Question about IBM ThinkVision L170 17" LCD Monitor
Suspect backlight inverter circuit--desktop appears completely for 1s and then loses backlight
Desktop appears completely for 1s and then loses backlight. Pushing the analog/DVI select button brings backlighting back on for 1 second and then drops. i suspect the inverter circuit as i found one 10v1000µf cap (C551) blown. I replaced this and its counter-part a 25v470µf cap (c661) with 25v1000µf and 25v470µf caps, respectively. Same symptoms. I am uncertain where to go from here as it would appear the backlight lamps are functioning and the inverter appears to work perfectly for about 1 second and then drops power to the lamps. I do not have a B.O.M. or schematic, so I am really troubleshooting blind. I suspect a protection feature is of some sort, but again, i have no schematic to reference. Where do i go from here?
  • 4 more comments
  • Noel Rusnell
    Noel Rusnell Oct 16, 2008
    To clarify, the first step in troubleshooting was to look for physical damage and re-seat cables, checking components one by one for visible signs of damage. I am unsure as to where to go from here. I do not typically perform shotgun parts replacement, but i do check each out of circuit. The lamps check out ok and all light up for one second. I am not understanding the cause of the inverter to be fully-functional for one second and then shut down. I am suspecting an over-voltage protection circuit or something of that nature--beyond the obviously failed and replaced 1000µf cap (C551) i am not sure where to go.for this symptom. Part of the problem is i do not have a schematic nor B.O.M. to reference.
  • Noel Rusnell
    Noel Rusnell Oct 17, 2008
    B+ is 14.44V, regulated 3.3v, 5v and 12v is present on the video processing board and 5v, 12v are both present on the power supply/inverter board. I am in dire need of a schematic to be certain, but i am leaning toward a faulty BIT3105 CCFL Controller as it has built-in dimming and over/under-voltage protection circuits as well as open lamp detection...a little more testing is necessary...a schematic with correct pinout values and B.O.M. would be really helpful here as i could better decipher the current path and TTL signal/switching processes. I am uploading images showing the power and inverter board along with the blown 10V1000µf cap and of the 1-second desktop--you can well imagine the fun i had timing the digital camera to capture the display ignition
    here is the link to the datasheet for the BIT3105 Controller: http://pdf1.alldatasheet.com/datasheet-p...
    Pinouts are as follows:
    ϑ 7.43V on AVDD and PVDD
    6.96V on CMP
    1.25V on RTDLY
    ϑ 7.4Von NOUT2, NOUT1, POUT1, and POUT2
    1.52V on EA
    213 Kω on PWMOUT
    1.3V on CTPWM
    .6V on DIMDC
    3.9V on SST
    0~.4mVon CLAMP
  • Noel Rusnell
    the one cap appearing to have the bulge is one i was super-imposing with a pair of forceps for comparison. its replacement is shown immediately below it in place and is taller by a full height than its counterparts. the four 25v47µf caps and the 2 pots are connected to the BIT3105 CCFL controller (top-center of the board) which i described in my previous post and whose 7.4Von NOUT2, NOUT1, POUT1, and POUT2 drive the N&P MOSFET switches on the back side of the board. the 4 lamps check out good; however it appears i need an inverter transformer SPI 8TT00006 as there is an open winding at pin 1 and pin 8 on T4 (labeled faintly in blue on opposing ends of the faulty transformer)
    So, here's the kicker...SPI 8TT00006 does not come up for any vendors i can find with a google search or even eBay. Any ideas? know of spares on unused inverter/power supply board for these models? closest i could find is a long shot by Delta Electronics with stock number CIT011. your take?
  • Noel Rusnell
    Noel Rusnell Oct 19, 2008
    in the end--even those electronics suppliers who list the part as "available" on their websites, don't...and their techs and sales staff do not know what they are when contacted directly and have had to get their engineers working on locating a match. I've been waiting for a call back from the suppliers as to whether they can even do that...the customer has opted not to wait and picked up the old LCD...what for, i don't know...maybe all the troubleshooting was really what they were after all along. I suppose i could have or might have been able to use the unit for parts...shame they wouldn't at least wait for a response from the suppliers. back-up plan was to check e-Bay for a parts unit, but they refused to wait...
