Question about Refrigerators
Freezer keeps icing up and lights turn off when ref. cycles off
Freezer icing up and when ref. cycles off lights turn off or when i turn off at t-stat lights turn off also. Have already replaced defrost board
    Genius:
  • 1,122 Answers
You need to check the freezer defrost heater and terminator with an ohms meter,this is where your problem is if you already replaced the defrost board,let me know what you find-mike
Posted on Oct 15, 2008
Thanks God my refrigerator started to work after we turned off for 8 hours.
If refrigerator started to work after being turned off for 8 hours, I suspect that the evaporator was frozen and restricting air flow. Turning it off let the ice melt and it worked again. But when the ice builds up again the same thing will happen.
Think the problem lies with the self defrosting mechanism. Either the timer is bogus or the defrost heating element has gone South.
Jul 06, 2015 | Refrigerators
The ice maker goes through the cycle but never fills with water to make ice
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 29, 2011 | Refrigerators
The freezer is iceing up and periodically the fan with kick on and off in in short cycles where I have to turn on swithch to off and back to reset. What part do I need to replace. Whirlpool model...
NOTE: This
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
But is probably a common defrost problem The ice build up
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 27, 2011 | Refrigerators
Ice tray frozen over. will not drop ice. Keeps dumping water on top of ice tray during cycling.
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
Leo Ponder
imufo2
Aug 08, 2011 | Samsung RS2630SH Side by Side Refrigerator
Ice build up on rear panel of freezer. side by side frig. temp is not cold enough to keep food from spoiling. Water will not freeze in ice tray.
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 28, 2011 | Refrigerators
The top freezer of my Maytag refrigerator does not keep ice cream firm. It will freeze water, but ice cream is like cool whip. Help!
Check your ref/frz settings. Check the condensing coil for dust/lint/other. You may also have a defrost problem. Check back panel in frz for ice/frost. Try emptying unit and leaving it off and doors open for 24 hrs. If it starts cooling afterwords, is probably dft cycle.
Nov 22, 2010 | Maytag Refrigerators
Ice is building up on the back panels in the freezer and the refridgerator is not as cold as it should be
you have a defrost problem, a bad defrost control, or defrost t-stat or possible bad heater. turn the ref off until it thaws out usually takes 24hours with the door open the plug it up and see if it stars working properly
Nov 18, 2010 | Refrigerators
Back of freezer ices up .refridgerator warm... Fan is OK..... Top mount freezer
There are 3 things to look for on this. The defrost timer which tells the ref. to go into defrost, the defrost t-stat which sends power from the timer to the heater and then the heater. Most likely out of the 3 it is usually the t-stat located on the evap coils behind the back panel of your freezer section. Easy to get to and easy to change. The stat is the one item that has a wire going to the heater. Hope this helps.
Feb 02, 2010 | Refrigerators
Freezer and Ref. are warm
i assume this is a frost free type. the fault may well cure itself.
to hasten the process, remove the back panel inside the freezer and you will probably find the pipework frozen up. melt of the ice carefully with a hairdryer making sure you don't heat any stats that are clipped on the pipework
Sep 04, 2008 | Whirlpool GD2SHGX Refrigerator
GE Fridge/Freezer Having to turn temp up just to keep it cold
From your comment. It's not that you have to defrost the parts, that's what they're called. "defrost timer", "defrost t-stat" and "heat element". Defrosting the whole fridge for a few days actually will clear the ice blockage if that's it but it will return in a couple weeks if the "defrost cycle" isn't doing its thing. A fridge typically goes into some form of "defrost cycle" to keep it "frost free". As an example, every 12 hours the compressor turns off and the evap. fan turns off then a heat element turns on to melt the light coating of ice on the "cooling coils". Once about 1/2 hour goes by the heating turns off and the cooling turns back on again. This repeats over and over to keep the ice from building up too much. If that cycle is broken, the ice will build and build till the whole coil is a block of ice. Then the air can't flow around it to provide cold air for the whole unit. It acts basically like putting a large block of ice in the freezer and keeping the doors closed... without a fan to move the cold air only the very lower portion of the freezer is cold, the rest is warm.
Dec 30, 2006 | GE GTH18KBR Top Freezer Refrigerator
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
