Question about Canon FAX-JX200
Problems sending fax.
HI There,
I have tried to send numerous amounts of fax's and not one has gone through. I get the same error message 0003 every time? How do I rectify this problem.
Cheers,
Sheldon.
    Genius:
  • 2,120 Answers
Plug a regular phone into the wall jack and listen for a dial tone.
make sure the phone cord is in the LINE jack of the fax.
Posted on Oct 25, 2008
Hi my name is lionel whenever i try sending a fax line error message comes up fax does not go what is the problem. thanks
To activate it you should install the fax program. this will require that you register your fax adress.
this is a requirement of utilizing the system of sending and recieving Fax.
Just fill in the information as requested, and it will register your Fax adress.
As soon as you hav ecompleted this,you will be able to send and recieve fax,
and no more error messages, unless ther is a technical problem.
Feb 02, 2010 | Dell 966 All-In-One InkJet Printer
Cant Send or Receiver. Message says Check Printer
Any numerical code displayed with 'check printer'?
Dec 16, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
Hi, Remote Fax Error being displayed
Set the DRPD in the settings to 9600 and then try send a fax ...
Jan 29, 2009 | Dell 924 All-in-One InkJet Printer
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
What happens if you dial the remote fax number as a voice call on another phone? Does that number pick up? Does it give you the modem handshake noise? If not, the remote side has a problem.
Can you fax other numbers? What happens when you dial your own fax line from another phone? If your fax does not pick up and talk to you, your fax may have a problem.
Jul 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
Brother fax machine 8360p
It seems that someone has sent a large fax that has filled the memory. What they may have done is accidentally programmed one of the buttons to send to #342. This is easily done, if those keys are pressed and then an empty program button is pressed right after. You will have to remove the program from the que 1st of all, then remove the program from the button.
Jun 09, 2008 | Brother Office Equipment & Supplies
Error message
Try to send the fax at a different time when telephone line conditions have improved.
Or try to disable the ECM on yuor printer, to do that to these steps:
Press SETUP
Press DOWN until you ADVANCE FAX SETUP displays
Press OK
Press DOWN until ERROR CORRECTION MODE displays
Press OK
Press RIGHT ARROW to turn it off
Press OK
Then try to send new fax. If this does not resolved your issue pls try to go to your phone provider. Thanks
Oct 26, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Sending fax
NG STANDS FOR NOT GONE , TYPICALLY THIS MEANS THAT THERE IS A COOMMUNICTION ERROR AND THERE IS ALINE DISTURBANCE /NOISE DURING THE CONNECTION WHILE SENDING THE FAX MESSAGE. TRY CHANGING THE TELEPHONE LINE IF IT IS AVAILABLE. HAPPY FAXING OMNIPRESENT
Oct 02, 2007 | Brother IntelliFAX 4100 Laser Fax
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Canon FAX-JX200 Logo
old marine
old marine
