Question about Maytag Neptune MDE5500AY Electric Dryer
How do I open up my dryer, I need see what is wrong
I have a maytag neptune electric dryer that I purchased 2 years ago. it suddenly stopped working, it makes a loud buzzing noise when it is first turned on and than nothing happens. I think that something may have jammed the moter, My question is this.. How do I take it apart? It does not appear to have any kind of a pannel on the frount or back. It seems to be one whole unit. I was told that I should unscrew the back or frount peice, but when I unscrewed the back, I relized that there is nothing to remove. Does any one know how these newer machines are constructed, the model # MDE5500AZW
  • Anonymous Nov 20, 2008
    i have a ge profile dryer and i want to get inside to fing out what the sqeaking noise is... but i dont know how to get inside
  • Anonymous Jan 10, 2009
    I have a Model MDE5500AZW too and on the short baffle inside the drum 2 of the screws have come out and I would like to open it up to replace the screws but the I don't know how to open it. The diagrams are helpful for the parts but don't explain how to open the machine to get inside. I really need a more step by step of how to get inside. Thank you very much in advance for all your help.
  • Maytag Master
  • 19,396 Answers
If you click here you get all diagrams for your dryer, that is a great help when you need to take it apart.
Posted on Oct 15, 2008
My Neptune all of a sudden has stopped blowing hot air , I have had all the setting correct.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune dryer timer won't stop
If the timer is not stopping as it goes around then it's for sure the timer. The timer does pretty much all the work with controlling the dryer. And if it's physically not stopping going around then it has broken.
Jul 08, 2008 | Maytag MDE2600 Electric Dryer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Is there a reset button?
No reset button.
Probably a bad thermal fuse located on the blower housing.
Jul 07, 2010 | Maytag Neptune MDE5500AY Electric Dryer
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
heatman101
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dryer is making a loud noise as it tumbles.
you need to open it most of the dryer need maintanace every 4-5 yars and if you keep runing it you may do more damage.
there are several parts that the drum is turning on them and they get bad after few years. like felts,riders,belt...
Apr 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune dryer is squeaking loudly. Belt was replaced 2-3 years ago. What else could it be?
berring in rear of dryer that the durm ride in. That is where the squeeking is comming from
Sep 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer door will not open
only the washer has a main bearing. the dryer only has bearings in the motor and still would not cost 1,000 to fix. did you door issue get fixed? Joe
Nov 13, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Neptune Dryer
the belt needs to be replaced. open the front of the dryer, remove the bulkhead and install belt. or call your service guy and have him do it
Sep 04, 2008 | Maytag Neptune MDE5500AY Electric Dryer
The heater and timer do not work
The timer won't advance unless te clothes are drying with heat.(No heat, no movement).
Check your fuse or breaker box to see if you have a tripped 30 amp breaker,(Flip breaker OFF then back ON), or blown 30 amp fuse.(Replace both 30 amp fuses to eliminate the possibility of being wrong).
If these check ok,(be certain), then you have a breakdown on the heat side of the 240 volt circuit, at which point, I would recommend calling a technician.
Let me know if I can be of any more assistance.
May 26, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
1,141 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