  • Noel Rusnell
    Noel Rusnell Nov 03, 2008
    thank you,
    kenny258...great suggestions--sadly, i no longer have the LCD to try these workarounds; however i am most certainly keeping this page bookmarked for future reference.
  • Ngewakl Soaladaob May 11, 2010
    I had the same problem but I had loose connection on my inverter board. I assume you have reseated your board?
"Latched Open Lamp Protection Pin 4", disconnect the transistor 7002 "D" Pin on BIT3105 Pin 4.
Posted on Oct 30, 2008
  • kenny258 Nov 03, 2008
    Solution of Transform 8TT00006.
    1, I have been use an old Compaq laptop single CCFL transform to do the job.
    2, Or pull out 2 transforms and put in a bigger one for 2 CCFL, you can keep the good one for spare.
    8TT00006 primary only use 2wire that easy covert to other transformers, just let the CT pin
    open.
    ps; May be you need disable "open lamp protection" Pin 4 (lamp current unbalance).
I had just the same problem and suspected the BIT3105 IC, but this was working well. It was just in protection mode because of a broken hi-voltage transformer (one of the four). All the secondary outputs of this transformers have a resistance of 1 kOhm, but that one was open! By removing it from the circuitboard it was clear. On the bottom of the transformer was a black spot from a "spark-bridge". All the CCFL tubes were good. So it must be a production fault. The only thing you can do, is find a new or similar type of transformer and try to put it back. (maybe from an old TFT monitor)
I think this is also the problem by a lot of people here.
Best regards,
Jonathan
Posted on Feb 02, 2010
Hi i need the type number of ic u302 can you tell me the type numer of this ic ??? i have the same power supply but the ic u302 is burned up and now i cant read the type numeber..
send a mail to ladre5@hotmail.com
thanks
greatings
Posted on Sep 26, 2009
Hi I'm not very proficient with these technologies but I think the blockade is produced specifically SOP-8 mos additional power, Branding: A or P First line: 4600 Second line: BB03N15 or AD3S3L, which are responsible for the blockage of energy. ..
Posted on Sep 18, 2009
    Novelist:
  • 159 Answers
Hi.
If you find one blow capacitor, you should change out all of them.
The large main one can usually be left go but for 6 bucks it is wiser to change that too while it is apart.
If that doesn't cure it then you have to move on to the transistors that run the backlight transformers.
A NOTE: you could have one failing bulb. Not sure if yours has 2 or 4, but it only takes one bad or weak bulb to give you the same effects.
bammbammfran
Posted on Oct 15, 2008
  • 2 more comments
  • Fran Bednar
    Fran Bednar Oct 16, 2008
    Finding a schematic is worse than finding some of the parts
    forthese or any boards. They are secretly stashed with the creators.
    A
    bulb going on for a second is not long enough to tell if it is
    good(especially if it is still in the screen and you cant watch
    it'sreaction) easiest way to test them is with the use of another
    monitor.
    Being 17s are older units, this is a common failure in these.
    What are you showing for dc voltage at the connection to the video board ? Most older units run 5 and 12. Some just use 5vdc.
    Good
    looking caps are not always good caps. Standard cap meters don'talways
    give the most accurate info. An ESR meter is the best to use.But it's
    cheaper to change all the caps then to buy a meter and sincecaps are
    the most prone to fail with age, now is the time to changethem all out
    if your showing some dc which you should have since yousay you have a
    picture for a bit.
    If you have a picture, post it or email it to bammbamm@ptd.net
  • Fran Bednar
    Fran Bednar Oct 17, 2008
    DC values appear typical.
    The screen picture looks darker on top than on bottom..
    DID you individually check the bulbs ?
    Plugging them in ONE AT A TIME to get the flash on the screen may help
    tell especially if you disconnect the video to lcd ribbon (that will
    give you just a white screen and make their brightness a bit more
    noticable)
    Best way to test each is using another monitor as a power source- It only takes one to stop these boards in their tracks !!
    It almost looks like the one cap is bulged on the picture (could be the picture?)
    I don't see the transistors the the ccfl transformers, (Probably on the
    back of the board between the ccfl transformers and under the 4 caps )
    If it's not a bulb , I would think these are more likely the suspects
    than the actual ccfl control board. Check to see if any are grounding
    out against the positive DC side.
