Question about Jl Audio 250/1 Car Audio Amplifier
Jl audio 250/1 thermal light
The amp was installed in my truck about 6 monthes ago on day while in use the thermal light came on everything say when temp goes down it will start again its been 2 weeks of not bein used and still wont work is the amp fried or could a blown speaker cause this chaos i have blon amps and sub b4 there was any smell when it stop workin from speakers or amp
I was having issues with this amp as well, the thermal light was flashing every couple seconds. i checked all the connections and i discovered that when i pulled the power wire out the thermal light was still flashing, which tells me that there was no power from the power wire, but it was getting power from the remote wire. i know this because it would stop flashing when i removed the remote wire. but wouldnt start when i didnt connect the remote wire but connected the power wire. so with the power meter i checked the fuse and it was a little loose so i screwed it back in and the amp turned right on.
to make a long story short, a flashing thermal light is a power supply issue.
Posted on Jul 27, 2009
The power to my 250\1 JL amp stays on even when the ground is disconnected. it should shut off right? what do i do?
Posted on Mar 17, 2009
  • 631 Answers
Disconnect all speaker wires from the amp and disconnect the RCA cables from the amp. If it still goes into protect mode, use a multimeter to confirm that you have 12v on the B+ and remote terminals. Place the black meter probe on the ground terminal of the amp when measuring the voltage. If the voltage is sufficient and the amp goes into protect, it will have to be repaired. JL only accepts repairs from authorized dealers. You'll have to find one in your area or you'll have to find a repair shop willing to work on JL amps.
Let me know if you have any other questions.
Posted on Oct 15, 2008
Why is jl audio 1000/1v2 in thermal but not hot?
They might be using the light to show other problems as well. Or the unit you bought has the same issue??
Double check all your connections, leave it unplugged for 24 hours after hitting the power button several times to drain the capacitors to hopefully clear any codes in the modual.
May 15, 2014 | Jl Audio 1000/1V2 Car Amp
I have a Jl Audio 250/1 mono block amp and the thermal light keeps coming on what could be causing this?
It could be a number of things? 1 to many subs, speakers wired to the amp causing it to overheat and making the thermal light come on. 2 It all depends were your amp is. If it's clear and nothing covering it, obstructing it, Ie sub in front of it, amp inbetween the rear seats and sub.
Mar 04, 2011 | Jl Audio 250/1 Car Audio Amplifier
The thermal light on my JL AUDIO 250/1 car audio amplifier is blinking, even after I have shut the veichle off for hours. HOw can I resolve this?
try to pull the fuse....may reset the amp...but more than likley there has been some kind of internal damage ....ie... water damage or bad speaker connected etc....
Aug 24, 2010 | Jl Audio 250/1 Car Audio Amplifier
My amp cuts out at higher volume
This happens to me all the time during the warm months. The problem is likely that the amplifier is overheating because of location. If not properly ventilated, the amplifier will shut off before damage occurs. Is it located under a seat or other area where sufficient air flow is lacking? I solved this problem by moving my amplifier from under a seat to the trunk area.
Jul 10, 2010 | Jl Audio 500/1 Car Audio Amplifier
JL Audio 500/1 Amplifier "Thermal" light flashing
Re-check all the connections to the speakers, The uPC monitors all the outputs and if any are taking more power than they should, the uPC shuts the amp down to protect the internal components. Don`t use tape joints alone, try to run the cable the full length without any joints. If you do have to piece the wires together, solder them and stagger the connections, in other words, make one lead shorter than the other so that if the tape does come off, the offending connection is well away from the other so they can never meet or connect to each other. Ian
Jul 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
1 10 jl jl 250/1 mono block amp cuts off an on help
your subwoofer is wired incorrectly to your amplifier. Figure out which ohm load of subs you have and then what ohm load options your amp is stable at. Next go to either the Crutchfield website. find their learning center. go to subwoofer wiring diagrams. or go to www.the12volt.com and find their section on it
Jun 11, 2009 | Jl Audio 250/1 Car Audio Amplifier
Jl 500/1 amplifier will not turn on
you may have burned the channel you were using..try taking the cover off the amp and checkin for burned spots or any wires that may be loose or touching within the amp.
Feb 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
My jl Auido 250/1 amp
You may have a bad output on the amplifier. I would recommend taking it to a local electronics repair to have fixed, or visit a local stereo shop - preferably a JL Audio dealer. Visit their website at www.jlaudio.com to find a dealer near you. You can have your amplifier sent in to JL Audio for repair by an authorized dealer and you'll get a warranty on the repair work.
Sep 27, 2008 | Jl Audio 250/1 Car Audio Amplifier
Help me
It sounds like your running the amp to hard (gain too high) or on an impedance lower than 1.5 ohm. What type of subwoofer are you running? voice coil? how far around is the gain setting? e mail me a j_impala@hotmail.com if you like.
Nov 08, 2006 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 250/1 Car Audio Amplifier Logo
789 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
