Question about HP Officejet Pro L7590 All-in-One InkJet Printer
Can't get the HP Officejet Pro L7590 AIO to Install Properly
I cant get this machine to install properly regardless of what I do! I am using a USB 2.0 cable as directed. The system will not install properly and fully through the scanning, document imaging system software, etc.. either by the cd or by downloading it from the hp website. I get plug and play errors, installer errors, etc... HELP!!!!!!!!!!!!!!!!!
  • dlc12 Nov 30, 2008
    Well now what? I've installed the software, it didn't see the printer, I told it to continue to install the software, the Windows system does not see the printer. The Plug-n-pray auto wizard doesn't fire up, I can't see it in the device list. Nothing.
    I'm ready to pull it and send it back after I vacuum all remnants of the software from my system.
When you are installing the L7590 you will get a screen that ask you if you are hooking up usb or ethernet. click usb. then the next screen will detect the printer do not plug your usb clble into your computer until this screen. I have found that if it gets past step 5/8 you shopuld be good. However it might still error out on step 5. I have installed many of these and got the same error many times and found that this is the best solution i have found.
Posted on Nov 08, 2008
  • talk2lock Feb 24, 2011
    how did you get past step 5?
How i can print in I pad2 with wireless printer
you can only print from an ipad using the airprint app if you have one of these printers read more about it here http://www.apple.com/ipad/features/airprint.html
    May 02, 2011 | Apple iPad 64 GB 3G Tablet PC
    Scanner error in HP officejet Pro L7590
    These instructions will fix the majority of scanner problems and networking problems using ethernet:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01849855&lc=en&dlc=ro&cc=ro&product=3643612&rule=4124&lang=ro
    The key is to assign a static ip address for the printer. The install problems of trying to get the HP printer to be found will go away. You can then use the scanner. Also...it is crucial that when connecting other laptop's and PC's on the same network that you use the hp printer'rs host name to find the printer on the network. I find that the IP address can and usually fails to find the hp on the network. Mostly likely you cannot search the network for a hp printer until you go the route of find the hp network printer with the host name of the printer. You will also need your install disk when installing on other networl laptop's and PC's since windows xp and Vista machines don't have the drivers in the list. You will need to point the add printer gui driver to the disk and look for autorun.inf
    file. After selecting that file...you can then see your drivers.
    May 14, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
    Unable to input a destination for the Button Settings Tab
    Even if the printer installs OK, the scanner is not allways recognized. Try to look for new hardware>scanners in Control Panel. It migth want the HP CD or the driver from www.HP,com. Or find a picture editing program and File>Import>HP officejet Pro L 7590 AIO- twain! That works!
    Mar 05, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
    Red is printing very light and streaking. The other colors print
    1.clean the printer head using printer service utility
    2.Buy a new catridge and fix it
    note: if you are not use the printer the ink will be dry.so it cant able to print
    Feb 12, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
    HP Officejet Pro L7590 AIO, manual needed. I don't want to have to print the whole thing, just to buy one
    Download one for free from http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3643612&cc=us&lc=en&dlc=en&product=3643612
    Oct 30, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    Scanner does not work It keeps telling me "no conncetion to computer" but the printer is conected . I can copy from the computer. Wher can I find an instruction manual for Officejet Pro L7590 My last HP...
    The Driver of the scanner and driver of the printer, this two miscellaneouses of the driver, in addition is fixed. Attentively install both drivers with mounting disk. Else use the cable USB from kit of the supply, scanner can not work since long шур USB.
    Sep 25, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    Cannot find printer L7590 to install on my computer
    Below is HP website for your print driver. Download it, install it, and select the fewest amount of software functions you possibly can.
    http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2100&lc=en&dlc=en&cc=us&lang=en&product=3643612
    Jun 30, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    Software Installation Problem
    I understand your concern that you are unable to remove previous HP drivers installed on your computer. To resolve this download the HP software removal utility and run the utility.
    Click here to download HP software removal utility.
    NOTE: Select your OS and select HP software utility At bottom and click on download only. After dowloading run the utility for four times to remove the HP printer software completely from your computer.
    After running the utility four times restart the computer and check whether HP Imaging folder is completely deleted or not which as located in C:/progra files/HP Imaging folder. If the folder is not there then the software is removed completely from your computer and continue to download the Full Feature software from the same link and install it.
    Now try to scan from HP solution center. This should resolve the issue.
    May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    HP Officejet Pro L7590 All-in-One InkJet Printer Logo
    296 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
