Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KV36XBR800 standby blinks 4 times
I've got a 5 year old Sony xbr800 which isn't powering up and the standby LED is blinking 4 times. I know the problem is on the D board, but can someone pin it down a bit more and maybe narrow it down to couple of components so that I can try to fix it myself ?
Thanks
  • Towhid Oct 15, 2008
    Thanks for your suggestion Dan!
    Do you know which board I need to look to resolder this IC ? Also is there another part number for this ? I couldn't find LA7837 in the manual, and just in case I need it I'll have to buy it from somewhere.
    Thanks!
    Towhid
  • 4,234 Answers
The 4 blinks usually mans that there is no vertical deflection signal. Look for a small flat Ic with about 11 pins that may be marked LA7837 or something similar. Resolder the pins on that first. If that fails to resolve it, replace the IC.
Keep me posted.
Dan
Posted on Oct 15, 2008
  • ABRsvcs Oct 15, 2008
    When you find the vertical Ic, it may be another part number. I'm doing this from memory and don't know all of the numbers for all sets. Also, the marking is the generic part designation, the Sony manual will only have the Sony part number. Post the actual marking here and I'll confirm that you have the correct part. Purchase it from a generic supplier and you will save over 50%.
    Dan
Hi I ve a sony KDL-40W2000 stuck on stdby red light flashing 4 times the stop for 3 second ??any advice please
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 16, 2014 | Televison & Video
KV36XBR800 5 blinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Apr 23, 2014 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KDF-42WE655 Won't power on. Red Power/Standby light blinks 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 21, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
Jun 02, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Apr 22, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
HELLO I HAVE A SONY 40XBR800 TV. WHEN I POWER THE TV ON THE STAND BY LIGHT STARTS BLINKING AND THE TV DOES NOT COME ON
My Sony XBR800 won't start and the standby light blinks 7 times with a 3 sec. interval before blinking again.
Aug 30, 2009 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Television
You probably just need a new lamp. If your tv is that old, im sure you do. I just got a new one from Projector Lamp Services (relampit.com) it works great... Only took me a few mins to install it too. I missed my TV!!!
May 21, 2007 | Sony XL-2000U Projector Lamp for XBR800...
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
318 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
