I had a speaker next to it and now the colors are bad
  • 749 Answers
Check the menu by pushing the buttons on the monitor until you see one named "degause" you may need to run this twice to correct the screen. most crts have this feature built in anymore.
Posted on Oct 15, 2008
My speakers sometimes work, and often not
It's a bad connection or bad speakers. Check your wires
Dec 11, 2011 | Genius SPF120 2 Speakers
I dont kno the wiring colors for my 2000 taurus radio
All you need to do is get the power, ground, and antenna hooked up then start with two colors matching, example: one purple and one black with purple line hook those up to a matching speaker wire then turn stereo on and go to balance setting choose back left if speaker does not sound then go back right and if speaker does not sound then try front speaker right and then left once you find correct speaker move on to next two matching remember to. Mark wires FL or fr or bl or back right. Good luck
Sep 10, 2011 | 2000 Ford Taurus
Hi people, so i want to install a aftermarket stereo in my 83 caddy sedan deville but i dont get the wires can somebody tell me do i need to use all the wires that the caddy has to put a after market...
Hi, please check to see if your colors match the ones below. If yes, then connect them to the aftermarket colors shown next. Assuming your factory installation has only four speakers, there should not be a lot of wires left over.
1983 Cadillac De Ville Stereo Wiring, aftermarket stereo wire
Car Radio Battery Constant 12v+ Wire: Orange, yellow
Car Radio Accessory Switched 12v+ Wire: Yellow, red
Car Radio Ground Wire: Black, black
Car Radio Illumination Wire: Gray (tape off), none
Car Stereo Dimmer Wire: Brown (tape off), none
Car Stereo Antenna Trigger Wire: Pink, blue
Left Front Speaker Positive Wire (+): Tan, white
Left Front Speaker Negative Wire (-): Gray, white/black
Right Front Speaker Positive Wire (+): Light Green, gray
Right Front Speaker Negative Wire (-): Dark Green, gray/black
Left Rear Speaker Positive Wire (+): Brown, green
Left Rear Speaker Negative Wire (-): Yellow, green/black
Right Rear Speaker Positive Wire (+): Dark Blue, purple
Right Rear Speaker Negative Wire (-): Light Blue, purple/black
Jun 25, 2011 | Car Audio & Video
I have no audio on my pc
1. Check the volume control (which you will find in the lower right corner of the screen, next to the time of day). Make sure it is not muted.
2. If the speakers are powered, make sure they are turned on.
3. Make sure the speakers are plugged into the correct socket on the back of the PC. Most connectors are color coded, and the colors of the plug must match the color of the socket.
Jan 25, 2011 | E-Machines T3410 (RBT3410) PC Desktop
My 51" sony rear projector has blue shadow on image. pictures are fine but it has blue shadow. how can I fix that?
Clean the mirror or the blue color gun. You may have it next to a powerful magnet from a speaker system that can also distort the blue. If thats not it it may be bad convergence ICs
Mar 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Dell XPS M1210 laptop was set next to a speaker and now the bottom half of the screen is grey
It's due to the magnetic field interferences from the speaker. At the first place, you shouldn't keep it near the speakers.
Always keep speakers far away from the Monitor.Now turn off the monitor and turn it on again,hope it solve the problem. You may even need to restart the system.
Moving magnetic fields (such as from an electric motor) can cause flickering when near a CRT screen. A static magnetic field, such as from your computer's speakers, can cause color shifts or incorrect colors in the area near the magnet. This color shift is caused by parts of the screen becoming magnetized. Occasionally the color shift will remain after you remove the source of magnetism. To help reduce or eliminate the color shift, you can use the degaussing option on most monitors. Most newer monitors automatically degauss when you turn them on, while older monitors might require you do to it manually. Most monitors have a button or menu option that enables you to degauss it manually. Degaussing a monitor will de-magnetize the inside of the monitor, removing the color shift. Unfortunately, if the monitor is exposed to the source of magnetism for too long, degaussing will not be able to clear it up, requiring you to repair or replace the monitor.
Feb 08, 2010 | Dell InspironTM XPS M1210 Notebook
My video works and i here people talking but they cant here me.
Vista mic set up
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} TEST SPEAKERS
Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Aug 25, 2009 | Logitech QuickCam Communicate Personal Web...
Power cuts off after a second after turning on.
There is a very good chance that you have a channel where the output transistors are shorted. Remove the top and pull the center colored ribbon cable going to the power amplifier section. If your display stays on, this is the problem
Jun 02, 2009 | KLH R5100 Receiver
Connect speakers to computer
You want to look for 3 colored ports on your computer if it is a desktop
Green - Headphones / Speaker Ports
Blue - Audio In (from CD player or other device)
Pink - Microphone
You will want to take the plug from your speakers and plug it into the Green spot on the back of your computer.
If you have a laptop look on the front of the machine (usually) again you should see 3 connectors (May not be colored) but there will be a symbol next to each jack. You want to look for the speaker symbol .
Plug your speakers into there
let me know if this helps.
May 25, 2009 | Acer (90.18612.36B) Computer Speakers
Need to know what wires are the back and front speakers
easy to check out bro get some power to your tuner give it half volume even if its just radio static -adjust the fader to the front only and plug the speaker leads into the different colored wire groups -one group at a time -if i remember correctly there should be 4 color groups white/white-black and grey/grey-black should be your front left/right and green set should be rear along with a purple but if you arent sure then do like i said and just fade to the front and hook up a speaker to each color group -the 2 groups that work now- are your front leads-you can then determine left from right by adjusting the balance.label your leads with some tape and a marker for next time and good luck
May 02, 2009 | Car Audio & Video
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
