Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
GeForce6100SM-M Intermitently Shutsdown
Does anyone know where i can try to update the bios to support AMD 6400+? I bought this mb and cpu at Fry's and they assured me it would work. Everything works great, but when i try to burn a cd/dvd or access SATA or IDE sometimes it just shutsdown intermitently. I checked CPU temp, viruses, updated bios to 6.00PG (5/23/08), downloaded the suggested nVidia drivers for mcp61, psu is good, memory checks out fine. I'm runing Vista 32-bit... when i run biosagent plus, it recommends a bios update, but can't find an update (according to ECS, i have the newest one). some posted it's the LAN causing sparatic shutdown, but i think it's something else... can anyone help?
  • 905 Answers
If there is a problem with one of the devices connections , or one of the devices chips are failing it will cause a shut down to protect the rest of the circutry.
try disconnecting all but cd/dvd drive to see if this happens , then only plug the sata or other ide including the power.
if a virus is in bios , resetting the clr bios and removing the battery on the motherboard can remove it
if the local area network is causing the shut down you would have data transfer problems or slow communications,
and there could also be a problem on the board
Posted on Oct 15, 2008
    Genius:
  • 1,252 Answers
ALSO CHECK THE SMPS,RAM AND BUS CABLES
Cpu
AsRock Support > AlivenF6G-DVI Motherboard > Main Support page,
http://www.asrock.com/MB/overview.asp?Model=ALiveNF6G-DVI
In the list on the left hand side, click on CPU Support List
http://www.asrock.com/mb/overview.asp?cat=CPU&Model=ALiveNF6G-DVI
The AMD Athlon 64 X2 5800+ CPU, (Processor), is part number ADA5800IAA5DO.
Operates Up To a maximum frequency rate ('Speed'), of 3.0GigaHertz, has two L2 cache's of 512MegaByte, and uses the Socket AM2 CPU socket.
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#.22Brisbane.22_.28energy-efficient_65W.2C_G1_.26_G2.2C_65_nm.29
In the CPU Support :List it is not shown.
This is ONLY because the Athlon 64 X2 5800+, came out way after the CPU Support List was compiled. NOT because it isn't supported.
No, I have to amend that,
http://forums.amd.com/forum/messageview.cfm?catid=14&threadid=108319
It's because AMD's lack of information, apparently, that AsRock didn't list it.
I don't see the voltage range listed anywhere. (To include AMD)
http://www.cpu-world.com/CPUs/K8/AMD-Athlon%20X2%205800+%20-%20ADA5800IAA5DO.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103274
At any rate let's go with deductive reasoning, and see if this CPU is supported.
1) You can compare the Athlon 64 X2 5800+, to the other CPU's in the CPU Support List; that are comparable to it, and above it.
Don't even have to go too far.
Look at the ADA6000IAA6CZ, and the ADX6000IAA6CZ CPU's.
The two Athlon 64 X2 6000+ versions.
(Doesn't state that, just the above part numbers)
However I DO notice that the ADX requires BIOS version P2.00, and the ADA only requires BIOS version P1.60
(Since BIOS)
2) The motherboard chipset is an Nvidia GeForce 6100 and Nvidia nForce 430, Or Nvidia GeForce 6150SE and Nvidia nForce 430
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6100
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_chipsets#For_AMD_processors
Compatible? Yes.
May need the P2.00 BIOS update, if not already installed.
Regards,
joecoolvette
May 16, 2013 | Asrock Computers & Internet
Need bios update for amd dual core 3.2 or phenom 9600
Hello here is the homepage:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=498#cpu
Only the cpu on the list, will fit the mainboard.
Others will be not be compatible with the mainboard, and a bios upgrade will not help with that.
Good luck
Feb 07, 2013 | Biostar N68S+ Motherboard w AMD Phenom X3...
Can the ACER ASPIRE AST180-UA380B run an amd phenom x4 with the bios update available?
If your motherboard manufacturer support website says that the bios update will fix it, yeah go for it, though 330W isnt a lot most pc now are about 500-600w. Flashing the bios isnt hard and only takes seconds
Jan 26, 2013 | Acer Aspire™ T180 PC Desktop
Can a Biostar NF61S MICRO AM2 SE (NF61MICROAM2SE) Motherboard run a AMD dual core X2 7750 2.7
Hello look here for the cpu list:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=23#cpu
Try also to look in the manual.
I think it will fit, but you probably have to upgrade the bios, to support the new cpu.
Good luck
Dec 19, 2012 | Biostar NF61S MICRO AM2 SE...
CPU upgrade for ACER rs780hvf
you could upgrade to AMD PHENOM II X4 960T but you should probably try and overclock and save your money.
