Question about Acer X1160 DLP Data Projector, 2,000 ANSI, 2,000:1 Contrast Native SVGA - 800 x 600 res Projector
"no signal " on the screen
I have an Acer DLP, after start up of my PC it gives a "no signal" on the screen.... its probably something basic that I am not doing.
  • 1 more comment
  • teconrad Oct 19, 2008
    I'm getting the same thing. When I startup my computer, it connects and displays my screen loading, but after 10 seconds reverts to no signal.
  • davyboy0151 Jan 04, 2009
    no signal on the screen
  • Ruth6328 Apr 23, 2009
    I have the same problem but the solution below works. Thanks xxx
After half a day of tinkering around with my new Acer I fixed my problem, which I think is yours also. I connected it to my notebook, it read the signal 'D-Sub' or something like that, and after my notebook finished startup, it reverted to no signal. I tried it with my desktop and it worked just fine. The display will only show up on one output device. It worked fine on my desktop because I was unplugging my monitor in order to hook up the projector. Hooking the projector up to my notebook left the display panel still active and that was where it displayed. In case I'm not making sense, the solution is this: After setting everything up, hit Control+Alt+F1 to switch display from your screen to the projector. To switch back, hit Control+Alt+F3
Posted on Oct 20, 2008
Is it possible to fix my desktopPC?
Not compatible. Make a flash drive/CD rom of your OS and start again.
Aug 07, 2016 | Acer Computers & Internet
HP Screen Problem
dark screen and dead pixels is caused by the invertor or the screen.
new invertor are usually about 5-15pounds on ebay, new screen probably around 50 pounds,
try pressing the fn + one of the f1 keys that has a monitor image on it to switch to external display if it has.
Jun 09, 2012 | HP Computers & Internet
A screen saver is an executable file (scr) and it could also be a script meant to do your computer harm or steal your information. I would give this one up, it was probably something bad... be thankfull your system has protection in force!
Sep 01, 2011 | Acer Aspire One PC Notebook
My acer Laptop 5610Z on the start-up has a white screen i can hear the signals as if it has started up but cant see anything only a white screen?
You can try to connect it to an external monitor using the vga connector on the side of the laptop.
If that works, try and hold down the function button and press the F8 key. That should switch between the two screens. If the Laptop screen still does not come on, It is probably bad.
May 19, 2011 | Acer Aspire One Netbook 8.9" Notebook
Getting 'No signal ' response. What could be the reason?
try using a lower screen resolution on your PC,
Try checking that the signal you are sending to the projector is actually there
Apr 08, 2011 | Acer X1230 DLP Projector
I receive a no signal message on the screen
If you make sure the pc produces the correct resolution of picture for the projector otherwise it will have trouble connecting.
Mar 10, 2011 | Acer X1230 DLP Projector
Don't know how to turn it on
Check power lead,press the button on the right at the bottom of the screen if a light comes on then it is on. Start PC, light should go green and monitor should give a display. If there is no life at all then the monitor is dead, change it :( If the light is on but starting PC doesn't give a display then check lead from PC, try another monitor with PC and if it works change resolution to something basic like 1026 x 768 @ 60Hz then try the acer again. If another monitor doesn't work your PC has a graphics problem; Check the lead thoroughly, check in bios settings the display is set right, try a new graphics card
Aug 02, 2009 | Acer AL1916W 19" LCD Monitor
No signal or loses signal from computer
Keep the computer on when you plug it it
so have the computer ready
May 12, 2009 | Acer PD725P DLP Projector
Ive been having problems restoring my acer arcade feature. ive tried restoring it from the acer empowering tech, but an error keeps it from functioning properly. i just want to find out how to start...
If you're talking about setting your system back to factory settings, what you need to do is this:
1 - When you turn your system on and the screen shows the ACER logo, press F2. This will bring you the the BIOS screen.
2 - Have a look through and find the option called D2D Recovery, make sure this is set to Enabled. Highlight it, and look at the right-hand side of the screen. It will give you a list of keys that you need to press, i.e.Ctrl+Alt+F10. Make note of these.
3 - Save the changes and exit. The system will reboot.
4 - When the screen shows the ACER logo, press the keys that you just made a note of. This will take you to Acer's eRecovery program. Follow the instructions to restore to factory.
Hope I have been of help.
Dec 08, 2008 | Acer Aspire 5610-4648 Notebook
Acer X1160 DLP Data Projector, 2,000 ANSI, 2,000:1 Contrast Native SVGA - 800 x 600 res Projector Logo
844 people viewed this question
Top Acer Office Equipment & Supplies Experts
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
