Question about Epson Stylus Photo R220 InkJet Printer
BLANK paper some time befor my printer R 230 in the head choke .than I replace a new head. I have use a ink supply system.the ink running and print procces is complet . BLANK PAPER PRINT after the print .new head is complet in other printer.what I need reset soft
    Sergeant:
  • 352 Answers
Hi ankita, this will update your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Posted on Oct 15, 2008
I have a Agptek receipt printer, i replaced a paper roll but the prints are blank
As a rule some printers use thermal paper and if the paper is installed inside out (Backwards) the wrong side is against the print head. If it is an INK system, the ink is dry.
Feb 05, 2018 | The Office Equipment & Supplies
My Dell A920 prints blank paper.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 01, 2012 | Dell A920 InkJet Printer
My printer print without no writting , paper just come out blank and it's new ank model hp d500
Hi, If you didn't used your inkjet printer for a long time the most common problem is that the nozzles of the print head are clogged with ink, so no ink can go down to the paper and that's why you see a blank sheet of paper. What you can do is Deep Head Cleaning from the printer properties menu a couple of times. If this does not help you will need to replace the print head
Sep 14, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Ive a kodak printer esp 7250 i have used it a couple times to print off my photos and its been fine,i got the printer out today and put new ink in ready to photo copy and it is not printing for some reason...
How long was the printer stored before you took it out to use it? You can't store a printer with or without ink cartridges in it. When a printer sits, the ink that is in the print heads settles and dries. Once that happens, the print heads are pretty much ruined. You can buy new print heads, but its usually cheaper to buy another printer instead. The reason it is not printing is probably because the print heads are plugged.
May 12, 2011 | Kodak Office Equipment & Supplies
Hi my printer won't print black, test colour work but no black, therefore all text to print is blank. I have replaced the ink with a new one and cleaned it 5 times, still no black ink. Thanks
Hi
Clean it manually by removing the black ink cartridge and rub the print head into a paper with rubbing alcohol until ink flows more. Then run the print nozzle to clean the print head thoroughly. After, try to print again.
If not, dip the print head only into hot water for 5 minutes and then run the print nozzle.
Let me know if you need more help
Mar 08, 2011 | Brother MFC 420CN All-In-One InkJet...
Just put 2 new ink cartridges in my printer - black and tricolor. the printer receives the message to print, sends the paper through and sounds like it is printing, but then the paper is blank with no ink...
Hi
Just remove the new 2 cartridges and rub the print head in a plain paper with isopropyl alcohol until ink flows, and then return the ink cartridges and run the print nozzle for 2-3 times. After that, try to print again.
Please let me know if you need more help.
Mar 05, 2011 | HP OfficeJet D135 All-In-One InkJet...
My Canon IP90 printer in printing blank paper
If the inkjet printer has not been used for some time, and the ink cartridges are full then the print head nozzles may be blocked. If running the maintenance nozzle cleaning does not clear the print head nozzles then the print head will need to be replaces.
NOTE - inkjet print heads are not cheap, it may be better to purchase a new injet printer.
Jan 16, 2011 | Canon PIXMA iP90 InkJet Printer
My printer is only printer blank pages? When it prints, it runs the paper through at a rate as if it was actually putting ink onto it but than the paper just comes out blank. Help!
Check the ink cartridges for ink level - it might just be empty. If you've replaced them with new cartridges already, clean the print heads with a "Q" tip and alcohol and run the "clean-cartridge" function in the printers properties.
Nov 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer will not print ,paper comes out blank
Put new in cartridges in printer.
Page prints out blank.
Have cleaned the print heads 3 times.
Need help!
Nov 16, 2008 | Epson Stylus C66 Inkjet Printer
Blank printout
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
