Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Frigidaire Refrigerator is warm on top of the frig and freezer but fine on bottom.
A few days ago there was a power outage on our side of town for about 30 minutes. The next day I noticed my frig and freezer were warm on top but fine on bottom. I don't know much about frigerators but need to try to fix this myself cuz I just had to buy a new washing machine so can't afford a service call right now.
    Brigadier General:
  • 6,966 Answers
Initially, Pls confirm the model number of your unit.
Alternately and assuming that the freezer is working as expected and it is only the fridge that has an issue. A few basic/working ideas:
  • most designs call for a single compressor to cool the freezer;
  • the cold air in the freezer is drawn towards the fridge to cool that area;
  • this is performed by a fan drawing air in the freezer through the evaporator;
  • most would have a vent or air pathway to guide the freezer air;
  • all would have thermostatic control to set the desired temperature;
  • some designs have two thermostatic control , 1 for the freezer, 1 for the fridge.
As applied to your concern:
  • compressor is working since freezer is OK;
  • pls verify that the fan is turning drawing air from the freezer side to the fridge side;
  • additionally check that the air is strongly blown into the fridge area;
  • a little experiment, open the fridge door, look for and press on the door switch, the light should go out, after a lengthy seconds, the fan should trigger on, not only would it be audible, you would notice the frozen air swirling inside the fridge area. If you hold on long enough to the dorr switch, the compressor should kick in (if it is not already running) since the thermostat of the fridge area (if one is present) would sense that the fan is turning but the fridge area is not cooling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 15, 2008
    Genius:
  • 1,847 Answers
Remove the rear lower panel on the unit check to see if the compressor is hot or if its running, should feel the vibration, also listen for any clicking noises.
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
The freezer is icing up up and the frig is warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 08, 2010 | Frigidaire FRT17B3A Top Freezer...
Frig too warm, freezer too cold
if there is ice build up you have a defrost problem. either the heater bimetal thermostat timer or evap fan could be bad. you could also have a stopped up drain. if the coils get too much ice build up the air wont beable to travel through them and the bad air flow will cause the fridge to become warmer
Sep 16, 2009 | Frigidaire FRT8S6EMB Top Freezer...
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Frigidaire refrigerator is warm on top of frig and freezer but fine on the bottom of both.
i suspect the fan is not working. take the back panel off inside the freezer and check that the fan is free to rotate, check for continuity thro the fan motor and check you have power to the fan
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
Warm side by side freezer and fridge
hi thanks for your question. i would clean the coils at the back of the fridge. it could be just dusty try that
Aug 23, 2008 | Jenn-Air JCB2388G Side by Side...
Side by side frigidaire
check the evaporator fan motor, behind the back wall of the freezer. If that is turning check if the damper is opening, top lt of the refrigerator compartment. I hope this helps you.
Jul 09, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frig runs but not cold
sounds like the beggins of a defrost promblem open your freezer and look at the back wall of the freezer cabnit and see if there is heavy frost there let me know and how old is it
Jan 13, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
196 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