    Again. Schematic WOULD BE GREAT !! But !!?? I have to trace just about every board I work on since I can't find them either !!
  • Fran Bednar
    I thought that capacitor looked out of place !!
    There is always a kicker !!
    Now More FUN finding the part !! ??
    Only
    one inverter I've done uses one transformer to one ccfl and thatis a
    Benq, but those are square shaped. All my other boards use oneTrans for
    2 lights.
    That one is almost light a laptop transformer.
    You can maybe get lucky and get a cross reference from lcdparts.net ??
    LOT OF WORK for a 17" screen !!!
    It appears you are like me ! PERSISTENT !!
    Fran
    This may help finding a substitute
    http://www.cooperbussmann.com/pdf/dc8ad7...
  • Fran Bednar
    Fran Bednar Oct 19, 2008
    Hi.
    If you want an ebay parts unit, wait a while (YOU'LL SEE THIS ONE SHOW UP !!!!! )
    Can't please all the people all the time !! All you can do is try !!
    Thanks and have fun
    Fran
What is the test for a flashing backlight?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 18, 2016 | Televison & Video
LED Backlights on LG TV?
If audio is OK, the backlight inverter is the part should suspected. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Oct 25, 2015 | LG Televison & Video
Tv turns on ok for 5 seconds then picture goes blank then recovers after ten minutes
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should troubles shoot. Contact any service technician. The circuit will differ with models and versions.
Apr 07, 2015 | LG 42LG50 42 in. LCD HDTV
Screen comes on for a second, then off, can still hear the tv, just cant see anything Westinghouse 32 inch hdtv
you are describing an inverter failure or possibly a backlight failure. the inverter is waht powers the backlight very similiar to flourescent lighting. it will most likely be an inverter failure before the backlight. if you were to post a model number i may be able to find a part number for the inverter
Jan 06, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Monitor does not display all the icons but a computer displays well when connected to an external desktop monitor
If you mean the desktop isn't completely filling the display, you need to be sure the resolution is set correctly. Native resolution for this model is 1500x1050, according to Dell's site. (Native resolution is the one the screen was designed to best work with. Unlike older CRT monitors, some resolution settings don't work well on LCD screens.) You can check and set the resolution through the Windows control panel.
If you mean that the display is dim and hard to make out, but is okay on an external monitor, you probably have a backlight issue. Without the backlight, you can't see what's on the screen even though the display is working. The usual cause of backlight failure is a bad inverter. The inverter is a small circuit board in the display that provides power for the lamp. Replacements are available for most laptops, and changing one is normally not a major job.
Sep 29, 2010 | Dell Latitude D610 Notebook
My samsuNg PS42A410C1D has no picture. i cant bring up any menus or anything see anything but it is producing sound
The most likely thing is that your screens backlight or inverter has gone faulty.
When you turn it on, you may be able to see a very very dark image of something (best seen by activating the TV menu). On some screens the picture is still far too dark to be visible though.
With this kind of fault, its down to fitting a new inverter, and if that doesn't cure it, then fitting a new backlight bulb (or bulbs) will sort it out, but these are not jobs that can be done without some expertise at them.
Most TV inverters are large circuit boards inside, and take about 20-30 minutes to change as the whole TV has to be dismantled, but the backlight bulbs are much more complicated (and extremely fragile too).
Unfortunately, there's not much else that can be done except trying changing those 2 parts. Although its possible for the screen cable inside to become disconnected and lose your picture, that results in the screen lighting up brightly (usually pure white if the cable comes off completely).
Apr 27, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Screen goes black but still can see the desktop??
Yes this is a back-light problem. The fault could be the inverter board which supplies high voltage to the CCFL lamp or it could be a faulty CCFL lamp, this lamp is a mini fluro tube.
For service, parts and DIY info check out LCD Parts - click on this link to their WEB site : -
www.lcdparts.net
Oct 12, 2009 | HP w2207 Monitor
Dell Inspiron 6400 - Screen visibility problems
This could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 16, 2009 | Dell Inspiron 6400 Notebook
Olevia 237V Backlight problems
Check inverter supply voltage, (should be constant and stable) if found ok, then inverter or back-light tubes are suspected.
Sep 06, 2008 | Olevia LT37HVS 37 in. LCD HDTV
IBM ThinkVision L170 17" LCD Monitor Logo
8,923 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
