Question about Refrigerators
GE Side by Side: GSS221BPCWW Cooling Problem
I have had the repair guy out three times, this week will be the fourth. It started out with the freezer not freezing and then the refrigerator not cooling evenly. First he vacuumed the back and thought it would be fine with proper air circulation, then he replaced the motherboard which was burnt out then inside the fridge side the component with the mechanical flap to open and close to let air in was replaced. As of today, the freezer is fine, the refrigerator is not cooling at all, barely tepid. The repair guy is due back this week, any suggestions before I poison someone with spoiled food. Thanks for your help in advance.
5 Suggested Answers
mikedurland
  • 481 Answers
SOURCE: Maytag MSD2651HES fridge not cooling freezer works find
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
docjohn174
  • 943 Answers
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Posted on Oct 15, 2008
  • 50 Answers
SOURCE: freezer is cold, fridge is barely cold, even on
http://www.fixya.com/support/t2786742-freezer_freezing_great_fridge_not
check this for a possible fix
Posted on Aug 18, 2009
woodchuck789
  • 4070 Answers
SOURCE: Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Posted on Jul 13, 2010
My GE side-by-side is not cooling.
The electronic control board is probably your culprit. These control boards control the compressor, fans and defrost. Look for any burned spots on the printed circuit bout it could be just bad.
May 11, 2014 | GE GSS25SGPSS Side by Side Refrigerator
The pool timer goes on, the hayward 2 HP pool pump turns on and then causes the circut breaker to pop. After two, three resets, it starts to work. This problem started a week agao. The pump is 9 years old.
could have a bad run capacitor or a start capacitor . search your area for your local pool pump motor repair guy with free testing, 9 years old that motor needs to be rebuilt.. i charge 85.00 to rebuild a 2hpincludes a free shaft seal.. remember to prime the pump with water after a repair !! best of luck .. oh breakers become week after amount of time time .. and ask the repair guy if this is the right size pump for you pool.. 9 out of 10 times its way too big !.. jay longwood florida
Sep 08, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
My refrigerator won't stay cold. The freezer is working but not the refrig side
I have the GE Monogram ZISB480 side by side. Once again I have your same problem of the freezer freezing (good), but the refrig does not go below 45-50. All the official repair guy did was do a quick 1 hour defrost. I did that also just two weeks ago and it was fine. Now it is not cold enough again. I just looked in the freezer using a mirror I was able to push a 2"x2" trap door open towards the fridge. It must be automated and malfunctioning. Why the heck the repair guy didn't work on that? This week I'll call for another repair job ($85 for him to just come to my door) and ask him to fix the trap door. -Bob
Nov 14, 2010 | GE Monogram Side by Side Refrigerator
About every two or three weeks the temperature rises to about 15 F in the freezer. Temperature also rises in the main part.
Defrost timer/control board is sticking...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator seems to just turn off for a day or so every two or three weeks and all the freezer items melt. Kicks back on after some time and works fine for another 2-3 weeks then repeats. Have unplugged...
Most Refrigerators have a defrost timer which cycles every couple of weeks, typically for several hours, in order to let any residual ice melt from the cooling system. If yours cycles long enough for the freezer items to melt, it should be replaced.
Nov 02, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Ge side by side not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
gfhjsf
Jun 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side refrigerator has stopped working...
sound to me that the unit may be stuck in defrost. look for the time clock and or if it is a newer unit check your condenser coil it may be dirty. the unit may also have a leak on the refrigeration side of it.
Dec 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ge side by side refrigerator
MOST TIMES ON NEWER GE FRIG.'S THERE ON THE BACK OF FRIG. UNDER BACK PANEL OR INSIDE UNDER THE THERMOSTAT PANEL OR BEHIND THE FRONT BOTTOM GRILL OR ON THE LOWER BACK BOTTOM,ANY STARDARD VOLT METER WILL DO BUT IF YOUR GOING TO GET ONE GET A GOOD ONE WITH THE AMP CLAP ON IT SO YOU CAN MEASURE AMPS TO(LOWES),BEFORE YOU BUY ONE YOU CAN REMOVE THE BACK PANEL AND LOOK AT THE HEATER, IF IT HAS TURNED DARK IT IS BLOWN AND YOU NEED NOT BUY A METER UNLESS YOU WANT ONE,PLEASE LET ME KNOW HOW YOUR DOING-MIKE
Jun 25, 2008 | Refrigerators
GE side by side refridgerator
you need to check the defrost heater with a omes meter,ge sxs are very bad about heater burnout and most must be replaced with a heavy duty one,let me know,thanks-mike
Jun 23, 2008 | Refrigerators
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
