copper, etc.). This is mainly used for connecting together networking equipments such as switches or routers.
Depending on the type of interface you plotter have, you may need a device called a Print Server. This device has an IP address and allows a conventional printer signal to travel through an IP network. If your plotter is designed to be connected using a LPT (Parallel) cable, like old printers, you may look for the D-Link DP-301P+ or DP-300U.
Feb 12, 2008 | D-Link DE 853 (DE-853) Transceiver
187 people viewed this question
k24674
jasbo
jasbo