Apr 03, 2012 | Computers & Internet
TA790XE Ver 6.0 Have been running a 9650+ for a couple years. bought a 1090T and installed it. Bios is the newest and recognizes the CPU. Win 7 boots to the point the desktop starts and then goes to a...
Hi, here you can see a list of cpu that your mainboard supports:
http://www.biostar.com.tw/app/en/mb/cpu_support.php?S_ID=417
You maybe have to download a manual.
It will show you how to unlock all the cores at the cpu.
That means you have to enter the bios to make a setting
so the bios can work with the new cpu.
Aug 31, 2011 | Biostar TA790XE 6x AMD 790X Socket AM2 MB...
ASUS CUSI-M ACPI BIOS Revision 1007 run very slow when i wana use 1024 by 768 pixel.how i can solve this problem.my processor speed is 700 MHz. 2.is it possible AMD 1.3 processor connect with this...
Getting you're system to display 1024 x 768 resolution depends on the graphics card. If you’re using the onboard VGA you will have poor display.
Suggest you use a PCI (White slot) graphics card with its own memory onboard. You will also need to make a bios setting change so the system boots to the PCI card and not the VGA.
Asus no longer provides support for this MB including drivers and bios.
You're board also supports slot A (For AMD), processors.
Only Intel Celeron and Intel Pentium III. Socket 370
see link provided;
http://www.cpu-upgrade.com/mb-ASUS/CUSI-M.html
Max CPU supported (With out over clocking);
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20(BX80526F1100128).html
In order to run this CPU you would need to update the bios to rev 1009. You'll find rev 1009 at the next link; http://www.userdrivers.com/BIOS/Asus-CUSI-M-BIOS-1009-With-LAN/
From what I've read it is possible to Get an AMD slot A CPU into a socket 370 MB. (Don't hold me to this though. This is a first for an old dog.
Any one of these PCI graphics cards should function on you're MB; http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=28&sel=Detail;55_158_2872_2872
Hope you find this helpful
Mike
Jun 04, 2010 | ASUS SiS Chipset CUSI-FX Motherboard
I bought the sims 3 and it keeps crashing sayin display driver stopped working how can i update it
Here is the Dell's driver page for your laptop.
Insperon 6400
Select your operating system and the appropriate drivers for you video card.
If you do not know what card you have you can find it by entering devmgmt.msc in the run dialog box and looking under Display Adapters, or you can use an application such as SIW to find the information.
Simply running the .exe file and restarting should update your drivers. If you this does not work or you need more information on how to update your drivers please let me know.
Also, check to make sure that your system meets the minumum requirments for the game if you haven't already done so.
Laptop (Windows XP + SP2):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2000+ Processor
RAM: 1.5 GB of RAM
GPU: 128mb Video Card (GeForce Go 6200 or Radeon 9600)
Laptop (Windows Vista + SP1):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2400+ Processor
RAM: 2 GB of RAM
Jun 12, 2009 | Dell Inspiron 6400 Notebook
Abit ip95 mobo
You should really check these things first or consult the motherboard documentation which lists in great detail what the board supports
Get yourself a new manual if youve lost the one that came with it
ftp://ftp.abitshop.com/pub//manual/english/ip-95.zip
And to answer your problem , no you cant have a quad core
your specification says
"CPU - LGA775 Socket for Intel Core 2 Duo/ Pentium D/ Pentium 4/ Celeron D/ Celeron Processors with 1066 MHz FSB - Supports Intel Hyper-Threading Technology "
It would say "Intel Core 2 Quad" if you could
Try powering it up and it will probably either:-
a)Overheat
b)Spark and set on fire if theres not enough cooling
c) Cause a power cut , Quad cores take more power than the boards designed to support , otherwise they would have said i t supported quad cores.
d)Fry up the motherboard , making it useless
e)Fry up the processor , making it useless
f) all of the above
Jan 07, 2009 | Ziotek ATX Motherboard Standoff, 12 Pk...
AMD Athlon 64x2 can't install, help!
which version update did you do?
only after 0804 will work
FAQ from ASUS
My system may refuse to boot under AMD Althon64 x2 6000+ CPU (OPN :ADX6000IAA6CZ) with 2x DDRII-800 memory combination.
The same problem does not happen with other CPUs, nor would it happen with memory modules of any lower specifications.
How can I solve this problem?
Please kindly update motherboard BIOS to version 0406 or later to resolve this problem.
BIOS 0406 can be downloaded form the link below:
ftp://ftp.asus.com.tw/pub/ASUS/mb/socketAM2/M2N-MX%20SE/M2N-MX-ASUS-SE-0406.rar
Dec 02, 2007 | ASUS M2N-MX Motherboard
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
333 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
