Question about Whirlpool Refrigerators
I have a whirlpool fd5jhaxt0oo side by side purchased in April 2007. It is getting hot on the front of the separation panel between the freezer and fridge (the part touching the gasket). I have taken off the bottom front grill and vacuumed the parts that I can reach, but would like to know if I am searching in the right place for a remedy. Can you help?
    President:
  • 1,462 Answers
This is normal. some of the hot pipework is routed across the transom to prevent condensation
Posted on Oct 15, 2008
Refrigerator warm, Freezer cold
This might indicate loss of refrigerant. If so, you must replace. Check the front of the bulkhead separating the compartments, if too hot to hold your hand on it, check underneath to see if the fan on the condenser coil is blocked. I found a mouse had committed suicide in one.
Dec 01, 2013 | Whirlpool Refrigerators
Overheating of Partition in a side-by-side
pull off the bottom front kick panel and check the condenser coil to see if it's filled with dust,also pull out the machine and remove the back bottom panel and make sure the condenser fan motor is running and clean out any dust back there,if the coil is clogged with dust or the condenser fan motor isn't working is what could make that strip hot.
Aug 30, 2012 | Whirlpool Refrigerators
Middle panel hot to the touch
This is an indication that the condenser is overheating. It could lead to problems if not addressed. I have put together some instructions on how to remedy this. Follow the link and let me know if it helps.
http://www.fixya.com/support/r4694132-hot_door_seal_rail_divider_strip_between
May 12, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The panel between the freezer and refrigerator heats up - too hot to touch for a while then cools off again. GD5SHAXLT01
You need to clean the coils under the front of the refrig of dust , lint , pet hair , etc . Pull the refrig out and remove the back panel covering the compressor . Make sure the fan there , next to the compressor is working . Usually , if this fan is not working , the center strip gets very hot , and the compressor may cut off , from getting too hot . The compressor can burn out , if the fan doesn't work for a while .
Sep 13, 2009 | Whirlpool ES5FHAXS Side by Side...
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Dec 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Extremely hot panel between freezer and refrig sections
Usually is not a fire danger however there is a problem that needs attention. I would recommend that you call a qualified service man for this one as soon as possible.
Nov 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Side by side refrigerator by whirlpool
try vaccumming under your frig coils, and pull away from the wall and clean under there too. i would check to see if the fan behind the unit is spinnig( its suppused to cool the compressor) if its not youll need to replace that.a pretty common problem easily fixed
Oct 25, 2008 | Whirlpool Refrigerators
Whirlpool Side by Side - Overheating
HI thanks for your question. the heat between the two doors is normal. its heated there to stop moisture, from hitting a cold surface , and turning to water, so its normal. but pull fridge away from the wall. remove the back panel by the compressor. clean all coils. thanks the appliance doc. please rate my answer. thanks
Oct 13, 2008 | Whirlpool Refrigerators
Refrigerators Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
