Ihave DVD player260 of pioneer and it does not read my DVD R of MADE IN TAIWAN THE COPIED DVD
Most DVD players have a copyright, it could also be that it's not compatible with your player.
Posted on Oct 15, 2008
Pioneer region code
When a DVD disc is created, it is encoded with a "Region number." The disc will only play on DVD players with the same Region number - for instance, a Region 3 disc won't play on a Region 1 player.
Region 1: U.S. and U.S. Territories, Canada
Region 2: Japan, Western Europe, Middle East, South Africa
Region 3: South Korea, Hong Kong, Taiwan, Southeast and East Asia
Region 4: New Zealand, Australia, Pacific Islands, Mexico, Central/ South America
Region 5: Russia and the former Soviet Union, Africa, Indian
subcontinent, North Korea
Region 6: China
The only way to get around the region codes, is to rip a DVD to your computer and remove the region code. Then burn the DVD to a DVD R. There are programs around on the net, but I'm not sure it is legal in all countries.
Google for the programs.
A DVD player sometimes allows you to change the region code once. But it not even would allow you to switch back after you changed it once.
Jul 27, 2014 | Pioneer DV-400V DVD Player
What format is used when the VHS is copied to the DVD ? I have copied the VHS tapes onto Verbatim DVD-R discs. They will not play on my computer. Verbatim says I need to know what format they are in...
the most common in the US is NTFS. another used in other countrys is PAL. the format is seperated into regions, and they are as follows,
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
you can use MAGICdvdRIPPER softwareon your computer, it works with NTSC, and PAL formats and vice versa.
Jan 28, 2011 | Samsung DVD-VR320 DVD Recorder/VCR
My Pioneer AVIC-D1 Won't play Dvd's
avic-d1 is a cd player it is not a dvd player
Mar 07, 2010 | Pioneer AVIC-D1 In-Dash Mobile Navigation...
My dvd player won't read copied dvd movies but willl read store bought dvd movies in the device manage is says "unable to recover TOC error 0x13570001
one answer is to format the movies after you record them on dvd player. They would then be more likely to be read by the pioneer dvr.
Mar 01, 2010 | Pioneer DVR-107D DVD±RW Burner
Avic-n3 pioneer
Ebay has copied version for around $15. But many of the copied discs are poor quality and malfunction after a short time. Goodluck.
Oct 07, 2008 | Pioneer AVIC-N3 Car DVD Player
Avic X1r will not read navi disks
I have had quite a few problems with copied discs not reading and it is usually the disc's but however in your case if you know the discs work on another unit then perhaps a later version of the discs were tested when the unit was repaired and therefore your earlier discs would not be recognised by the unit, and therefore your unit needs to be reset and i'm afraid this is not something you can do yourself, speak to northolt and see if this is the case.
Mar 15, 2008 | Pioneer AVIC-X1R CD Player
WONT PLAY COPIED DVDS ANYMORE
were you able to play copied dvd's on this unit ? if yes then check setting on the dvd menu for things like DVD REGION and DVD playback speed and types of DVD playable, this is quite likely as i ha this problem on a pioneer model previously.
do those copied dvds no longer play on the same unit ? and you have tried them again on another unit or dvd player ?
rather i suspect problems with the DVD burn itself and its compatibility with the dvd player you are palying them on now (asuming settings in DVD enu are correct as loosely outlined above in point 1)
it may be that if this is a new dvd player than the one you played them on before, the dvd's may have to be closed in a certain way using your burning software so that they are playable on standard dvd players.
please also check that region is not an issue and that the recording speed of the dvd (the rip speed) is not too high or too low for your unit, as this data is stored on the written dvd and is responsible for the quality of the palyback data.
Mar 08, 2008 | JVC TH-M303 System
PIONEER DVD-RW DVR-112D problem
have you tried cleaning the lens? i also had this experience with my dvd rom and what i did, was cleaned the lens.
tell us what happen after you clean it ok.
Jan 14, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Won't playback copied dvd's, only commercially made ones.
Read here and we can see that other people have both trouble and success running back ups on this device: http://www.videohelp.com/forum/archive/anyone-experienced-with-b-u-s-playing-on-a-sony-dvp-s7000-t283487.html So... That tells us this device is finicky IE it requires a high quality burn. DVD burners have varying levels of accuracy. To improve your burn: -SLOW the burn speed for increased accuracy -USE DVD-R only as it is the most compatible -Use those Sony's DVD-r's at wal-mart or KMART because Sony makes DVR's and everyone else buys them from generic Taiwan manufacturer and relabel I bet this will solve your problem. After you get a successful burn at 2x try 4x then 6 etc.
Aug 27, 2007 | Sony DVP-S7000 DVD Player
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
