Question about Electrolux Vacuums
I need a new litle swivel wheel for solamatic
Hi, kenmore model 116.25812508 how does the single front wheel assembly come off. It needs to be replaced with part KC95CBZTZV06.
I found this on the Sears website, I'm just copying it. There are 2 possible solutions here.
It can be difficult disassembling parts on your own vacuum. I have taken some time to research your question here on the Manage My Life website and I noticed that someone else had asked a similar question with a posted response from an expert. I attached the link below if you are interested in viewing. I hope the link that I provided is helpful. Have a great day. by afritz afritz Earned 1,558 community points in Click">Upright Vacuums May 26th, 2011
I understand the issue you are having with removing the swivel wheel assembly.
From your reply I see that you have the other style design which is quite similar but with out the locking tabs exposed.
I don't always relate this way of removing the swivel wheel because people are afraid that they will damage the base of the vacuum. Use a large flat bladed screwdriver and get it up under the swivel plate and pry the wheel assembly off. The manufacturing engineers were of the opinion that this part would not break so I think when they designed the part they did not have in mind that someone may replace it. This makes it difficult to replace.
When installing the new one you will need to press it into the hole so it will snap into place.
Let me know how it goes.
Sam A. by Sam A Earned 6,102 community points in Click">Upright Vacuums May 27th, 2011
Thank you for your question.
I can understand wanting to know how to replace the swivel caster on the vacuum base assembly.
To replace the caster you will need to use a pair of needle nose pliers and pinch back the clips and then drive the caster from the base.
I suggest that you support the base between two short pieces of wood so the caster can be pressed out the bottom without touching the support.
As you can see by the new one it will snap into place in the hole of the base after you remove the old one.
I hope these instructions will help.
Thank you for using Manage My Life. by Sam A Earned 6,102 community points in Click">Upright Vacuums May 27th, 2011
Jul 19, 2016 | Kenmore Vacuums
Swivel wheels won't stay straight and the vac just skids.
Do you find that the wheels are jammed and won't rotate, thus causing the vac to go to theleft or right or just have to be dragged along forward?Try wd40 to see if it will allow the wheels to rotate freely.
May 17, 2015 | Miele Vacuums
How do I remove the swivel neck assembly from the vacuum case?
You will also need to remove the screws on the inside that hold the motor in place because part of the side support for the swivel is under the motor. Remember to disconnect wires coming from the swivel as well before you try to pull it out, so that you do not damage them. Hope this helps.
Jul 16, 2014 | Windsor SR12 Sensor Bagged Upright Vacuum
HOw do I replace the riccar 8850 hose?
Inside the bad compartment you can see the swivel portion sticking through. You will need to take a screwdriver and push in on the tabs on the swivel to release it so it can be removed from the body of the vacuum. The new hose ans swivel will just push into the hole and the tabs will hold it in.
May 04, 2014 | Riccar 8850 Vacuum
Easiest way to attach spring to the back wheel base?
As long as the black piece still has the "nubs" on both sides at the turn in the "L" shape and the base isn't broke then this is going to be easy. There is a groove on the main unit the little wheel fits into that groove, the "nubs" fit into small holes on the swivel down piece, and the spring fits between the small side of the "L" shape and the bottom of the swivel down piece..
May 26, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
Need to know which attachment is for sweeping tile floors. Dog hair is getting out of control.
There is a large attachment with a swiveling elbow and wheels on it. That is the one for tile floors.
Marci
Jun 19, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
How do you access and then repair the cord winder on an electrolux canister vacuum cleaner?
Is it the long type, 2 wheels on the back, one swivel wheel on front?
Aug 02, 2008 | Electrolux Vacuums
Vacuums Logo
29 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
